brando9d7d
Re: 802.11n
Wed Feb 03, 2010 8:03 am
I have a MikroTik 411AH w/ a Ubiquiti SR71-A card doing 802.11n on a 60 degree sector antenna on a 7 mile shot and I have noticed a few things:
When using single polarization with older backhauls and AP's there was a inconsistent issue with latencies due to the fact that 802.11 is contention based. I would see latencies of 1mn to 16ms. With the 802.11n stuff I am seeing a consistent 2 ms latency, however speeds do fluctuate.
Do these speeds fluctuate because 802.11n is contention based meaning that if the horizontal channel is busy then it checks the vertical channel (and vice versa) and since odds are at least one of the channels is free the pings get through at a consistent latency? Do the speeds fluctuate, which I see between 70 and 100 mbps symnetrical, because of small interference on one of the polarizations?
My theory is yes to both of those questions, but I am curious to others' ideas and thoughts.
pampi
Re: 802.11n
Thu Feb 04, 2010 9:03 pm
Hello
Here is a 4,7km test link in a noisy enviroment (2 more rocketm on the same direction, 8 simple 802.11a link nearly on the same direction) with an 55cm parabolic dish, on a 4.5 MT x86 system with an 1.6Ghz Celeron D processor.
Interesting on the signal strenght, but its working
xezen
Long time Member
Long time Member
Re: 802.11n
Sat Feb 06, 2010 7:23 am
what radios you using?
and whta antennas you got set up? with this config
can you post your configeration here for up please
pampi
Re: 802.11n
Sat Feb 06, 2010 11:32 am
Hello, the radios are r52n
The antennas are a hand made 55cm parabolic dish with radom, see below in the picture.
Heres the configuration:
int wi pri advanced
 0    name="wlan1" mtu=1500 mac-address=00:0C:42:61:71:1D arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name="000C4261711D"
      mode=ap-bridge ssid="ntest-km" area="" frequency-mode=superchannel country=no_country_set antenna-gain=0 frequency=5180 band=5ghz-onlyn
      scan-list=default rate-set=configured supported-rates-b="" supported-rates-a/g="" basic-rates-b="" basic-rates-a/g="" max-station-count=2007
      ack-timeout=dynamic tx-power=17 tx-power-mode=all-rates-fixed periodic-calibration=disabled periodic-calibration-interval=60 dfs-mode=none
      wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
      default-authentication=no default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25
      wmm-support=disabled hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=short compression=no
      allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-guard-interval=long
      ht-extension-channel=above-control ht-supported-mcs=mcs-0,mcs-7,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-basic-mcs=mcs-0 ht-txchains=0,1
      ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 hw-retries=15 frame-lifetime=0 adaptive-noise-immunity=none
      hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0
int wi nstreme pri
 0 name="wlan1" enable-nstreme=yes enable-polling=yes disable-csma=no framer-policy=best-fit framer-limit=3998
int wi manual-tx-power-table pri
 0 name="wlan1" manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0
same on the other side, just mode=station
xezen
Long time Member
Long time Member
Re: 802.11n
Mon Feb 08, 2010 6:27 am
thanks for this inforamtion hekps alot
merlinthemagic
Re: 802.11n
Tue Feb 09, 2010 1:51 am
Hey,
We are using the r52n for a bunch of links, and have 2 issues.
1) Have links that will move 60-90Mbit/s in one direction but NEVER more than 31Mbit/s the other way, regardless of what side is AP and Station. Multiple frequencies provide the same result, the link is locked at -55 to -62 and 260Mbit/s / 260Mbit/s. Tried new RB 600 and new R52N same result.
2) The N radios seem to "gather" errors or something. If the radio is running max throughput for a period of time it will all the sudden stop and only move a few kbps for 10-15 minutes or until disabled and re-enabled, then back to normal operation. During the problem periods the rate, ccq and signal looks perfectly normal.
Have tried 4.2 and 4.5.
Martin Madsen
Bel Air Internet
vladimirslk
Re: 802.11n
Wed Feb 10, 2010 2:08 am
Hello to all!
At the moment we are using 5ghz-turbo, and getting ca 55-60mbps speed on 433ah..
I have read about support of 802.11n, and could not get, is it ready to USE or not.
Really freaky shots with pings.. abnormal for ISP =)
but we soon need a real PTP link with 100mbps or better more, planning to pull throught IPTV content for users, at the start on unicast.. multicast isnt possible if i am right =)
SO: Q:
How it s now with pings? nstream support came to new version?
On antennas I would to offer to use Svenska antennispetsialisten, we have one link on them, very very good ones. 60cm dishes :)
Best regards,
Vladimir Saluk
junkie
Re: 802.11n
Thu Feb 11, 2010 12:07 am
I'm trying 802.11n on rb800 with r52n radio card, and ROS 4.5 . The results are excellent.
The same configuration on alix 2d2 (WDS bridge or MPLS + VPLS , as described on the wiki) does not work at all.
The machines are connected, but no data output when I do the BT and sometimes they suddenly reboot. Someone has already solved this situation?
My config ( in WDS mode ) is :
-bridge interface with ether1 and wlan1
-wireless mode : station-wds (or bridge)
-band : 5GHz only n
-freq. : 5500
-HT chains : Tx 0 1 / Rx 0 1
-HT AMPDU : 0 1 2 3 4 5 6 7
-wds mode : dynamic
-wds def. bridge : bridge_name
-nstreme : enabled (on bridge machine frame policy : "best fit")
On rb800 it work fine but if i try with alix ... nothing .
dingsingo
Re: 802.11n
Fri Feb 12, 2010 12:32 pm
I've a Link over 8km.
A-Side: Rb/411AH (Ros 4.5) R52Hn 2meter Coaxcable 1x 23dB vertical 1x 23dB horizontal
B-Side: RB/600 (Ros 4.5) R52Hn 2meter Cable 1x 23dB vertical 1x 23dB horizontal
Link goes with 43dB Signal and by HT20-8
B-Test ( udp 1500) say max. 30Mbit half and 8Mbit by duplex.
Thx
dingsingo
pikpik
Re: 802.11n
Fri Feb 12, 2010 1:00 pm
wds is working fine on N ?
mishaM
Re: 802.11n
Fri Feb 12, 2010 3:22 pm
no that not suported ,
i hawe link ower ~2km
routerboards is rb433 (300mhz) and r52n cards , use 17 dbi patch antenas 1X
signal -70... -68 and signal to noise ~40db , i use vpls
tcp traffic over 30-40mb half duplex .
pikpik
Re: 802.11n
Fri Feb 12, 2010 3:53 pm
with nstreme ?
dingsingo
Re: 802.11n
Fri Feb 12, 2010 3:59 pm
5Ghz or 2,4Ghz ???
mishaM
Re: 802.11n
Fri Feb 12, 2010 4:08 pm
with nstreme ?
no , config is (AP-->station)
5Ghz or 2,4Ghz ???
