OpiumDream
Re: 802.11n
Wed Jun 23, 2010 2:19 pm
we have 4.10 :(
Voltage
Re: 802.11n
Thu Jun 24, 2010 6:15 pm
I have a poor link that is only running at 3 mbps with 10 Mhz channel bandwidth.
It is a link with no good line of sight, because many trees and bushes are there.
Is it possible to use 802.11n for that link and getting more speed?
Greetings
xezen
Long time Member
Long time Member
Re: 802.11n
Mon Jun 28, 2010 1:04 pm
what setting do i use on n cards if i use chain as i cant seem to get ccq up i played with tx powe as on defualt i get -20
for 3km link please help with a basic setup that works with 20-30 mb that i can play with
chvdr
Re: 802.11n
Mon Jun 28, 2010 1:20 pm
Greetings
unfortunately, no. n-draft usable when everything is almost ideal. and after that nobody knows why if not usable. we fighting for bandwidth test of 100Mbps (FDX) @ 5km link already year - unsuccessfully. -55dBm levels, 140Mbps, but only one directional. when direction=both, worst results done.
xezen
Long time Member
Long time Member
Re: 802.11n
Mon Jun 28, 2010 2:03 pm
can anyone help i have lOS 3km
26dbi grids both sides
433ah on both sides and n radios
i have connected one chain0
chvdr
Re: 802.11n
Tue Jun 29, 2010 2:21 pm
what cards
what signal levels
OpiumDream
Re: 802.11n
Tue Jun 29, 2010 10:34 pm
has anyone tried n link bonding ?
is 300 mb real throughput achievable or it's just a 2 more years dream ?
chvdr
Re: 802.11n
Tue Jun 29, 2010 11:46 pm
it's still only a dream
missinlnk
Re: 802.11n
Wed Jun 30, 2010 5:40 pm
I have a customer trying to accomplish it right now. He's using some high dollar filters to do it. He's got the link working, but he's still working out the kinks to try to get it above the bandwidth of just one fully maxed out 2x2 40MHz N link.
iw4eky
Re: 802.11n
Wed Jun 30, 2010 6:15 pm
Hi guys,
that's the result of my tests with 802.11n on Mikrotik hardware, keep reading for an abstract of results and images with settings.
I started using the settings suggested by "exe" on the previous posts and make some changes to find the best tradeoff between stability and performance.
SCENARIO
AP and STATION: RB433AH and R52n radios inside outdoor metal boxes with u.fl-N pigtails
Antennas: Jirous JRC-24 DuplEX
Distance: 4km with perfect LOS
RESULTS (see images below)
Highest UDP speed reached: 180Mbit/s stable and simmetric on downlink or uplink, CPU average load @ 70-75%, average ping @ 15ms
Highest TCP speed reached: 90-95Mbit/s stable and simmetric on downlink or uplink , CPU average load @ 100%, average ping @ 40ms
ROUTEROS SETTINGS (while testing at 150Mbit/s UDP fixed speed)
NOTES
- Using HW-retries of 4, 10 or 15 the results didn't change that much
- I made the tests using RouterOS 4.9, 4.10 and 5.0beta2 on both devices with no change on performance
- Each outdoor box has only one RB433AH, one R52n and 2 pigtails. At first I put the test board together with another RB433AH in the same box and the RF interferences caused the link to work perfectly only on tx side: the rx side was interferred by the other miniPCI radio even though their working frequencies were spaced by 400MHz!
I will soon do more tests using RB750G connected after each RB433AH, so the results will be more effective and similar to a real production scenario.
Bye,
mattia
jbowsher
Re: 802.11n
Wed Jun 30, 2010 6:53 pm
anybody seen one direction bandwidth tests resulting in 346Mbps UDP and 140Mbps TCP? Thats what I was getting yesterday with my sr71's and was curious if anyone else has seen better results? :shock:
OpiumDream
Re: 802.11n
Wed Jun 30, 2010 9:34 pm
it's a kind of magic :shock:
chvdr
Re: 802.11n
Thu Jul 01, 2010 7:20 am
no, it isn't a magic. no even impressive result.
let iw4eky show result of bandwidth-test with direction=both
chvdr
Re: 802.11n
Thu Jul 01, 2010 7:23 am
iw4eky, show us result of bandwidth-test with direction=both
iw4eky
Re: 802.11n
Thu Jul 01, 2010 10:47 am
Ok, below you can find the results of bandwidth-test using "both" directions!
Highest UDP simmetric speed reached: 66Mbit/s stable on both downlink and uplink, CPU average load @ 30%, average ping @ 40ms
Highest TCP simmetric speed reached: 58Mbit/s stable on both downlink and uplink, CPU average load @ 100%, average ping @ 40ms
Highest UDP asimmetric speed reached: 90Mbit/s down and 35Mbit/s up, both stable on downlink and uplink, CPU average load @ 15%, average ping @ 9ms
Highest TCP asimmetric speed reached: 68Mbit/s down adn 35Mbit/s up, both stable on downlink and uplink, CPU average load @ 100%, average ping @ 34ms
And I'd like you to believe me that I post the results just to be of help to the Mikrotik user community: I don't want to challenge anyone nor I desire any prize! This is my job and I'd like to share the results with you, as I was helped by the work of other users on this forum.
Bye,
mattia
jbowsher
Re: 802.11n
Thu Jul 01, 2010 9:42 pm
wasn't looking for a prize.....I was a little shocked with my results as they were the best I've seen but I felt that it was still less than adequate for 5ghz-N and I was looking to see if anyone had gotten closer to the 200 Mbps mark than I had. I am curious why everyone uses RB800 or RB433AH's since it seems to be better to have more processor. The best I had "both directions" was 170 Mbps/170 Mbps UDP. TCP seems to jump around a lot but mine was hanging around 80 Mbps/60 Mbps both directions and part of me thinks its just that the bandwidth test doesnt like x86 as i have confirmed with a couple mikrotik distributors that there is a problem with x86 and the btest which i have seen with other tests of my own. I want to help out here too but I want to get the best results or make sure I have the best config so that I don't hand out problems with my setup. Thank you for any help or advice that you can share.
Muqatil
Trainer
Trainer
Re: 802.11n
Thu Jul 01, 2010 11:23 pm
impressive results iw4eky :D
keep us updated if you get better results..
If you can get a picture of your installation too to see what it does look like would be very nice :D
BTW, i'm using your same antennas and i recommend them too
chvdr
Re: 802.11n
Fri Jul 02, 2010 9:57 am
yeah!
impressive!
taduikis
Re: 802.11n
Fri Jul 02, 2010 10:13 am
yeah.. glad to see your success :) I think of moving back to 11a-turbo setup already.. :)
csallor
Re: 802.11n
Fri Jul 02, 2010 1:03 pm
.. I'm think of moving back to 11a-turbo setup already.. :)
+1
piontec
Re: 802.11n
Fri Jul 02, 2010 1:35 pm
OK, I'm having... issues with 802.11n and despite of the reading of this forum I can't cope with configuration.
