mipland
Re: WR: 304km with RouterOS + XR5 + handmade antenna
Fri Nov 30, 2007 10:47 am
can you please give us some more detail about the antenna and feedhorn used ?
They are also on this thread.
Also how did you do the alignment ? (via alignment mode in ROS ? )
Sure.
Did you put the permanent link on ? ( you said it would be late sept. this year. )
Hy jorj, you are right. We tried to re-estabilis that link on the fist days of October, but we encounter some problem to re-establish it. We have still not re-establish it, becouse that site is very hard to reach (on this moment, there's a big quantity of snow there!).
I will write here when we will able to put it permanent.
0ldman
Tue Feb 26, 2008 9:23 am
It was 70F here today (30F tomorrow!), did you get it going yet? When is winter over there?
Very interested myself.
kthameen
Fri Feb 29, 2008 12:29 am
The longest working link is between Cyprus and lebanon which is up since 11 months at 284km ,all these trials are not links if they can not be up at least for 48 hours.And there no evidence that this link worked even , at least u can print screen when you got ur first connection, and using 1.2 m dish will get u one or 2 reply on this distance but will not get you a link you need over 2.8m Dish on your next try.
Regards,
jo2jo
Sun Jul 06, 2008 1:38 pm
any update?
great work guys! really quality stuff!
Mikrotik deserves some credit in any articles for sure.
xin005
Mon Jul 07, 2008 2:30 pm
"200km Distance of the sea surface ", How you are to build up The Wireless Relay Station?
use Height Balloon or Ship ?
mipland
Mon Jul 07, 2008 9:14 pm
"200km sea surface"? How you are to build up Wireless Electrics station? On the Sea...
sebac
Tue Sep 02, 2008 2:56 pm
Nice work!
73 de 9A3BSP!
neoplan
Sun Sep 14, 2008 2:00 pm
First of all congratulations for this great job!!
The most impressive of all is that you used handmade feeders! it seems that they are simply PERFECT!
Would you mind giving us the key dimensions? the internal diameter, the total length, the length and the diameter of the cable inside (or did u use something else?) and finaly its distance from the bottom of the feeder.
I have tried to create feeders for the 5ghz band but without such results.
thanks
uphi
Mon Sep 22, 2008 8:26 pm
Congratulations on this great job ! As a ham radio operator, and builder of ATV repeaters, I know how hard it is on those frequences ! Very impressive ! Keep us updated on progress and please publish specs on antenna dish.
Thanks,
Earl
N8TV
neoplan
Wed Oct 22, 2008 7:10 pm
thanks
i guess you don't wanna tell us the feeder dimentions... :(
jacoblydon
Thu Nov 20, 2008 2:56 am
I did my speech in Oral Communications on this link last semester!
titius
Mon Dec 08, 2008 2:15 am
alebianky
Thu Jan 29, 2009 8:07 pm
With wath tools Do you Points de Antenas ?
The GPS and what else
bonnecomm
Wed Jun 24, 2009 5:40 pm
WOW! That is just amazing! I am very much impressed.
Real
Fri Jul 31, 2009 7:15 pm
mipland , congratulations , impresive distance, great job :wink:
thanks
i have information about this type of can antenna ,and i have rebuild other's manufacturers antena feeders from 1 to 2 polarizations , work great and used in my real working network without any problems, it can be used in N standart or in Nstream2 configuration , i dont know how much isolation is betwen 2 emiters in db, then one radio is enabled (16db card,30cm pigtail and 1m s400 cable conected with N conectors),other card show -35 db ,but with N standart, 2.4km distance ,2 26db 2 polarization antenas i reached rate 70mbps in and 70mbps out in ful duplex ,i think is good results :wink:
there a lot of information about can antena :
http://www.h-online.com/features/Build- ... -/110278/0
i think its helpful for you and all :wink:
Nanflexal
Wed Sep 16, 2009 8:14 am
Congrat for the hardwork. it's amazing.