5ghz
pikpik
Re: 802.11n
Fri Feb 12, 2010 4:37 pm
can you test it with nstreame ?
mishaM
Re: 802.11n
Fri Feb 12, 2010 5:17 pm
nstreame wich 1x antena is a senselessness , in my opinion nstreame justified when use 2X antena in order duplex speed success .
jcremin
Re: 802.11n
Fri Feb 12, 2010 5:28 pm
While I haven't used 802.11n, my other links have had huge performance gains with nstreme and 1 antenna.
pampi
Re: 802.11n
Fri Feb 12, 2010 11:40 pm
Could you please share us the result of a tcp test with rb800 on 802.11n?
I'm interested in the numbers, is it enough good as a PC
-band : 5GHz only n
-freq. : 5500
-wds mode : dynamic
congo
Re: 802.11n
Sun Feb 14, 2010 1:48 pm
We have seen something similar with R52n. In our case the TX rate falls to 1Mbps-SP and CCQ to ~20%. Signals are very good. I have been searching for these symptoms in the forum. I can't believe that only I have problems with these cards. I think there is something wrong with them.
popcorrin
Re: 802.11n
Mon Feb 15, 2010 10:54 pm
I think you are confused about what nstreme does. You might want to read up on it or test it out on 1x antenna to see how it works.
dingsingo
Re: 802.11n
Wed Feb 17, 2010 5:53 pm
hi,
how set the N-Testlink to max. 36mbps-HT or 56,5Mbps-HT on the connection ??
Thx
dingsingo
2jarek
Re: 802.11n
Wed Feb 17, 2010 9:09 pm
9 months and still no progress 802.11n does not work correctly with production traffic. Ping is a high latency is not acceptable for 30-50ms for 40/10mbit traffic. Nstreme still does not work correctly with production traffic, falls CCQ miserably when Nstreme is enabled.
rpingar
Long time Member
Long time Member
Re: 802.11n
Wed Feb 17, 2010 10:57 pm
same expreinece, hope the will release the N*Nstreme as soon as possible,
regards
Ros
pampi
Re: 802.11n
Thu Feb 18, 2010 3:03 pm
Okay, I'm gona answer to my question.
The rb800 is capable to do the same throughput as my Celeron D 1600 Mhz, till 150Mbit which was the maximum, that I can rich in both direction.
-band : 5GHz only n
-freq. : 5500
-wds mode : dynamic
pampi
Re: 802.11n
Thu Feb 18, 2010 3:10 pm
I put the test config back, couse I see your post, that for a period of time, it stops.
Now its running 1day 15 hour, one bandwidth test with maximal throughput till now, at the moment I change the direction. No disconnections, no speed dropdowns, I monitored the interface with snmp. I see the interface statistic and there are no errors, but lots of data transmited :)
2jarek
Re: 802.11n
Thu Feb 18, 2010 3:31 pm
@pampi
Do the test in both direction UDP frame size set 200b & measure the ping latency.
Or just run this link productively.
I have a link to the production set static 216/216 Mbps CCQ always 99/99%, TX / RX Signal 50dB, 100Mbit possible with UDP packets 1500b ethernet is limit.
But the ping latency in the 30/10 traffic Mbitsis not acceptable 20-50ms (802.11a Turbo Link is 5-10 ms MAX!!!!!) jitter is weak, Nstreme not work.
pampi
Re: 802.11n
Thu Feb 18, 2010 5:48 pm
Problem same on here, 40% packet lost pings are worst then 40ms. CCQ down at 20% from 99%
Tomorrow I will put this link to production, I will report back what I see.
@pampi
ovkiller
Re: 802.11n
Fri Feb 19, 2010 11:18 pm
Here are my tests on a backbone link:
2x RB433AH + R52n cards and 60cm dish antennas wit dual polarity horns.
5km distance
band 5ghz
signals are not very good:
Tx/Rx: 71/68
CCQ: varies between 20% and 80%
yesterday in the evening i reached tx/rx rate: 162Mbps-HT (real throughput: 80Mbits HDuplex ) and i thought i nailed it.
in the morning the result was 12/24mbits rates and CCQ around 15%. Same signals...
Sounds like noise to me...but when i go to pure 5ghz i got 100% CCQ and 54/54 rates. Really strange. Nstreme is off. If anyone can help me with a tip i will be really greatfull.
acim
Re: 802.11n
Sat Feb 20, 2010 12:06 am
We are starting 802.11n tests again, but this time with RB800 and Mini PCI-E SparkLAN WPEA-110N inside WaveArena alloy box.
However, I am wondering, shell I separate pigtails somehow because of the interference between them?
This box is looking very good, but there is not enough space to insert miniPCI cards to the upper row. However, there is not enough holes for pigtails, so it seems to be enough to have one Mini PCI-E and two miniPCI cards.
lekozs
Re: 802.11n
Sat Feb 20, 2010 4:44 pm
The same experience here!
Here's what I did:
The testbed:
5Ghz, N-Only mode, ROS version 4.5
Laptop-----RB800 + R52N + DualPol Ant <-----20meters (a few walls in between)-----> DualPol Ant + R52N + RB800-----Laptop
Everything seemed fine. I was getting stable 270/270Mbps Tx/Rx rate and a 95/95% CCQ. The bandwidth test in the RouterOS run fine, and gave me mind-blowing results:
- one way TCP :120-140Mbps
- both ways TCP: ~ 82/87 Mbps
I left this - one way - test running for 3 days!! Not a single glitch, no disconnection, perfect! Just like pampi, I was very happy!
BUT!
The tests between the two laptops (with gigabit eth ports) weren't so great at all... The one way test (copying file from one laptop to another) gave me some 25-30Mbps max.
Then I took the whole setup outside and put it to the test under real-world circumstances :
Very noisy environment @ 5.4GHz!
Corporate Net---RB800 + R52N + DualPol Ant <-----1300m-----> DualPol Ant + R52N + RB800---Corporate Net
And then, the problems began to emerge...
First of all, I've got a very good signal strength -48~51 / -48~50 dBm ... but just like merlinthemagic and congo said... everything was fine for some time, and then, under 50-60 Mbps of traffic and 10-11kpps, suddenly, everything seemed to collapse! The RX-rate fell from 216-270Mbps to 6-12Mbps, and the CCQ did the same... from 90% ---> down to 5-7%. If I left it this way... sometimes it recovered itself after an hour, or so... but if I wanted a quick recovery, I had to reboot one of the RouterBoards...
The ping was somewhere between 4-6ms with 5GHz-Turbo mode (Compex AG card), but with this 5GHz-N-only link it looked like it was multiplied by a factor of 8... somewhere around 30-40ms
... had to put back the old miniPCI cards and the 5GHz-Turbo mode to regain the stability we were accustomed to...
Conclusion: a lot of work (coding) is required by MikroTik to make these N-links stable and ready for the "Real World" circumstances
I wish they (MikroTik engineers) could be here to see with their own eyes the behavior of these N-links... or would it be helpful if I send a supout.rif file to them for analysis ...?