Here's the hardware I've got:
2 x (RB 433 UAH, ROS 4.10, R52n)
The wireless interface is in WDS, which is added to a mesh. Both antennas of R52n are AirMax AM-5G16, connected on pig tails only. The distance between my 2 test MTs is about 6-7m.
Iface config:
1  R name="r52-n" mtu=1500 mac-address=00:0C:42:61:98:05 arp=enabled disable-running-check=no interface-type=Atheros 11N
      radio-name="r52piontec_1" mode=ap-bridge ssid="test-1" area="" frequency-mode=manual-txpower country=poland
      antenna-gain=16 frequency=5200 band=5ghz-onlyn scan-list=default rate-set=default
      supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps
      max-station-count=2007 ack-timeout=dynamic tx-power=12 tx-power-mode=card-rates periodic-calibration=default
      periodic-calibration-interval=60 dfs-mode=none wds-mode=dynamic-mesh wds-default-bridge=mesh-testb
      wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      proprietary-extensions=post-2.9.25 wmm-support=enabled hide-ssid=no security-profile=default disconnect-timeout=3s
      on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
      station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0,1 ht-guard-interval=any
      ht-extension-channel=above-control
      ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-
                       15
      ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192
      ht-amsdu-threshold=8192 hw-retries=3 frame-lifetime=0 adaptive-noise-immunity=none
      hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
Now, problems I'm having:
1) During quite a few of my tests, the wireless link on the 2. layer was up, but there was no layer 3 link, when one of the MTs was in a high-speed mode; when the link dropped to 54M (a), everything worked OK. Unfortunately, I'm not able to reproduce this right now...
2) Sometime the reported link was even 300M/54M, but always only one peer of the connection has .n mode, the other is 54M max. Worse, when I run the speed test, it is something like 9-10Mb/s (tcp, both directions) or 12 (udp, both); even in one direction (the faster one, >> 140Mb) for udp it is 13Mb/s!!!
3) Sometime, despite the same configuration and exactly the same physical position, .n modes just don't set up -- I'm ending with 54/54 or even worse...
Any help would be really appreciated :)
wispwest
Re: 802.11n
Sat Jul 03, 2010 7:13 am
I really hope the official 5.0 ROS rolls out soon. I can't wait to try this on some of my major backhaul links, just can't risk BETA on them!
chvdr
Re: 802.11n
Sat Jul 03, 2010 7:44 am
better don't risk. to prevent some trouble. we test 5.0beta2 on pc before. but it cannot be installed on pc. lot of troubles to rollback to 4.xx
frontiersteve
Re: 802.11n
Fri Jul 09, 2010 7:10 pm
Just curious. What are the max pps people are seeing with various boards. i.e. 411ah, 433ah, 600, 800. Just want to see how the cpu power and ram impact the ability of these types of connections pump out the packets. I gather that on a solid link one could see 90 to even 100 mb/s tcp using the boards with 10/100 ports. Now I would like to see what the max is packets at various packet sizes. (64 on up to 1500). I personally have seen as high as 50k pps (aggregate) using 64 byte packets on an n link using r52n 411ah.
Harunaga
Re: 802.11n
Fri Jul 09, 2010 10:00 pm
The bandwith in WDS (ap bridge/wds - ap bridge-wds) mode is much less than in the mode of the ap bridge/station. When will it be fixed? VPLS not offer as WDS need to MESH.
changeip
Re: 802.11n
Fri Jul 09, 2010 10:43 pm
I dont think it can be fixed, you are splitting radio time 50/50 between AP and STATION. If you make it station its 100% dedicated to connecting to AP, if it's AP BRIDGE WDS then its 50% station, 50% AP.
taduikis
Re: 802.11n
Sat Jul 10, 2010 1:02 am
So using MPLS bridge setup should eliminate this problem?
ste
Re: 802.11n
Sat Jul 10, 2010 7:23 am
Yes. On nearly the same Hardware. But they do not implement DFS so i am
Not allowed to use it.
chvdr
Re: 802.11n
Sat Jul 10, 2010 7:31 am
what max distance you test
with n-draft m5
Muqatil
Trainer
Trainer
Re: 802.11n
Sat Jul 10, 2010 4:54 pm
What about latency and jitter?
I tested rocket m5, but the latency was high and jitter was crazy..
Harunaga
Re: 802.11n
Sat Jul 10, 2010 9:16 pm
Thank you for your reply. Well, how do I optimize the network, if I use a dual radio - one module to access and one module for backhaul? MPLS does not help here.
jyny
Re: 802.11n
Thu Jul 22, 2010 12:56 pm
Hi , I am new one im mikrotik. Im using RB433 with N wifi card and 5ghz double antena. I use it only for 1 km and i think i need to attenuation signal. Now Its working like before with single 5ghz antena with G wifi card. I dont find where i can attenuation signal, can somebody help me ?
im using rocketdish dual antena http://wificentrum.sk/dual-polalarizacn ... _d734.html
doush
Long time Member
Long time Member
Re: 802.11n
Fri Jul 23, 2010 7:55 pm
with n-draft m5
Its written there on the main page 2.3km.
charliebrown
Re: 802.11n
Sat Jul 24, 2010 12:57 pm
Its worth noting for people having bandwidth issue during testing that doing bandwidth tests from router to router caps out at around 30mbit for anything below RB433AH. During our testing we found that RB433 plain can only receive 30mbit, Changing to a 433AH resulted in more bandwidth but even than a RB433 will cap out at around 70mbit
Now for a question, Is there a reason for a single chain N link not to go into 40mhz? We've set HT extension channel but it wont go past 65mbit-HT and signal only shows a max of HT20-8 even tho the signal is -65
ste
Re: 802.11n
Sat Jul 24, 2010 1:57 pm
Low Signal or Channel on the Edge of the Band.
charliebrown
Re: 802.11n
Sat Jul 24, 2010 4:16 pm
Figured it out, the 5.0 beta doesnt like 40mhz. Downgrading to 4.10 and I'm pushing 70mbit TCP thru the link
RK
Long time Member
Long time Member
Re: 802.11n
Sun Jul 25, 2010 10:28 pm
Simplest way to do is to turn down the output power to minimum.
