No i can not, like i said its like the routerboard is not responding to me at ALL i can send all day but it will not send anything my way packets are sent but not receieved. However i can connect up to the wireless network fine ????????? but i STILL can not log into winbox nore webox.... Although under interface's just before it went haywire on me, there was no R in front of the Wlan1 so maybe that has something to do with the wireless part.... Is there Any way of remote accesing it? Like a restore to a previous time.... My serial cable is coming today so, if all else fails i needed to do a netinstall anyways. Thanks guys - JordanUsing winbox, can you connect to it via mac address?
I will if i can not reset config or fix the problem, Thanks guys. = Jordangrab an old PC and install the demo on it.
WHat COM port is the routerboard on it does not indicate nore show the routerboard in any of the COM ports, and remember ethernet is paralised... i beleive most of you keep thinking ethernet works on the routerboard for some reason it does not, disabled or somethign im not sure.With your serial cable and hooked up to the router and a network cable
from ether 1 to your nic and hyperterminal configured as you noted and
running, power up the router and then hit any key to enter the ROS
bios. Select etherboot. Now you can FTP the ROS package to your board
using ether1's address.
Did I miss anything? If my memory isn't completely gone I think this is how I did it several months ago.
Yep. I tried that, i was able to get ahold of this very good web page and description of how to reinstall router OS this is the url http://www.miro.co.za/manuals/What_Do_I ... ssword.pdf I did that, i setup my serial cable it was put to COM port 20, so i set the COM port to 20, set the rate to what you told me, and then light up the routerboard, Nothing loads up on the screen, says its connected and it says auto detect, auto detect, and NUM, I also tried 150200 but that didnt work. Is my routerboard TOTALLY off the wall or something!! I no for a fact what port it is on so its not that... What else could it be? IM so close to just asking ANYONE if they are willing to netinstall it for me, I will pay for shipping there and back and whatever else... Its going on a week and I cannot fix this thing, This is delaying my hole wisp startup.. Anybody got any ideas?? please? thanks- Jordan....Set up Hyperterminal for a new connection using whatever Com port you want (no dialup #), 9600 , 8 bits, no parity, 1 stop bit. With Hyperterminal configured and running and the serial cable connected, power on the router. Hit any key within 2 seconds to enter the bios after MikroTik appears.
Well my hyperterminal seems to allow COM20, i will set it for a smallter port number and give that a try but i HIGHLY dought it will help anything.Com 20??? In Hyperterminal I believe you have a choice of Com1-5. But to back way up, why are you using an old 112 for an AP at all? Why not a 532 or 133 at the very least?
Ok did that, it reset it and really the only way i know that is becaue the wireless connection is no longer, soo im guessing software was reset but still nothing from ethernet nore serial... im starting to think the board is fried... Why i have no clue, it still lights up and beebs twice... so im not sure. *Sigh*There is a software reset jumper on routerboard, shorten it, reboot router and all configuration will reset.