I have the same project. anyway, I want to build my own WISP somewhere in the philippines, I plan to cover all island in our place which Telco can't provide internet access.
here is my thread:
http://forum.mikrotik.com/viewtopic.php?f=7&t=34957
winnie
Tue Jan 12, 2010 9:59 pm
nice link
i would really like to know what do you use to work out the LOS?
We would like to test a long range wifi link also, but some sites say the LOS is fine, others say the earth curve would not allow.
any help appreciated
Adam McLaughlin
Tue Jan 26, 2010 2:51 am
I'd like to tip my hat to you guys, congratulations from a fellow UHF Ham
Adam KD6POC / K6KPH
tagno25
Sat May 15, 2010 10:48 am
It would be neat to attempt a 70000km+ link and get it working, even if for only a few seconds.
It would probably require a different radio and a amp though.
KillerOPS
Sun May 16, 2010 1:26 am
and a wireless freak on the moon. literally
tagno25
Sun May 16, 2010 3:13 am
Oops sorry, when I posted I accidentally removed saying to try a moon bounce.
xezen
Long time Member
Long time Member
Sun May 16, 2010 11:31 am
what is this link doing with new router os
and the uptime on of this link
and the config if possable
samsoum
Thu May 27, 2010 8:04 pm
hi
are u able to help to build a link 270km for us?
we are looking for a link between cyprus and lebanon.
please advice if u can establish this link
sam
doush
Long time Member
Long time Member
Tue Jun 08, 2010 12:14 pm
hi
sam
shoot me an email
yalmandogus [at] yahoo.com
nahvi
Fri May 16, 2014 7:28 pm
this link is very very good
i have one question
Mikrotik RB912 help you score better bandwidth on this link?
tiagosouza
Fri Jun 13, 2014 7:20 pm
Hy all.
On 16-06-2007, we (CISAR, a radioHAM italian association) have realized a 304km link (about 100km ground and 200km sea surface), between Amiata mount (1734asl) and Limbara mount (1300 ca asl).
We utilized a pair of wrap board (but they will be replaced by a new RB532 soon), a pair of Ubiquiti XR5, and a pair of handmade antenna (120cm satellite dish for the surface, and a bronze ball-bearing extracted from a bus).
The signal received on both end was from -58dBm to -62dBm, bitrate between 12 and 48Mbps, CCQ between 70 and 100.
IW5CGM and IK0TCL on Amiata mountain
Me (IZ3HAD) on Amiata Mountain
IK0PCJ and IK0YUK on Limbara site.
IW0UIF on Limbara Mountain
Image Image
The feed (we used the feed on the left)
On the moment i'm writing, this seems to be a distance world record (the precedent was from "Politecnico di Torino" on Italy, 295km).
The people which partecipate on this WR:
Amiata Mount
- Giuseppe IW5CGM (CISAR president);
- Antonello IK0TCL
- Mirco IZ3HAD (me)
Limbara Mount
- Natale IW0UIF
- Paolo IK0PCJ (antenna's constructor)
- Mauro IK0YUK
73 de IZ3HAD, Mirco
mostafaafus
Fri Jul 11, 2014 8:21 am
Hi dear mipland
i have some question about this lik
please contact me :
mostafa.afus@gmail.com
+989153092801
Best regard
ThorHunt
Tue Jan 08, 2019 7:35 pm
Hi Mipland,
That's a great & clever job. Congras!! So, could you please, post the images again. I'm experiencing the same issues (a long link a way to 200km) that I believe you can help me with details. Your post went forward through the Mikrotik Support Team (as a good achievement) after my ticket request about devices options to solve this issue. I appreciate any contact about that.
Cheers !!
Thor
Hy all.
Image Image
Amiata Mount
- Antonello IK0TCL
- Mirco IZ3HAD (me)
Limbara Mount
- Natale IW0UIF
- Mauro IK0YUK
73 de IZ3HAD, Mirco
Users browsing this forum: Amazon [Bot] and 59 guests