If that is not enough, point your antennas a little to the sky.
taduikis
Re: 802.11n
Sun Jul 25, 2010 10:44 pm
Maybe some hint what signal to look for? I mean in particular numbers.
charliebrown
Re: 802.11n
Thu Jul 29, 2010 12:11 am
If you use the R52Hnm card's with only 1 pigtail but a tech enables both chains are you likely to damage the card in anyway? Have had a tech telling me they enable both chains despite only having 1 chain antenna's
RK
Long time Member
Long time Member
Re: 802.11n
Thu Jul 29, 2010 10:19 am
-55 to -65 is good from my experience
Lakis
Forum Veteran
Forum Veteran
Re: 802.11n
Sun Aug 01, 2010 12:27 am
PC-Lan-433AH--------34km--------RB800
TCP Test is done from pc connected with 100mbit lan
2 Chains Nstreme
soon will change 433AH with RB800 also I'll fix Signal Strength (now -66/-67) I hope Ill Get 140Mbit Tcp
1. On RB800/RB433 side I have to enable TxPower TAB all rates fix (in this case is set 20Db) with out this link disconnect/reconnect (3-5min)
2. I have to set manual TX/RX Rates HT MCS MCS10-MCS15 with out setting link after 10-15min TX/RX rates goes down 39Mbit-Ht/52Mbit-HT
xezen
Long time Member
Long time Member
Re: 802.11n
Mon Aug 02, 2010 5:56 pm
please post script with full config
Lakis
Forum Veteran
Forum Veteran
Re: 802.11n
Tue Aug 03, 2010 1:16 pm
Just TX Power set on 20DB on both sides
HT Extension Chanel:above control and HT AMPDU Priorities 5,6,7.
+Nstreme
Everything else on default
xezen
Long time Member
Long time Member
Re: 802.11n
Wed Aug 04, 2010 9:16 pm
thanks
xezen
Long time Member
Long time Member
Re: 802.11n
Wed Aug 04, 2010 9:18 pm
so its just 1 chain or 2
Lakis
Forum Veteran
Forum Veteran
Re: 802.11n
Wed Aug 04, 2010 11:05 pm
2
xezen
Long time Member
Long time Member
Re: 802.11n
Sat Aug 07, 2010 8:20 am
what anttens dual pol or two single ones
Lakis
Forum Veteran
Forum Veteran
Re: 802.11n
Sat Aug 07, 2010 12:32 pm
Look at this xezen
http://forum.mikrotik.com/viewtopic.php ... is#p178990
This was my old link I made some modification just I update longest part od the Link 34km to 11N and with N it works more better and more stable (also without PC's I put RB's)
paperk
Re: 802.11n
Tue Aug 17, 2010 5:39 pm
I'm debating purchasing an R52Hn over an R52n to use inside an alix board. Which would be better to use for just a single AP inside a home? Are they both equally supported as far as open source drivers go (ath9k)?
I'm looking for the best performance (i.e. near 100mbit tcp bandwidth).
mcrose
Re: 802.11n
Tue Aug 17, 2010 6:33 pm
Is the configuration at http://wiki.mikrotik.com/wiki/802.11n_Setup_Guide still valid? The wiki article's ~10 months old at this point and there's been a lot of changes to wireless behavior in 4.x from looking at the changelogs.
Matess
Re: 802.11n
Wed Sep 01, 2010 4:18 pm
I´ve tested some links too and here are my results.
Exe´s config
1. link 600m, -49dB, 110cm offset antenas, dual polarity, 20MHz channel, very long signal cable, very bad enviroment (over 100 ap on scan list). R52n RB800-RB433AH
35Mb/s Full Duplex over iperf
802.11a has only 10Mb/s Full Duplex
great one
2. link 1,9km, -60dB, dual polarity jrc 24dB, 20Mhz channel, noisy enviroment (25-30 ap on scan list) R52n RB411AH-RB433AH
32Mb/s
very good too
but...
3. link to 6. link
1km, dual polarity jrc24 or jrc 29, 20MHz channel, normal enviroment (15-25 ap on scan list)R52n 433AH-433AH
2-8Mb/s Full duplex for no reason. Signal was ok, ccq no...
i´ve spent many hours changing antenas, cables and wireless cards but nothing helped.
So i bought sr71-15 replaced them and had 25Mb FullDuplex.
then i started testing r52n and found something very strange...
all r52n has good signal value on the link, but only a few of them were able to run at 30Mb/s Full Duplex. After 30 hours of outdoor testing i found that 48 r52n were damaged.. speed about 5Mb/s, 16 r52n were able run at 25-27Mb/s, and only last 36 from 100 were able run at 35Mb/s Full Duplex (tested on exe´s config on 1 chain, 40MHz channel)
the worst thing about this is that there isn´t other way to figure out which one is good a which one isnt. (or i didn´t found one yet)
So if you have problems with your link and you´ve tried everything, including replace wireless card, don´t be so sure that new ones are fine.
nvhs75
Re: 802.11n , 540 Mbits in the status page
Fri Sep 03, 2010 4:29 pm
Hi all,
We too are tinkering around with the N settings with and without N-streme.
Now we are testing a great x86 board with 5.0 beta 6 becauzse that supports our gbits ethernet ports.
What we are looking for is a steady 100 Mbits FDX.
We now have something strange but i am sure it is just a bug.
We have 2 r52Hn cards per board and dual n-streme setup.
We get a lovely 540 Mbits data rate each way:)
And as for TCP speeds we are hitting 120 Mbits in separate directions (send or receive) and only 85 in both. Whick is not much better than a 5 Ghz- A dual n-streme.
Our CPU is not the issue as it is enjoying itself at 55%
Any ideas or should we for now just go back to 1 radio card and try to get 80 Mbits FDX.
I have the printscreen below. it WAS fun to see the datarates:) even though it did nothing for the performance
hope to hear from you
Ec
samjan
Re: 802.11n
Sun Sep 05, 2010 12:24 pm
So now, i understand, why Mikrotik don't write normal drivers for SR71-15 :(
They don't need the clients, who loved to use Mikrotik hard&soft...
So we start t use Rockets, and each days we found that it works really
Erastus
Re: 802.11n
Sun Sep 05, 2010 12:25 pm
Yip unfortunately
awacenter
Re: 802.11n
Mon Sep 06, 2010 6:04 pm
Hi forum!
We have been performing some tests with 802.11n+R52n cards and although we got excelent results when short distances and good (very good) signals, as the link gets longer and poorer N behaves quite worse than simple A (at least on 5GHz).
This is the scenario:
17km link
BASE: RB433 (v4.10) + R52n + Ubiquiti Dual Polarization (http://www.ubnt.com/downloads/RocketDish_Datasheet.pdf)
STATION: Same equipment than BASE
These are the results:
Frequent disconnections even when not performing bandwidth tests
Decent signal but very poor bandwidth
No improvments as frecquency changes
No improvments either with different configurations (nstreme, wds, 5Gh-only-N, a,n, 5Ghz, etc)
No improvments when using different polarization combinations on HT Chains.
