It does for sure.
You just need to have regulatory domain, your country and gain value set on wireless tab. on Tx power tab should be "default" mode.
Then, changing the gain value changes the tx power.
It cannot have any impact on the rx power, but you can regulate it on the second side as tx power in the same way.
I see. Thanks. But connection speed is 1300Mbit\s very rarely. I tried to change channels, increase antenna gain, etc. But most of time I see only 878Mbit\s (and it drops down when I test connection with iperf). It is possible to increase connection speed and make it more stable?
