Does anyone know which connectors are used in the hex ac? They aren't the normal mmcx. I need to attach external antennas and I can't seem to figure out what they are.
Thanks in advance.
I think he means replace the test points with smd UFL connectors. The test point solder pads do match up. Of course this voids the warranty and breaks FCC rules.There is nowhere to solder to