CPU goes to 100% on both BASE and STATION when performing TCP BandwidthTest (Not UDP)
These are the screenshots:
BASE-Wireless:
BASE-HT:
BASE-HT MCS:
BASE-WDS:
BASE-NSTREME:
BASE-Signal:
STATION-Signal:
BASE-BandwidthTest UDP:
BASE-BandwidthTest TCP:
Any suggestions will be welcome.
Thanks in advance.
Erastus
Re: 802.11n
Mon Sep 06, 2010 6:50 pm
Hi forum!
17km link
BASE-Wireless:
BASE-HT:
BASE-HT MCS:
BASE-WDS:
BASE-NSTREME:
BASE-Signal:
STATION-Signal:
Thanks in advance.
THe tx/Rx ccq is very bad.
THe signal strength will be better id it is neg 60 - 62 dB
Looks like the distance is to long for the equipment or the antennas could not be properly aligned.
I would first start by aliging the antennas what length.
Send me you google earth place mark then I calculate you the signal it must be and give you a graph of the path
awacenter
Re: 802.11n
Mon Sep 06, 2010 7:27 pm
Hey Newbie,
Thanks for your quick response. The antennas might not be well-aligned but still I think bandwidth is too poor for the signal got. Anyhow we'll be pleased you could send those info to us. Link placemarks below:
BASE-Lat: 39.519716°
BASE-Long: -0.466781°
STATION-Lat: 39.381389°
STATION-Long: -0.574501°
Best regards.
Erastus
Re: 802.11n
Mon Sep 06, 2010 7:43 pm
Hey Newbie,
Best regards.
-0.574501
This is your problem :
there is no clear line of site
please give me your email address I will send you infgo
awacenter
Re: 802.11n
Mon Sep 06, 2010 7:56 pm
Sorry I didn't mention we have 18 meters towers at both places. My email: ingenieria@grupoawa.es
Tons of thanks.
Hey Newbie,
Best regards.
-0.574501
pampi
Re: 802.11n
Mon Sep 06, 2010 9:37 pm
Hello
I got a problem with r52n cards, If I set the data rates to configure or default, the maximal HT rate which achieved is HT20-8, and its dont achieved any HT40 data rates..so the maximal TCP throughput is 44Mbit FDX. I try to upgarde from 4.10 to 4.11 but still nothing, try to reset the router but it didnt helped. I'm thing that I use the right configuration, couse same place exectly same hardware is working at the moment with more than 108 mbit tcp throughput.. FDX, I also try to change the cards with other r52n-s
Heres my config at point A
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
    antenna-gain=0 area="" arp=enabled band=5ghz-onlyn basic-rates-a/g="" \
    basic-rates-b="" comment="" compression=no country=no_country_set \
    default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=\
    0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=\
    no disconnect-timeout=3s frame-lifetime=0 frequency=4920 frequency-mode=\
    superchannel frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 \
    ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0 \
    ht-extension-channel=above-control ht-guard-interval=any ht-rxchains=0,1 \
    ht-supported-mcs=mcs-0,mcs-1,mcs-13,mcs-14,mcs-15 ht-txchains=0,1 \
    hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=15 l2mtu=2290 \
    max-station-count=2007 mode=ap-bridge mtu=1500 name=\
    wlan1 on-fail-retry-time=100ms periodic-calibration=default \
    periodic-calibration-interval=60 preamble-mode=both \
    proprietary-extensions=post-2.9.25 rate-set=\
    configured scan-list=default,4920 security-profile=default ssid=\
    test station-bridge-clone-mac=00:00:00:00:00:00 \
    supported-rates-a/g="" supported-rates-b="" tx-power=10 tx-power-mode=\
    all-rates-fixed update-stats-interval=disabled wds-cost-range=50-150 \
    wds-default-bridge=bridge1 wds-default-cost=100 wds-ignore-ssid=no \
    wds-mode=dynamic wmm-support=disabled
/interface wireless nstreme
set wlan1 comment="" disable-csma=no enable-nstreme=yes \
    enable-polling=yes framer-limit=3200 framer-policy=none
and the config at point B:
/interface wireless
    max-station-count=2007 mode=station-wds mtu=1500 name=\
    wlan2 on-fail-retry-time=100ms periodic-calibration=default \
    supported-rates-a/g="" supported-rates-b="" tx-power=15 tx-power-mode=\
set wlan2 comment="" disable-csma=yes enable-nstreme=yes \
    enable-polling=yes framer-limit=3000 framer-policy=dynamic-size
Signal level is: -60/-63
noise-floor: -122dBm
Anyone see the same problem? And got any solution for this? :)
taduikis
Re: 802.11n
Mon Sep 06, 2010 10:34 pm
I'm still waiting for things to sort out with 11n in Mikrotik. Currently I have more luck with turbo links.
popcorrin
Re: 802.11n
Wed Sep 08, 2010 6:24 pm
Anyone from mikrotik care to comment on this? Seems pretty serious!
normis
Re: 802.11n
Thu Sep 09, 2010 12:31 pm
how was that test done? speed is not an indication of card quality. it will depend on current conditions of the link, how many people use the link, if there is any traffic on it, etc. You would have to do the test in controlled environment with no interference and no connected devices to be even close to good testing conditions.
Erastus
Re: 802.11n
Thu Sep 09, 2010 12:52 pm
THis is the frustration part of Mikrotik . They have the same attitude as Micro Soft. Only they know.
Thereality is that if we install a different link on the same frequency using Motoral equipment we can get up to 200 Mb/sec
The reason why I bother to log these issues is to support MY not to critisize. I normaly did not log faults etc just used a different supplier.
Sorry for bothering you guus and go to this trouble of trying to get systems working I will revert to my previous method of working
THanks
normis
Re: 802.11n
Thu Sep 09, 2010 12:56 pm
Is it so hard to write some details about the issues instead of just complaining that some of your cards are 'bad'?
Erastus
Re: 802.11n
Thu Sep 09, 2010 1:35 pm
No not at all. The main problem for me is heat. an then dealing with Scoop. WHatr we have is it over heats and then it fails.
The speed getting 80 - 100 Mb/sec is super for me and the software is stable. The links are staying up for days and I am happy with the speed.
I truly want to help and contribute
I do understand that it is not a full duplex that is why we have a radio for rx and on for tx.
We have returned a 411 to poynting direct in Cpt where the heat unsoldered the connector. You can check it with them.
We could have resoldered the connector to the PC board.
We took the radio to scoop they tested it and no fault find. To scared to put it into the network again.
I can give you a login on to our router I can install more equipment that we can test and do what ever you guys need to do so it is not that I don't want to give more info ...