Regards
pampi
Re: 802.11n
Sat Feb 20, 2010 6:06 pm
At the moment, same on my production test at friday.
Here's what I did:
The testbed:
BUT!
Regards
ovkiller
Re: 802.11n
Sat Feb 20, 2010 10:17 pm
Same with me...20-30-40ms ping on a 5km link. The links works good and suddenly collapses totally to 12-24mbits rates.
After some time it regains previous state. i was really disappointed with the results...
Tomorrow i will place the antennas higher and test for a last time. Hope for some improvement.
my setup is:
2xRB433AH + 2xR52N Cards + 2x 60cm dish antennas
5km distance.
should be a real good link....but still...it is NOT! :S
Maybe in next Router OS version it will be much more stable!
professor
Re: 802.11n
Sun Feb 21, 2010 8:10 am
After months of playing with N this is what works for me. Removed all a and b data rates and just use one ht-mcs rate that your link preferes. I have 18km link running single chain using only mcs=4 basic and supported. On btest i get 64Mb throughput and production data 58Mb one way. Also have 2km link set on mcs6 supported and basic and on btest get 100Mb and real data 94Mb. Also have a 40Km link set msc4 single chain doing 50Mb real data and lastly an 8km link running dual pol dishes msc10 doing 120Mb real data. The key was with the hw retries and data rates. Also all the link from 10Km up is running nstreme as it doesn't like to work on the short links.
All in all am extremely happy with me links. They all performing very well.
ovkiller
Re: 802.11n
Mon Feb 22, 2010 5:00 pm
And what antennas do you use on 8km link?
I use 60cm dishes but seems to be too small for that distance (5km)
I ordered 90cm and i am waiting for them now.... hope it helps to improve signals and CCQ.
jober
Long time Member
Long time Member
Re: 802.11n
Tue Feb 23, 2010 9:08 am
Is that with a 20mhz or 40mhz channel?
ovkiller
Re: 802.11n
Tue Feb 23, 2010 11:05 pm
Should be 40mhz.
jober
Long time Member
Long time Member
Re: 802.11n
Wed Feb 24, 2010 12:45 am
So how many people are running .11n in a PtMP network?
What speeds do you see with TCP?
frontiersteve
Re: 802.11n
Wed Feb 24, 2010 6:47 pm
So I have 2 RB411AH w/r52Hn connected on the bench. Using the the bandwidth test from each device I can achieve 45-50 Mbit/s fdx tcp, and about 90-100 Mbit/s fdx udp. When I put a pc on each and and run jperf i can only achieve roughly 30 Mbit/s Hdx tcp. Anyone else seeing these sort of things?
ovkiller
Re: 802.11n
Thu Feb 25, 2010 6:08 pm
all of us
lekozs
Re: 802.11n
Thu Feb 25, 2010 10:04 pm
@professor
OK, I tried your setup exactly the way you described but still nothing! I was getting 80-100Mbps with the bandwidth test (winbox to winbox) but only 18-20 Mbps on a single file transfer with a laptop to laptop test... (It was a windows network, and yes... I tested it with an ethernet cable too, and everything was fine that way)
My testbed is a bridged setup (MPLS/VPLS as explained in the Wiki)!
Is your network bridged too on those above-mentioned links...?
Regards!
arcolorado
Re: 802.11n
Fri Feb 26, 2010 6:37 pm
does 802.11n works on the 5ghz band
Check out this dual pol antenna for 802.11n. http://www.antennas.com/DATA-SHEETS/ARC ... 113009.pdf
I've heard test results using 802.11n Mikrotik of 70-80 Mbps.
0ldman
Re: 802.11n
Fri Feb 26, 2010 7:19 pm
I didn't get many answers on my thread, so...
How about 2 chains on an AP and one chain on the CPE? Would that increase the download speed, upload speed or the same as a single chain?
On a small AP, has anyone run a high gain omni along with a lower gain omni? I'm looking at a Hyperlink 15dBi with a 8 or 10dBi for the second chain. Wider beamwidth for closer customers and cheaper as well.
vladimirslk
Re: 802.11n
Sat Feb 27, 2010 9:13 pm
:!: DO not cross Pigtails on outdoor boxes, put them on left and right, so they could not be connected. I have a link on 433ah 2x5ghz-turbo link, all work fine. I think, this could make good interference (pigtails together)
acim
Re: 802.11n
Sun Feb 28, 2010 10:45 pm
I thought so, thank you for your confirmation. These two channels are very close in frequency, so it's easy to get intererference.
0ldman
Re: 802.11n
Mon Mar 01, 2010 7:02 am
I agree with separating the pigtails as far as possible, however, outside of an N connection, I am hesitant to run 2 cards of the same frequency in the same box. I've got a 433 running a 3 sector 2.4GHz setup, works quite well. I've got several 600 with 2.4 AP and 5GHz ptp in and out. I am catching tons of self interference in the 5GHz band with careful location of the pigtails.
Running an XR5 with MMCX pigtails shows a 20dB difference than your standard ufl, could also be due to the fact the XR5 has only one port, my self interference may be caused by bleed through of the secondary ufl port through the diversity chip.
Rattlehead
Re: 802.11n
Mon Mar 01, 2010 2:31 pm
Hi guys,
Sorry guys if this is the wrong thread, but found it the most appropriate one.
Ive recently for an RB600 with wireless R52N card in it, been doing some testing on it and getting approx 150Mbs through it which I am happy enough with. This is a simple at home Wireless N, Router to multi client setup. The problem lies in when I put WPA2 or any other type of security on the wireless link the throughput goes down to MAX of about 20Mbs, in fact the wireless G card I have in the same RB600 performs better at throughput testing.
Testing was using the BTest.exe app on a Windows 7 machine to the RB. I presume the Wireless PCI (WMP600N) is performing correctly as I get the 150Mbs with the security turned off.
I'm not sure what config you guys would want to see, but its a fairly basic config, so just let me know if you need more info exactly. If anyone could help me it would be great.
danielillu
Re: 802.11n
Tue Mar 02, 2010 2:03 am
I read this thread because I'm setting up a new .11N link and was afraid of some unstabilities when using nstreme and/or wds.
My link have the following specs:
- 2x RB600A
- 2x R52Hn
- 2x JRC-24Duplex (dual polarity)
- 2.66km long with LOS.
- both chains for TX&RX.
Today I powered everything and I'm trying it.
Antennas are badly oriented (too much wind today) so I have bad signal but I started testing anyway.
I was afraid that when using wds CCQ and transfer rate drops for a while when transferring small packets.
I also read that nstreme is not stable (if even works) so I also tried it (never used n-streme before).
I tested using bandwidth test client/server running in both RB600A (I don't have a computer/RB1000 available to generate traffic)
Using WDS+ nstreme (default settings: no frame policy):
- UDP, 150 bytes/packet, both directions: 10s avg: 3,5mbps/3,5mbps (peaks of 7mbps when there is a signal variation) after running for 5minutes
- UDP, 1500 bytes/packet, both directions: 10s avg: 43mbps/50mbps. (max of more than 70mbps, lowest of 28mbps) After running 25 minutes.
