Hey guys! I'm looking for a solution to a couple features i need in my WAN network. Here's what I'd like:
1] Master router (RT-N12E) inside, plugged into LAN.
2] Outdoor extender for the Guest network with a signal radius of about 200m = ~500ft (master will be 20m away).
3] Guest network/slave must have captive portal, no registration, just a popup and confirmation. This captive portal must allow an iframe with an external webpage. Captive portal ideally setup on external site.
4] If the master WLAN is unavailable, fall back to a TPLink E5250 pocket wifi with HSDPA.
5] Most importantly - Guest network/slave needs to have URL redirection. Not IP filtering/firewall, but real redirects. So eg. google.com redir to google.com/images. I would prefer if these rules could come from an external server/php script so that I can edit them from anywhere without touching the router software. I have hosting servers for the external stuff and PHP/HTML knowledge to set the external stuff up.
I have been looking at the RB912UAG-2HPnD or 5HPnD (not sure which to choose). But I like that I can upgrade to PCIEm in the future and not have to use the TPLink.
Here's a little mock-up of what the network should look like.
Is this doable? Thanks in advance for any advice!