I can get stickers that change coulor with temp it is a good indication of where the temp stopped. THat can proof the temp prob.
My main prob is not getting the heat sorted and as a designer I understand that that is not easy as it comes and goes.
To me 70 M is super
Lakis
Forum Veteran
Forum Veteran
Re: 802.11n
Thu Sep 09, 2010 2:03 pm
To me 70 M is super
Play little with Tx Power put it 18,19 or 20 dBm see what's happen with this signal level of course if everything else is ok u can rich 120-140 TCP
Erastus
Re: 802.11n
Thu Sep 09, 2010 2:05 pm
To me 70 M is super
Play little with Tx Power put it 18,19 or 20 dBm see what's hapen
Will do
normis
Re: 802.11n
Thu Sep 09, 2010 2:06 pm
So you are running the BT test from the router itself?
:shock:
Lakis
Forum Veteran
Forum Veteran
Re: 802.11n
Thu Sep 09, 2010 2:09 pm
:shock:
Problem is his TX/RX rate is too low
normis
Re: 802.11n
Thu Sep 09, 2010 2:14 pm
no, it's completely normal. signal is good, this means card is fine. the environment should be at fault for not so good speed.
and playing with tx-power is not a good idea also
Lakis
Forum Veteran
Forum Veteran
Re: 802.11n
Thu Sep 09, 2010 2:16 pm
This is not btest this is actual internet traffic (not using Nv2 just nstreeme)
normis
Re: 802.11n
Thu Sep 09, 2010 2:17 pm
this is exactly the type of action that will cause the mentioned card problems. on lower rates this is fine, but on higher rates this power is too much and could damage the card.
only use "card rates" when changing power.
Erastus
Re: 802.11n
Thu Sep 09, 2010 2:19 pm
:shock:
Yes I do enough CPU power to do it
Lakis
Forum Veteran
Forum Veteran
Re: 802.11n
Thu Sep 09, 2010 2:20 pm
normis But if I put TX Power on default TX/RX rates drop to HT-20
normis
Re: 802.11n
Thu Sep 09, 2010 2:21 pm
get bigger antenna instead. or at least use card rates, not all rates fixed.
normis
Re: 802.11n
Thu Sep 09, 2010 2:35 pm
Erastus, please stop sending screenshots to support. Use the "Upload attachment" form below your post text.
Erastus
Re: 802.11n
Thu Sep 09, 2010 2:36 pm
I send you a google earth .
The link is 8.5 Km I have two 30dB dishes and running ht1 and ht2. THe distance is 9 km I also send you an screen with the freq ussage and the scan stats.
Matess
Re: 802.11n
Thu Sep 09, 2010 2:39 pm
i´ve tested od 400m link. Link si working fine for 3 months nonstop (my house) so i´m testing there.
Speed was tested by bandwidth test between rb433ah in tcp. I know that speed is not indication of card quality, but thats the only differance between them. CCQ is fine until full load si running.
Another part of this funny story are reclamations of these cards :)
normis
Re: 802.11n
Thu Sep 09, 2010 2:43 pm
why not post here?
Erastus
Re: 802.11n
Thu Sep 09, 2010 2:55 pm
why not post here?
THought it must go through you guys first as some other support channels
normis
Re: 802.11n
Thu Sep 09, 2010 3:05 pm
I see you use 4900-5200 frequencies. Most antennas have been made for 5800 or 5400, look at the antenna radiation patterns. You will also see that the wireless card is calibrated to run at it's full power at 5800.
If you can't change antenna, and you have no choice but to use such frequency, maybe you can upgrade to v5beta and try Nv2 which is what the mentioned motorola uses (TDMA)
Erastus
Re: 802.11n
Thu Sep 09, 2010 3:08 pm
Thanks I did not know the centre freq of the card is 5800 MANY THANKS!! THe dish is quit linear from 4900 but I will do that immediately !!!
bney
Re: 802.11n
Wed Sep 15, 2010 7:31 am
When I attempt to adjust down the power levels of the r52N cards, the interface stops registering clients and often requires a reboot of the router to get it back. This sounds like a bug to me. I need to bring down the power as the other radio units in the mesh are seeing signals in the 40's and 50's from each other. This is resulting in a ccq of less than 10%. not real impressive.
Since this is a mesh, the radio units are all running dual omni's and are about 1500 feet apart in wooded terrain.
Any suggestions on how to raise the ccq would be appreciated.
Erastus
Re: 802.11n
Wed Sep 15, 2010 9:40 am
We never experianced that are you using 2.4 or 5G ?
Howmany stations how far appart?
This is strange we can def lower the power with out any problems. But then why use an Hn and lower the power?
bney
Re: 802.11n
Wed Sep 15, 2010 6:30 pm
We are using 2.4 only. We are lowering the power because the levels are in hte -30 to -45 range. Absolutely too hot. Radios really like to see signals in the -60 range. The terrain is a highly wooded area so we used the higher capable radio cards.
There is one thing we are changing today however. When we set this up we used a single radio to carry the mesh and to connect the clients. We are replacing the MT nodes today with dual radio units so that the mesh can have its own channel and the customers can connect on their own AP. Maybe its just too many things talking in the same space.
frontiersteve
Re: 802.11n
Fri Sep 17, 2010 1:52 am
Has anyone had any experience using these enclosure/antennas:WX572003 from wispmax? Seems like another option for mimo client antenna.
bney
Re: 802.11n
Fri Sep 17, 2010 3:09 am
It looks like a reasonable enclosure except for the fact that it includes mmcx connectors rather than the u.fl type that the mikrotik R52 series cards come with. That would be a show stopper to me
pampi
Re: 802.11n
Fri Sep 24, 2010 10:59 pm
Hello
I got some time to, investigate the problem, so I climb up and see that one of the cables are full of water on the connector side. When I replace it, the signal didnt change but the ccq goes up to 99/99% and the bandwidth back to 160mbit/tcp/one way
Hello
/interface wireless
/interface wireless
devchaos
Re: 802.11n
Tue Oct 12, 2010 2:15 am
My results:
800m link
x86 775 Celeron 1600mhz
r52n
dual polarity 31dB parabolic
4m LMR-400 pigtails
mpls bridge
In future will try to upgrade 12km 802.11a nstreme turbo link )
mindaugasr
Re: 802.11n
Thu Oct 14, 2010 8:13 am
We have p2p link, rbb 433 ah + r52n on both sides. We use 4.6 firmware with exe config (nstreme + hw retries 15 + wds) it works prety good, stable CCQ average 97-99% connection speeds 270/270 mbps real speeds also pretty goods. We try to upgrade to 5.0rc1 and we got poorly results with nv2 CCQ not working, connetion rates striking from 160 mbps to 270 mbps very unstable, ping on idle link 3X !!!!!! higher 3-4 ms on idle link, on 4.6 firmware we have stable ~1ms link, speedtest also shows not stabdle results. Configuration i same only we changed in 5.0rc1 to use NV2.