Using only WDS:
- UDP, 150 bytes/packet, both directions: 10s avg: 1,2/1,8mbps (+/- 300kbps)
- UDP, 1500 bytes/packet, both directions: 10s avg: 8,6/8,9mbps (but speed very unstable). After running for more than 10min.
Tomorrow I will repeat these tests when the antennas are correctly aligned but the results looks promising
frontiersteve
Re: 802.11n
Tue Mar 02, 2010 3:16 am
with 802.11n you are apparently much better off using an mpls/vpls tunnel as opposed to wds. I am curious what kind of results you get as you are using rb 600s. I am wondering if my own bandwidth limitations I am seeing is not because of the fact that I am using 411AH boards.
Rattlehead
Re: 802.11n
Wed Mar 03, 2010 1:10 am
Hi guys,
As per my above post from yesterday, I have solved the problem regarding security and AP to Client throughput using an RB600 / R52N and a WMP600N. After a lot of searching and digging it would seem that Linksys have disabled HT in an earlier driver release for the WMP600N and the function remains disabled in the more up to date release of the firmware. I am not sure behind the reasoning behind this but for now, least there I have what I need.
Rattle
PS: Release notes here : http://downloads.linksysbycisco.com/dow ... n73020.txt
rahrouh
Trainer
Trainer
Re: 802.11n
Mon Mar 15, 2010 9:10 pm
Happy new year (norouz) .
about wireless link 802.11n !?
for about 3 meter , routerboard 411AH , R52N , 16dBi dual Polar antenna , with eoip bridge ; test with btest on wlan we have about 222Mbps RX or TX and TX:103Mbps and RX:85Mbps ; and test with btest on ethernet 95.5Mbps
for about 2.001 KM with routerboard 800 , R52N , 2 * 29dBi parabolic antenna , with eoip bridge ; test with btest on wlan about 127Mbps and test with btest on ethernet 117 Mbps ; i send file with 524MG from 4 windows computer to 4 windows computer about 5,5 minutes for all computer , and copy file to 2 windows with IDM(internet download manager) from 2 RB411U(USB2 Flash) with ftp by 79Mbps . cpu usage is 8%
for about 3.7 km with routerboard 411AH , R52N , 28dBi dual polar Dish antenna ......... ; test ................................................. about 127Mbps RX or TX on WLAN and 95.5 Mbps on Ethernet .
WirelessRudy
Re: 802.11n
Mon Mar 15, 2010 10:44 pm
Well, Nice for you, you are a lucky one.
We would like to know what freq. used, 20/40Mhz channel, CCQ, signal levels on both ends, any other radio settings, but most of all, how is your radio link. Plenty of free LOS with free fresnell and no other adjacent radio's in the areal working with same or close to your working freq's?
Give us some more info please. Many of us can only produce good working ´n´ links on short distances or under almost like ´lab´ circumstances, but real long links with many adjacent other 802.11a,b,g units around are just another league.
R.
InoX
Re: 802.11n
Tue Mar 16, 2010 1:02 am
UDP tests are not relevant...
staslabs
Re: 802.11n
Tue Mar 16, 2010 7:31 am
Yes. Try it on small packets, like 100 bytes.
ste
802.11n Short Range AP
Tue Mar 16, 2010 8:20 am
Anyone tried to build a 11n-AP for a short range with s.th. like this:
http://www.mars-antennas.com/item/023097b0c9b3-201.html
2jarek
Re: 802.11n
Thu Mar 18, 2010 7:59 pm
10 months......... ROS 4.6 no change......
HaQs
Re: 802.11n
Fri Mar 19, 2010 1:49 am
And new alpha version of ROS v5 when ROS 4 is in beta state. :/
Why release ROS v5 when v4 is very beta version?
normis
Re: 802.11n
Fri Mar 19, 2010 8:41 am
RouterOS v4 works fine. What the problem? See above thread, most issues have been solved with proper configuration. 802.11n is very hard to configure, lots of new options that need adjusting. You have to ask for help if you have issues.
acim
Re: 802.11n
Fri Mar 19, 2010 8:48 am
He probably means V4 lacks some 802.11n features, for example:
- signal stregth and quality per chain
- nstreme on two chains
- other features mentioned in this thread
normis
Re: 802.11n
Fri Mar 19, 2010 8:49 am
granted, those could be added to wishlist.
acim
Re: 802.11n
Fri Mar 19, 2010 8:52 am
normis, where to add it, where is the wishlist? I would do it right away :) We need these two features for yesterday :D
normis
Re: 802.11n
Fri Mar 19, 2010 8:57 am
It's already added
ste
Re: 802.11n
Fri Mar 19, 2010 9:06 am
Uuups. You're happy with your 11n implementation? Expect that there will be others who manage
to do this "hard to configure"-job for their customers.
You're right v4 runs fine for 11a. But Wisps have to go 11n to stay alive.
normis
Re: 802.11n
Fri Mar 19, 2010 9:10 am
Do you have an issue with 802.11n ? Please, give us your configuration, and tell us what's wrong. We will try to help.
acim
Re: 802.11n
Fri Mar 19, 2010 9:11 am
It's already added
Thank you. Can you tell us some release dates prediction for these two features I mentioned? Are you already working on that?
ianek
Re: 802.11n
Fri Mar 19, 2010 1:52 pm
Well you should make wiki for this. I tried several weeks to get your N solution to work - no success. Tried 3 different locations, all the time same result - high ping, low throughtput.
Changed to M5 solution - worked for 1st time on deployment - setted up only ap, station, band and IP adresees, so how can you tell its hard to configure ?
I like to continue with MK also on backbones, but
I have no luck to get it work ... Maybe you have to have only one card per device ? Maybe you should flag some options i donno what ?
Maybe - but i spent really like 6 weeks, and no success - except UDP test, but not for production.
If i miss some important thing, make WIKI for it ... Your wiki is not sufficient for N .
I doubt it is in setup - cause same setup M5 is working no problem.
Thanks for advance
Jan
2jarek
Re: 802.11n
Fri Mar 19, 2010 2:01 pm
Example best working config signal 50/50dB CCQ 99/99%:
name="wlan1" mtu=1500 mac-address=00:0C:42:3A:E8:E6 arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name="000C423AE8E6" mode=ap-bridge ssid="XXXX" area=""
frequency-mode=superchannel country=poland antenna-gain=0 frequency=5840 band=5ghz-onlyn scan-list=5700-6000 rate-set=configured supported-rates-b="" supported-rates-a/g="" basic-rates-b=""
basic-rates-a/g="" max-station-count=2007 ack-timeout=45 tx-power=17 tx-power-mode=all-rates-fixed periodic-calibration=disabled periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=yes security-profile=default disconnect-timeout=15s on-fail-retry-time=100ms preamble-mode=short compression=no
allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-guard-interval=long ht-extension-channel=above-control ht-supported-mcs=mcs-12 ht-basic-mcs=mcs-12
ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8000 ht-amsdu-threshold=8000 hw-retries=15 frame-lifetime=0 adaptive-noise-immunity=ap-and-client-mode hw-fragmentation-threshold=disabled
WirelessRudy
Re: 802.11n
Fri Mar 19, 2010 2:06 pm
If I put the ´n´ cards in ONLY ´N´ mode, does that means the same as ´greenfield`?