I want ask somebody have success results from 5.0rc1? Or better today use 4.6? With 4.11 also we got bad results, ccq striking, connection rates droping and so on. I think 4.6 is best for 802.11n with mikrotik.
Thanks for reply
cieplik206
Trainer
Trainer
Re: 802.11n
Thu Oct 14, 2010 9:24 am
Throughput and CCQ in separate issue than PING.
All of you be aware that frames in NV2 are time-based (2ms default) so if you send a echo request reply could be replied in next frame (2-4) ms + additional delay from buffers, link etc. so 3-4 ms Delay using NV2 with default settings is good result.
mindaugasr
Re: 802.11n
Thu Oct 14, 2010 10:36 am
Thanks for suggestion. Can you tell on 500 meter link i should use tdma-period-size: 1? or lower? To archyve best ping latency? Maybe someone have config with best latency and throuput on very short link with 5.0rc1 and nv2? Maybe some recommendation on short links?
TomjNorthIdaho
802.11n --- WDS bridge --- Is the setup the same?
Fri Oct 15, 2010 2:22 am
I have done many WDS bridges (802.11a) which bridge an 802.1q tagged network. The 802.11a mikrotik config did not know anything about 802.1q. It just passwd the vlans and mac address back and fourth with no problem.
I am trying to setup my first mikrotik 802.n-only wds link. I am pretty sure i have the same configuration procedures as when I set up my 802.11a wds bridges. My problem is than when I activate the 802.11n wds link the remote network takes a dump and stops talking.
(Point A) cisco switch#1 --802.1q--> Trango bridge -->------------microwave link------------> Trango bridge --802.1q--> Cisco switch#2 (Point B)
(Point A) cisco switch#1 --802.1q--> Mikrotik N wds bridge -->-----microwave link-----> Mikrotik N wds bridge --802.1q--> Cisco switch#2 (Point B)
This did work well when my Mikrotik wds bridge was an 802.a configuration
Notes: I have verified MAC address and interfaces and bridge settings
Notes: My cisco spanning tree on my switches is normally configured to prefer the Mikrotik link.
Is WDS using a 802.11n configured exactly the same or is it different from 802.11a ?
Does WDS using 802.11n pass the 802.1q traffic or do I need to modify a packet size ?
This was working prior to replacing both mikrotiks with 802.11n cards
help
Tom Jones - A WISP up here in North Idaho
tritsako
Re: 802.11n
Mon Oct 25, 2010 6:15 am
Hi to all,
as I am new in 802.11n, I am trying to setup R52n to work with on sinlge poular feeder. Is this possible and how?
Thank you in advance.
Costas.
DJHiP
Re: 802.11n
Wed Dec 08, 2010 12:42 am
Long time reader, first time poster. You know how it goes :)
Been playing with 802.11n for the past year or so, but I thought i'd drop some info on the latest test link I setup.
Using RB711A's with 26dB Grid Antennas.
We're yet to fully align as our weather has been horrible, but the single stream 802.11n is amazing!
Routerboard 711A's on both ends
RouterOS 5.0rc5
3KM link (Yeah a short one, I know)
10MB/s throughput TCP.
NV2 enabled.
So far, very happy. I've previously tested R52Hn's with 60cm Solid Dual Polarity dishes and not gotten anywhere near these results (however, also not had ROS5.0 and NV2 to help.)
Only thing to note is, you can't do an onboard BTest (TCP) as the 711's run out of CPU before they run out of bandwidth space :) so the data was FTP traffic from PC to PC and HTTP download from PC to PC, both produced ~100mbit throghput!
So, very happy so far :)
normis
Re: 802.11n
Wed Dec 08, 2010 11:46 am
you can also try the Btest tool from PC to PC, more control over the kind of traffic you test:
http://www.mikrotik.com/download/btest.exe
DJHiP
Re: 802.11n
Wed Dec 08, 2010 12:03 pm
Yeah, it needs an update though so you can specify multiple streams instead of just running 10 instances :)
We also aligned today and now top 11.7MB/s :)
Need Gigabit 711A's 8)
taduikis
Re: 802.11n
Wed Dec 08, 2010 3:26 pm
Well since 711 uses only single chain, I wouldn't expect more bandwidth than Ethernet can handle. Still, it's very good achievement with RB711 using 11n. Currently we are investigating possibility to upgrade our networks to 11n. Since most of CPEs are now RB711, and those that aren't can easily be upgraded simply by swapping 11n card in them. Only concern is the performance of 11n in P2MP mode. We are choking at current 11a speeds and todays bandwidth demands :(
Trisc
Re: 802.11n
Sat Dec 11, 2010 7:19 pm
For months I have tried to get laptops with wireless N cards to associate to Mikrotik router using 802.11n - but it seems only possible to connect using b/g.
I have tried endless configurations without success. Is Mikrotik 802.11n only designed to connect to other MTs? I can see no other threads other than people discussing point to point links.
What if we want to use MT exclusively for campus and building APs? Fine if we stick with b/g but otherwise we will have to go with UBNT or Ruckus kit for wireless N clients.
Has anyone managed to solve this? Please post configs!
KillerOPS
Re: 802.11n
Sat Dec 11, 2010 8:53 pm
just make sure you didn't enable nv2 or nstreme.
DJHiP
Re: 802.11n
Sun Dec 12, 2010 12:19 am
Have you enabled the extension channel?
I would also be setting manual rates and disabling all the B and G channels so only the HT-MCS rates are allowable to run, then see if they can connect.
I've not played with any 2.4ghz N gear as its just too noisy where I live.
Trisc
Re: 802.11n
Mon Dec 13, 2010 11:41 am
No I didn't enable NV2 - it wasn't available until recently anyway and certainly not using Nstreme.
I have tried every combination of extension channels, HT-MCS settings but I cannot get PC or Mac wireless clients to connect on N only.
If this won't work we will abandon MT for future hotspot deployments.
ste
Re: 802.11n
Mon Dec 13, 2010 11:45 am
I've a centrino lap. It scales up to 11n rates for downloads but stays at 11a Rates (54Max) up.
Seems there are some incompatibilities.
TKITFrank
Re: 802.11n
Mon Dec 13, 2010 12:08 pm
If I'm not mistaken on some centrino laptops that is the max TX rate. They only use N for RX. Why i don't know... :(
Trisc
Re: 802.11n
Mon Dec 13, 2010 2:29 pm
And how long has N been available on Mikrotik? Seems like other manufacturers can get it right. Why not MT?
gvanwie
Re: 802.11n
Tue Dec 14, 2010 6:21 am
We are working on a Point to Multipoint project with R52nh cards and have been having trouble getting 802.11n to work. 802.11a works great, even with 5Mhz channels. Would would like to try N to see if there is an improvement in range and/or speed, but have had trouble configuring (we have used 4.13, 4.11 and 4.9, with the same result)
We have also had issues getting nstreme or NV2 (on 4.13) working on either 802.11a or n. Any pointers we can use to help us out?
nest
Forum Veteran
Forum Veteran
Re: 802.11n
Mon Dec 20, 2010 4:14 pm
Trisc - I'm not far from you at the moment - if you wish to, could you contact me direct? See below. Might be able to help?
Matess
Re: 802.11n
Fri Feb 18, 2011 6:01 pm
I used RouterBoard 433ah r52n 2 wireless cards for this test.One wireless card I made as AP and and the second one as a client(without minipigtails and antennas) and the signal strengh was -56 db. I wrapped the wifi card with a layer of antistatic film, another layer of aluminum foil and the last layer of an antistatic film again. Then I checked the signal and I got to -72 db
This really helped.
I´ve also tested this on cards i use on normal links (wnc cm9) and nothing happened. Signal was always the same - around -71dB
frontiersteve
Re: 802.11n
Sat Feb 19, 2011 5:56 pm
I've considered doing this as well. Could you post photos of the setup.
chadd
Re: 802.11n
Sat Feb 19, 2011 7:36 pm
This really helped.
It seems like you could have some heat related issues with the cards wrapped up like that. Is this something you have ran in production?
Matess
Re: 802.11n
Sat Feb 19, 2011 11:23 pm
dont know exactly how long i am using it, but at "Thu Sep 09, 2010 2:39 pm" i´ve written a post here with a few problems in 802.11n, so it has to be only few days after that. So lets wait for Summer :)
I do not have much of these cards.... maybe 20, but so far they are working just fine....
I just taked a photo of that.... sorry for the poor quality... cellphone photo...
http://img573.imageshack.us/img573/3596/19022011097.jpg
t3rm
Re: 802.11n
Mon Feb 21, 2011 4:58 am
Capture of RB SXT-5D in action.
224Mbps reached, but too bad this is in UDP test :p
TCP, still testing, which one gone bad, my laptop ethernet or SXT ethernet.
Cause i only able to transfer 60Mbps full duplex
Beccara
Long time Member
Long time Member
Re: 802.11n
Mon Feb 21, 2011 5:33 am
And just how long was that linke? -55 signal so what, 100m max?
ekkas
Long time Member
Long time Member
Re: 802.11n
Mon Feb 21, 2011 11:45 am
t3rm,
any possibility of posting your configs here?
I have a R52n link setup here:
http://forum.mikrotik.com/viewtopic.php ... 85#p250885
But struggle to get to these speeds.
Hammy
Forum Veteran
Forum Veteran
Re: 802.11n
Tue Feb 22, 2011 3:52 am
I have a 25 mile link that's supposed to be -55. ;-)
ottoshr
Re: 802.11n
Mon Feb 28, 2011 9:32 pm
please post config SXT 5Hnd ! Cant get them worked more than 135Mbps ... connected !
upgraded to 5.0rc10 but no result !
I wonder how to get 270Mbps and at least aprox 100Mbps duplex at least on the table.
one side
[admin@MikroTik] > interface wireless print
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:84:66:1B arp=enabled
interface-type=Atheros 11N mode=station-bridge ssid="MikroTik"
frequency=5240 band=5ghz-a/n channel-width=20mhz scan-list=default
wireless-protocol=nv2 wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
hide-ssid=no security-profile=default compression=no
other side
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:84:46:99 arp=enabled
interface-type=Atheros 11N mode=bridge ssid="MikroTik" frequency=5240
band=5ghz-a/n channel-width=20mhz scan-list=default wireless-protocol=nv2
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
m4rk0
Re: 802.11n
Mon Mar 07, 2011 12:33 pm
I have this configuration:
2x RB411 + R52n-M
1x RB433 + 2x R52n-M
4x GRID 5GHz 27dB
RB411 client ->((( ~14km )))->[5640MHz] AP RB433 [5540MHz]<-((( ~15km )))<- RB411 client
Mode is 5GHz-only-N (MCS 0 - 6)
Signal ~ -70
When I try TX bw test from ap to both of clients it works fine, but when I try RX to clients it goes up to 1 Mbps and link drops...
Does anyone have any idea what could it be?
uldis
Re: 802.11n
Mon Mar 07, 2011 2:13 pm
ottoshr, in order to get to 270mbps data-rate you need to use both chains on the SXT device (check if you have enabled them for TX and RX), and you need to enable the ht-extension-channel support.
normis
Re: 802.11n
Tue Mar 08, 2011 9:26 am
m4rk0, what software did you use to make those link drawings?
m4rk0
Re: 802.11n
Tue Mar 08, 2011 11:36 am
Hello, we use this website for profiling http://www.alphimax.com/
Do You have any idea about my problem?
marsantennas
Re: 802.11n
Thu Mar 10, 2011 2:38 pm
Hello @ all.
We are a small wisp in Germany. Im reading for a long time here in the forum. We have problems with N, too. The same Problem as chvdr.
Our Equipment at both Sites:
RB433AH + R52N + 2*30dBi Mars Antennas Flat Pannel (No DUAL!!) but in Dual-Polarisation (1 * hor + 1 * ver).
The 2 Antennas (H + V on both Sites) are mounted in a distance of 1 meter. The Distance of the 2 Points (AP and Client) are 11 Km.
The Line is TOP.
Thanks for help.....
joban
well you have the dual 29dbi for some time now
anyway what's of interest for me is a case study for use of MARS antennas with MK boards
what's the distance/ throughput that you where able to get
Matess
Re: 802.11n
Fri Mar 25, 2011 3:20 pm
Hi again,
I have 2 SXTs on 240m, no obstacels.
tx power set to all rates fixed - 0
frequency 5765
ht channel below control on both sides
route attenuation - 95dB
antena gain 16dBi
wifi card power 0dBm
so 0+16-95+16 gives mi signal strengh about -63dBm
so why i have these?
Ch0 -78/-87dBm
Ch1 -87/-87dBm
If i set tx-power to all rates fixed = 10
10+16-95+16 gives mi signal strengh about -53dBm
then i have
Ch0 -64/-66dBm
Ch1 -66/-67dBm
so 10dB on a power gives me this differences:
Ch0 14/21
Ch1 21/20
how is this possible?
ROS 5.0rc11
What is difference between SXT 5HnD and SXT-5D?
normis
Re: 802.11n
Fri Mar 25, 2011 3:22 pm
no difference, internal numbering was upgraded.