Does the radio still have problems with other ´a´ mode radio's in the vicinity? Not interference, that's an radiowave issue, but the protocol, does the radio's communications rate switch down towards legacy speeds?
Even if I have a ´n´ link running, with both ends ¨5Ghz-only-N¨ enabled, in the status screen it still shows ¨5Ghz-a/n¨ band?
Does that mean this link is still downward compatible with 802.11a?
If it means the MT ´n´ cards don't have ´greenfield´ option yet they are useless in any environment where still 802.11a radio waves are around.....
normis
Re: 802.11n
Fri Mar 19, 2010 2:48 pm
this only means that you don't know about the hw-retries setting, which affects latency, and can decrease it. As I said, configuration issue
2jarek
Re: 802.11n
Fri Mar 19, 2010 3:39 pm
I try hw-retries setting 15, 5, 0 on AP & APC no change but if I set 0 some ping lost no stable.
normis
Re: 802.11n
Fri Mar 19, 2010 3:47 pm
small hw-retries means good latency, lower link stability
bigger hw-retries means worse latency, higher link stability
choose your target and experiment accordingly, to balance latency and stability
2jarek
Re: 802.11n
Fri Mar 19, 2010 6:39 pm
I think bigger hw-retries means worse latency not true for point too point link.
In multipoint - yes stations/clients with weaker signal or working in noisy environments enforce "hw-retries" frames & kill latency too another stations.
jcrites2008
Re: 802.11n
Fri Mar 19, 2010 6:48 pm
You would think that even with default settings, you could get decent throughput, but I haven't been able to get decent throughput no matter what I try. I tried other people's configs, tried experimenting with my own, took advice from other people,still nothing. It's just not worth headache really... I wonder if some of the R52N's perform better than others. It just doesn't make sense that configs could make the difference between 10 Mbps and 80 Mbps. It should be made easy for us to at least get I don't know like 40 mbps? And then we could tweak settings to get up to the 80 mbps or more that we should be able to get.
Personally I think wireless N is flaky in general. Tried and true wireless G routers have much better ratings than any wireless N routers.
WirelessRudy
Re: 802.11n
Fri Mar 19, 2010 7:55 pm
Normis;
What is the meaning of "link stability" here?
High ping times usually are also accompanied with fluctuating ping times, both makes bad latency and I can't call that really "stability". Your comment makes not a lot of sense here.
I would say the better the latency (=the shorter the ping times), the higher the link stability. But at the same time, a low latency link can drop or loose its throughput completely which makes it a very unstable link....
(I had a ´n´ link running over 12km with duo pol antennas and got up to 18Mb tcp over it, just to see it completely collapse after 4, 5 minutes or so. I had to stop the test and then sometimes wait 5 to 10 minutes and then I could get the same test running again, with same speeds. CCQ were sometimes relative nice +80's but then suddenly fall into 30 or less, and sometimes in one direction only. Then also the receiving signal levels were all over the range, from -85 to -40 while the link just stayed up, and yet again, sometimes on both ends, sometimes only one end.
To get that badly needed link running I had to put two R52H cards on both ends rb433AH boards in and have now a very stable 45Mb bonded link running over it. Signals are very stable at each end and very strong. I even had to tune down the card to 15dBm to bring recieve levels in the -50dBm range. CCQ is also very stable now and jumping between 100 and 95%. Apart from the cards all physical situation is exactly the same!)
If there exist a defined explanation of the expression "link stability" I would like to know what that is.
I have managed to get one other ´n´ link running on a short (800mtrs) distant in a very noisy environment with many other radio's that ran for 4 months now and in the beginning I could get 60-80Mb tcp traffic running over it.
Now I found out that without any changes since then the links stops at a poor 25Mb. I can try any setting and every time I see a suggestion in one of these topics try it out myself but the link is just not performing any more..... udp still flies towards 200Mb but tcp absolutely sucks....
I had put my hope on the new 802.11n technology to stay ahead of the Wimax competition but so far only got gold showers from it... very disappointing....
The only thing I see is that MT's biggest competitor in the field, Ubiquity, has the same issue with ´n´ protocol so were not alone...
I still believe 802.11n protocol will deliver in the end but to help us all on this forum more info should be shared about this technology to make it really usable for many users. We should develop much more understanding of the ´n´ protocol and put it in a usable ´manual´.
The present manuals or Wiki's in regard to 802.11n are very limited and therefore not very helpful.
The situation now if you would compare it to the car industry is that you order the latest model formula one race car but its been delivered at your doorstep in a box with all components. The manual accompanied is written by some first hour user's daughter of 5 and we, buyers of that new record winnner car have to figure it all ourselves how to build the car to become a real race monster......
Critics on the MT manuals have been vented in this forum before and although I see some improvements lately there is still a long way to go..
R.
ianek
Re: 802.11n
Sat Mar 20, 2010 4:02 pm
Same for me ...
Btw about hw-retries i tried a lot and everything lower than 15 put the link to absolute non usable state.
Jan
expunge
Re: 802.11n
Tue Mar 23, 2010 3:54 am
I love this, normis drops into this thread after months of people having headaches to tell us that everything is perfect and it's just that nobody can properly configure their 802.11n settings. Please oh please normis share with us the magic of this 802.11n voodoo that nobody seems to be able to figure out. I can tell you that hardware retires does not fix the issues. I've played with every setting imaginable and I'm unable to get anything to work with any reliability. I can however pop out the n card, drop an XR5 in the same place, same pig tail, same antenna, same ROS and link up with 40+ mbits throughput.
Why is it that so few people have having success with 802.11n and it appears that the cries from the masses have fallen on deaf ears for the past several months and now it's all just a "configuration issue"? I would think that someone out of all of those who are trying would have stumbled upon the magic combination of settings that makes a link work well. There are here and there results where someone gets a nice production link but those seem to be over short distances and with astronomically high signal levels. We're used to taking a 5 GHz link and going 30+ km to a -60's signal and getting 40 mbits. I have yet to see anyone do anything similar with 802.11n products from Mikrotik. I can however buy M5 solutions left and right and slap them up with relative ease and count on them to work correctly (or at least usually).