Matess
Re: 802.11n
Fri Mar 25, 2011 4:46 pm
and can you tell me why 10 more dB in wireless card gives me 20 more on signal?
If you want i can give you access to them.
normis
Re: 802.11n
Mon Mar 28, 2011 12:55 pm
signal level in RouterOS is not a very exact number. if you increase power by one unit, it will not increase signal by one unit. It doesn't work that way.
ekkas
Long time Member
Long time Member
Re: 802.11n
Mon Mar 28, 2011 11:27 pm
Hi Normis,
relating to questions/issues mentioned in this thread and others regarding N...
Are you guys aware of issues and working on it, or do you believe MT N support (+for legacy devices) is working 100%
Just like to know if we can expect changes/improvements or is this as good as it gets?
Ekkas
Matess
Re: 802.11n
Tue Mar 29, 2011 2:07 pm
i just dont get it. It seems that sxts has a really bad wireless cards.
I´ve measured EIRP and got this:
EIRP power measurment
RouterBoard SXT
Measurment on 2m with 17dBi antenna
1dB power loss on connector between antenna and sond
Sond: R&S measuring up to 6GHz
Power loss on 2m: 54dB
note: Prijmaci signal = Signal level on sond.
That means, that sxt´s output power is ok, but recieved signals are really weird
normis
Re: 802.11n
Tue Mar 29, 2011 2:10 pm
how did you measure this?
what is "Signal level on sond."?
uldis
Re: 802.11n
Tue Mar 29, 2011 2:35 pm
please provide more detailed description how did you measure it and make some pictures from the setup and the configuration.
Matess
Re: 802.11n
Tue Mar 29, 2011 11:15 pm
used RB SXT with ROS 5.0 rc11 - level 4, ap bridge, tx power - all rates fixed from -30 to 30
2 meters between the SXT and the antenna with known gain (54dB - environment attenuation)
antenna gain 17dB, 1dB power loss on connector between antenna and probe
probe: http://www2.rohde-schwarz.com/en/produc ... RPZ92.html
EIRP = antenna gain - cable loss + wireless card power
EIRP - environment attenuation + antenna gain (on sond) - cable loss = received signal
EIRP = cable loss + environment attenuation + received signal - antenna gain on sond
EU limit for EIRP is 30dBm, or 27dBm without DFS
for example - tx power +10
EIRP= 1dB + 54dB + (-8dB) - 17dB = 30dBm
So in other words...
if I set tx power to 10, i have 30dBm EIRP
environment attenuation = 32.4 + 20 x log frequency (MHz) + 20 x log range (km)
environment attenuation = 32.4 + 20 x log 5800 + 20 x log 0,23 = 32,4 + 75,27 -12,76
environment attenuation = 95dB
so it should be something like this
30dBm - 95dB + 16dB (other SXT antenna gain) = -49 dBm
but thats the problem....
ch0 60/62
ch1 58/60
~10dB is missing
If i set tx-power to 0
EIRP = 20dBm
20-95+16=59dBm
conlusion?
uldis
Re: 802.11n
Wed Mar 30, 2011 9:44 am
please note that for the receive signal values the noise floor levels also are taken into the account. And that is why maybe the rx signal is not so high.
Beccara
Long time Member
Long time Member
Re: 802.11n
Wed Mar 30, 2011 10:25 am
Noise floors that change wildly between ROS point releases and even packages!
Is there a reason RX signal is adjusted by NF?
normis
Re: 802.11n
Wed Mar 30, 2011 1:42 pm
Matess you have made many mistakes in your tests:
1. signal level in RouterOS is not precise, and can't be used for exact measurements, it's meant as a guide only, to compare better and worse situations, when aligning antenna
2. you said you used a "17 dbi known antenna" without specifying the manufacturer, and whether it's a certified antenna to be used for testing. many regular and cheap brand manufacturers specify incorrect gain and other parameters, this is not to be trusted unless it's a certified antenna made specifically for testing.
3. to be able to get any kind of accurate reading, the SXT should be fully transmitting 100% of the time at maximum possible duty cycle. otherwise, measurement is inaccurate
Matess
Re: 802.11n
Wed Mar 30, 2011 4:40 pm
It was measured in the college laboratory - University of Technology Brno Czech Rep.
They have much more better equipment, then i have.
And as you see... tx power regulation is good. But thats all....
Yes, it would explain why after changing wifi cards for cards from Mikrotik signal deteriorates.
There are a few good cards for miniPCI express.
Are you planning some kind of a powerful little router with a miniPCI Express interface? RB800 is not very cheap. Something like 411AH should do the job.
Cira
Re: 802.11n
Sun May 22, 2011 10:48 pm
Hello guys,
I have questions on what kind of antennas are you all using for your tests and what can I expect when matching 802.11n with various antenna options?
(hardware being 433AH and R52n radio card, 5Ghz band)
1) sector antenna single polarization
2) sector antenna dual polarization (tx/rx vs tx,rx / tx,rx chains)
3) MIMO antenna (single or dual polarization)
Matess
Re: 802.11n
Mon May 23, 2011 10:43 am
I am using dual polarization jirous parabolic antenas
http://en.jirous.com/antenna-5ghz/jrc-24-duplex up to 2km
http://en.jirous.com/antenna-5ghz/jrc-29-duplex up to 4km
longer distances, or huge interference on offset antenas (110cm) with nn-12 duplex
http://antenna.cz/nn-12_DUPLEX/nn-12_DUPLEX.pdf (sorry only in czech)
offset antenas costs half price then jirous 29, but it is really hard to install them (antenna focusing)
i´ve tried to use ubnt dual polarization dish.... waste of time.
petro25
Re: 802.11n
Tue May 31, 2011 8:36 am
2x RB411 + R52n-M
4x GRID 5GHz 27dB
Signal ~ -70
You share the program in which considered profiles
cdga12
Re: 802.11n
Sat Dec 10, 2011 7:42 pm
Thanks all for answer.
I think maybe using one chain can get little more bandwidth compare to 5Ghz turbo nstreme. Add one more antenna is little complicated need more space, stronger tower more cables is not option for now on that place. Also dual polarity antenna is usually solid parabolic antenna need stronger tower sometime time wind is very strong.
May be tested on some other place.
One more thanks to all.
My name is carlos, i implemented a 80211n + MIMO 2x2 Wireless Network with diversity only, I used: RB 433AH, R52Hn, Routeos license 4.x, 60 mts. tower, in the Amazonic Jungle in Peru.
The results are 60 a 64 Mbps (data throughput)
A MIMO System, with STBC, Beamforming and Spatial Multiplexing are a very important solution for improve my network.
I am continue my research (PHD) about MIMO System.
I attach documents on round,
Users browsing this forum: No registered users and 75 guests