I love the "do you have a problem with N?" "Give us your configuration and we'll help". There has been at least 20 people post their full configuration in this thread who are getting poor results on a production link and I have yet to see one of them solved. Most of us don't have the luxury of leaving a broken link in place for weeks at a time while you feed us this and that tid bit of information on how to massage the link into functionality. If MT is unwilling to put serious effort into fixing the 802.11n issues and supporting those of us who have forked over the money to try to jump on the MT n bandwagon just let us know now so we can plan accordingly. I'm sure this will draw the ban hammer down upon me but someone really needs to say what everyone is thinking.
changeip
Re: 802.11n
Tue Mar 23, 2010 4:43 am
I have a 2-3 mile link with this same erradic behavior. I can put in an XR5 and its perfect, yet with SR71-15 or r52N cards its horrible (ccq < 80%, most of the time 50%). P-througput shows 150+ mbps but in reality I get about 8-15mbps. I will try to get Mikrotik logins and let them play with it to see if they can figure it out... i've spent 2 months and every suggestion presented with no success.
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=client-mode allow-sharedkey=no \
antenna-gain=0 area="" arp=enabled band=5ghz-onlyn basic-rates-a/g=6Mbps comment="" \
compression=no country="united states" default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none disable-running-check=no \
disabled=no disconnect-timeout=3s frame-lifetime=0 frequency=5300 frequency-mode=\
manual-txpower hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=\
8192 ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-extension-channel=\
above-control ht-guard-interval=any ht-rxchains=0,1 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mc\
s-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15" \
ht-txchains=0,1 hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=4 l2mtu=2290 mac-address=00:15:6D:84:2E:24 \
max-station-count=2007 mode=station-pseudobridge mtu=1500 name=wlan1 on-fail-retry-time=\
100ms periodic-calibration=disabled periodic-calibration-interval=60 preamble-mode=both \
proprietary-extensions=post-2.9.25 radio-name=00156D842E24 rate-set=default scan-list=\
5260,5280,5300,5320,5430,5435,5440,5445,5450,5455,5460,5465,5470 security-profile=wpa \
ssid=north.wshtna.wifi.myserver.org station-bridge-clone-mac=00:00:00:00:00:00 \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tx-power-mode=\
default update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none \
wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wmm-support=disabled
pikpik
Re: 802.11n
Tue Mar 23, 2010 10:40 am
hw-retries=15, try to set only few mcs rates. Disable a/g rate. If doesnt help, try reset-conf (with bios upg) and use this settings:
ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=5ghz-onlyn \
basic-rates-a/g="" basic-rates-b="" comment="" compression=no country=\
poland default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=3s \
frame-lifetime=0 frequency=5180 frequency-mode=manual-txpower hide-ssid=\
no ht-ampdu-priorities=0,1,2,3,4,5,6,7 ht-amsdu-limit=8192 \
ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0 ht-extension-channel=disabled \
ht-guard-interval=any ht-rxchains=0,1 ht-supported-mcs=\
mcs-0,mcs-7,mcs-8,mcs-14,mcs-15 ht-txchains=0,1 \
hw-protection-threshold=0 hw-retries=15 \
max-station-count=2 mode=bridge mtu=1500 name=wlan1 on-fail-retry-time=\
100ms periodic-calibration=disabled periodic-calibration-interval=60 \
preamble-mode=short \
rate-set=configured scan-list=5180,5760,5320,5825 \
security-profile=default ssid=awmn-2315-3665 station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g="" supported-rates-b="" \
update-stats-interval=disabled \
wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
wds-ignore-ssid=no wds-mode=disabled wmm-support=enabled
gringoZ
Re: 802.11n
Tue Mar 23, 2010 11:20 am
I try EVERY configuration from this thread and i had bad results. Btest from mt to mt go to over 100 mbit udp or 70 mbit tcp but ping are BIG with traffic of 40mbit or 100mbit! Worse than i bonded 2x nstreme or nstreme dual at mt 3.30 at same traffic. Pings at level of 30-300ms are not acceptable for productivity link at small isp :( I try n at mt 4.6 at table and outdoor (3km link). I think "n" is unusable in this state of development.
pikpik
Re: 802.11n
Tue Mar 23, 2010 12:03 pm
I have the same issue, reset helps me, dont know why. Those setting works fine on ~3km. Just try. I have 4.5
gringoZ
Re: 802.11n
Tue Mar 23, 2010 2:51 pm
tried your configuration at desk but it does the same symptoms as before. :(
mt 4.6, reset configuration, r52n, vpls:
mt 4.6, reset configuration, r52n, vpls, nstreme best-fit=3200 pooling=yes csma=no:
pikpik
Re: 802.11n
Tue Mar 23, 2010 3:02 pm
CPU overloaded and vpls doesnt work on your. Try to send traffic over vpls.
When you use vpls, decrease CPU usage and throughput will improve.
angboontiong
Re: 802.11n
Tue Mar 23, 2010 4:05 pm
It seem like the Mikrotik 11n also very based on the CPU speed.
I will say, totally not the good idea for R52Hn + RB433.
Why there is no option for RB433 series with power processor?
gringoZ
Re: 802.11n
Tue Mar 23, 2010 4:28 pm
Ups... I had p3 1.2GHz tualatin processor, than have more power then powerpc in rb600 :)
Btest from pc to pc. Good pings but where is my transfer ? :(
both:
receive:
send:
pikpik
Re: 802.11n
Tue Mar 23, 2010 4:35 pm
show me test MT-MT on this settings. (not pc pc). Try add ht-extension-channel= .
gringoZ
Re: 802.11n
Tue Mar 23, 2010 4:53 pm
pikpik
Re: 802.11n
Tue Mar 23, 2010 5:00 pm
tcp test plz:P try change band to only-n. Show me wireless advanced (all hw cvars)
edit:
OMG use VPLS !!! :P
gringoZ
Re: 802.11n
Wed Mar 24, 2010 4:03 pm
gringoZ
Re: 802.11n
Wed Mar 24, 2010 4:04 pm
gringoZ
Re: 802.11n
Wed Mar 24, 2010 4:05 pm
gringoZ
Re: 802.11n
Wed Mar 24, 2010 4:07 pm
gringoZ
Re: 802.11n
Wed Mar 24, 2010 4:14 pm
mt ap config:
set default authentication-types="" eap-methods=passthrough group-ciphers="" \
group-key-update=5m interim-update=0s management-protection=disabled \
management-protection-key="" mode=none name=default \
radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
static-sta-private-algo=none static-sta-private-key="" \
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\
none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" \
wpa2-pre-shared-key=""
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
antenna-gain=0 area="" arp=enabled band=5ghz-onlyn basic-rates-a/g="" \
basic-rates-b="" comment="" compression=no country=poland \
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=\
0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=\
no disconnect-timeout=3s frame-lifetime=0 frequency=5180 frequency-mode=\
manual-txpower hide-ssid=no ht-ampdu-priorities=0,1,2,3,4,5,6,7 \
ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0 \
ht-extension-channel=disabled ht-guard-interval=any ht-rxchains=0,1 \
ht-supported-mcs=mcs-0,mcs-7,mcs-8,mcs-14,mcs-15 ht-txchains=0,1 \
hw-protection-threshold=0 hw-retries=15 l2mtu=2290 mac-address=\
00:0C:42:61:72:04 max-station-count=2 mode=bridge mtu=1500 name=wlan1 \
on-fail-retry-time=100ms periodic-calibration=disabled \
periodic-calibration-interval=60 preamble-mode=short \
proprietary-extensions=post-2.9.25 radio-name=000C42617204 rate-set=\
configured scan-list=5180,5760,5320,5825 security-profile=default ssid=n \
station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g="" \
supported-rates-b="" tx-power-mode=default update-stats-interval=disabled \
/interface wireless manual-tx-power-table
set wlan1 comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,\
6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps\
:17,HT20-0:0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:\
0,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0"
/interface wireless nstreme
set wlan1 comment="" disable-csma=no enable-nstreme=no enable-polling=no \
framer-limit=3200 framer-policy=none
mt client config:
/interface wireless
00:0C:42:61:72:01 max-station-count=2 mode=station mtu=1500 name=wlan1 \
proprietary-extensions=post-2.9.25 radio-name=000C42617201 rate-set=\
set wlan1 comment="" disable-csma=no enable-nstreme=no enable-polling=yes \
its look like wireless-n-image spam ;)
pikpik
Re: 802.11n
Wed Mar 24, 2010 5:48 pm
eeh ..
1. Run test over vpls (test to ether ip - not transport/remote/wlan ip )
2. Test run on ROS not on pc with winshit
gringoZ
Re: 802.11n
Wed Mar 24, 2010 6:53 pm
eeh ..
i add ip 10.10.10.1 to mt-ap, and 10.10.10.2 to mt-client to ether1 at mt's:
and results same...
2jarek
Re: 802.11n
Wed Mar 24, 2010 7:46 pm
eeh ..
Pikpik....... Show me working 802.11n ROS bridge works fine (ping lower than 10ms & stable) if you push 40/10 Mbit/s or more asymmetric traffic.
Why no push 50 Mbit/s in one session TCP ???? Because latency sucks so much on MT 802.11n implementation or Ethernet frame order is not preserved.
mishaM
Re: 802.11n
Thu Mar 25, 2010 8:03 am
rb600a and rb433 , 1x antena ,~1km
tcp ~35mb (half) , ~20mb (duplex)
so that is udp:
pikpik
Re: 802.11n
Thu Mar 25, 2010 10:04 am
I try today on ~12 km. Will show you results.
gringoZ : try change mtu /mpls interface set 0 mpls-mtu=1526
2jarek: i only try iprove his link
l0ft13
Re: 802.11n
Fri Mar 26, 2010 7:13 pm
if only all the folk who are generating decent speeds would share their config secrets with the rest of us mere mortals..
jcem
Fri Mar 26, 2010 9:05 pm
I have a 5km link with 2 r52n cards on which I only use single chain and Signal-77. After have tried many different settings
on this link I found the following....
1. Increasing the "hw retries" to 10
2. Setting the "Ack Timeout" to 75us
- In the default setting the link established with a "Ack Timeout" of 45us
- This made the greatest difference. The link went from an avg of CCQ70 to CCQ 95
3. Removed all rates in "Data Rates"
4. Only marked MSC0 and MSC4 under "supported" and MCS0 under "basic"
- Here I removed all except MCS0 and added one by one as long as the link kept good CCQ
I total I went from a TP of 20mb to 65mb
I applied similar changes to a 1km link and went from 70mb to 90mb with a single chain.
I don't know if this could be applied for dual chains, but I hope this can help someone
RGDS
jcem
Re: 802.11n
Sat Mar 27, 2010 1:27 am
Just to add to My previus post....
I only make changes to the AP and leave the station in default.
angboontiong
Re:
Sun Mar 28, 2010 5:06 pm
RGDS
You mean...
how we going to do so, cause in the winbox i not able to make change on it.
jcem
Re: 802.11n
Sun Mar 28, 2010 6:00 pm
Sure you can do it in winbox......
First change to "Advanced Mode"
and then check "Configured" under the "Data Rates" tab
Now proceed as I described previously
RGDS
gringoZ
Re:
Sun Mar 28, 2010 10:45 pm
please show us pings at tcp 65mb
please show us pings at tcp 70mb
jcem
Re: 802.11n
Sun Mar 28, 2010 11:42 pm
I have some traffic so I can only show you 45Mb and 85Mb right now...
I can't show you tcp from were I'm at. Only about 30Mb that RB600 can generate...
I know udp isn't exactly relavant, but the point I'm showing is the
the Link doesn't break down when using this types of settings. I'm not
an expert, but I found out by trial and error and it works for me.
Setting the "Time-Out" makes the biggest difference and you have to set it
to the same on AP & Client
I wonder why ROS can't calculate the optimal "Time-Out"?
These are "Single Chain"
2jarek
Re: 802.11n
Mon Mar 29, 2010 12:23 am
@ jcem TCP, TCP, TCP...................
jcem
Re: 802.11n
Mon Mar 29, 2010 12:38 am
RGDS
WirelessRudy
Re: 802.11n
Mon Mar 29, 2010 11:09 am
Can any of the guys displaying success stories with ´n´ protocol enlighten the situation regarding surrounding 802.11a (b/g) networks and their freq's?
The more I read about ´n´ (and look at my own links) the more I am given the opinion that 802.11n links or usage is bound to become a disappointment when a/b/g radio's are around and ´heard´ by ´n´ AP or station.
But maybe some of you still have success while these ´legacy´ devices are around?
angboontiong
Re: 802.11n
Mon Mar 29, 2010 2:34 pm
Hi...
Thanks for you sharing...
Cheers...
aaa
Re: 802.11n
Mon Mar 29, 2010 9:19 pm
Real 100mbit half duplex is arrived! This is real customer traffic not any type of b-test. I try replace RB600 at station side and I am sure i can get more then 100mbit in one direction!
gringoZ
Re: 802.11n
Mon Mar 29, 2010 10:41 pm
1 or 2 chain? Please show us pings at this traffic...
WirelessRudy
Re: 802.11n
Mon Mar 29, 2010 11:17 pm
Concratulations! But;
- Configs please (´n´ specific as well as other wireless. nstreme? WDS? MPLS?)
- Link data (distance, freq's, power, signal level CCQ etc. etc. etc.
- Environment; Noise levels, other ´legacy´ a/b/g radio's around?
If we know all this maybe we can learn from it and achieve the same.... :)
jcrites2008
Re: 802.11n
Tue Mar 30, 2010 12:24 am
doubtful
OpiumDream
Re: 802.11n
Tue Mar 30, 2010 7:27 am
why bother with this n links ? when you can get same results with turbo g ? even better,
N is horrible on small packets.
we have a nstream dual link performing on 80mb tcp full duplex.
No metter small packets , big packets , tcp , udp.
Link is in production. It’s used as a backup of fiber optic connection.
3 weeks link was in production as primary link for 1000 users.
Voip, data …… everything works perfectly.
We lost 3 weeks configuring N wireless for this link without any success, bandwidth test for udp traffic showed 200m WOOOW that’s cool, but in real life 10 voip calls was killing this link.
I will wait 1 year before I will try N again.
ste
Re: 802.11n
Tue Mar 30, 2010 8:39 am
Did you checked the HT AMPDU priority and AMSDU Limit/Threshold values? Did not help to use this parameters?
OpiumDream
Re: 802.11n
Tue Mar 30, 2010 10:48 am
I don't remember , that was 3-4 month ago.
I lost 3 weeks checking and unchecking various parameters.
in production maximum traffic we achieved was only 60mb full duplex data only, voice calls was killing throughput to 5-6mb.
same equipment with R52 modules instead of R52n is perfectly working now.
0ldman
Re: 802.11n
Wed Mar 31, 2010 3:58 am
I can't get these to work in N mode period. They'll connect, show 150Mbps connection, I can ping through it, as soon as I move traffic I lose the link. The CPE just disconnects and constantly tries to connect. The AP still shows the client connected for a while after.
These have only run 4.x, upgraded to 4.6, reset, configured. If I leave the data rates at default, it will show 150mb and drop to 54 as soon as data starts moving and works fine. If I disable all but N data rates, it works until I move data. Anything larger than a ping and the link drops. One CPE is 3 rooms down with a signal of -75, one is in the next room, signal anywhere from the -50s to -70, depending on how I turn the antenna.
I have enabled both chains on the AP, disabled one, turned extension channel on and off, Nstreme on and off, no change, WMM, etc...
I was using RTS/CTS at first, disabled that and I thought that did it. I actually got to move about 2 megs of data before it lost the link and refused to associate again. The only fix is to disable the AP card and then turn it back on.
CCQ will occasionally show more than 100% on both CPE's and the AP, status will occasionally go from -60 to -17 on the RX, which absolutely isn't possible with the AP being in another room...
AP is a 433 with R52NH and two 6dBi omni, one client is a 19dBi rootenna, 411 and R52N, other is a dual band rootenna with 411 and R52N.
I've tried two different cards, two different RB433, two different CPE, different sets of pigtails.
At least I can say they are 100% stable in A, B or G.
Client
name="wlan1" mtu=1500 mac-address=00:0C:42:x arp=enabled
      interface-type=Atheros 11N mode=station ssid="test" frequency=5180
      band=5ghz-a/n scan-list=default wds-mode=disabled
      wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes
      hide-ssid=no security-profile=WPA compression=no
AP
name="5GHz AP" mtu=1500 mac-address=00:0C:42:x arp=enabled
      interface-type=Atheros 11N mode=ap-bridge ssid="test" frequency=5785
      band=5ghz-onlyn scan-list=default wds-mode=disabled
      hide-ssid=yes security-profile=WPA compression=no
mishaM
Re: 802.11n
Wed Mar 31, 2010 2:32 pm
100mbt tcp or udp traffic ?
jcem
Re: 802.11n
Wed Mar 31, 2010 3:28 pm
I'm not sure you tried this.......
When looking on the front of the R52n card antenna connectors up:
- I only "check" chain0 when the antenna is connected to the left connector on the card
- I only "check" chain1 when the antenna is connected to the right connector on the card
Only "check" the appropriate chain# when using single chain and single antenna
RGDS
2jarek
Re: 802.11n
Wed Mar 31, 2010 9:15 pm
Who will check 5.0beta1 with 802.11n? Any change?
0ldman
Re: 802.11n
Thu Apr 01, 2010 12:19 am
RGDS
I've connected to an AP on the tower with the CPE's and done site surveys with one of them. I don't remember which connector, I think J4, using chain 0. Just for giggles, I checked it and swapped to the other chain, lost 30dB signal.
jcem
Re: 802.11n
Thu Apr 01, 2010 12:36 am
RGDS
Scanning with the chain not connected You shouldn't see anything further away than ~50 meters.
For example other AP's in the same tower or an AP real close.....
RGDS
WirelessRudy
Re: 802.11n
Thu Apr 01, 2010 1:05 am
RGDS
That's not true. I had a radio that had a pigtail disconnected and still picked up two or three radio's from more then a km away that were aiming that same tower. Off course these used high gain antenna's with concentrated energy beam toward that tower.
I also had once a client complaining about poor internet at times. When we checked signal levels were not very good, -85dBm or so but ok, the installer guys must have lined out the antenna wrong or the wind must have twisted the pole or so.
This CPE with 14dBi antenna was some 150 meters away from AP.
When I checked installation saw antenna was pointing in complete different off-set direction. So I turned antenna to point to its AP. No improvement in signals!! Very strange! (Later found that installer actually had pointed antenna to where he saw highest receive signal in scan! That he literally could see the AP made not a lot of sense to him! :shock: )
I then opened the box, found pigtail completely loose, some 2 cm's away from its connector!
When I connected the pigtail signal jumped into -40's...
In the past I remember that on the desk testing these connectors for which one was radio a or b, while the unit was only on the other end of the table as the AP, I noticed little differences between chosen radio a or b.
So be careful with this. Things are not always what they look.
Skaught
Re: 802.11n
Thu Apr 01, 2010 5:15 am
I have been forced to start moving away from MT on my network over this on many new deployments. Other vendors have cheaper solutions that work better/faster and can be installed in minutes. We are going on 6 months now on a test link.
A certain competing product is less than 1/4 the cost and worked first try at speeds way faster than I can even get in ideal conditions in the lab with MT. It did go down once or twice in the first month and needed a bit of tweaking but it has now been very stable and trunks a few thousand voip calls and torrents without breaking a sweat.
MT can continue to let the competition finish catching up. They already offer many of the features the MT has and are only getting better. This is MT's market to loose and they are doing all the things they need to, to loose it.
There is definitely a major issue with the corporate culture at MT. Once a company allows the attitude that users are the fault, it is never a good thing.
Successful companies recognize that when a customer makes an error, the vendor needs to find ways to make the error harder to commit by having more robust systems and interfaces. Documentation is also a key component of this. Of which there is none. Message boards are not documentation despite what MT thinks. The Wiki is a joke and vastly incomplete. I do not know where this idea that you can get your customers to write the wiki for you came from. It works for free software because it is free. This is not free. I pay for it and expect a certain level of support and expect it to work as advertised.
I cannot spend hours on here pouring though posts to find a the secret hidden trick that someone found. I have not seen any examples of anyone getting this to work anywhere near what they claim or what the competition is delivering. If there are people getting this to work, the onus is on the company who I gave my money to, to provide the answers.
I start to get reminded of the old BOFH stories. The admins know all and everyone else is incompetent. No way to run a business and demonstrates they are missing the whole point.
This is constructive criticism. If I did not care I would not waste my time to offer them help. If they do not know how to take criticism it will become obvious by the response to this message.
normis
Re: 802.11n
Thu Apr 01, 2010 8:25 am
we have new drivers in v5, all work that we put into wireless goes into v5 now, there should be lots of improvements coming shortly. We have many test links here, each with different conditions, we are trying to simulate all environments and improve in them.
mishaM
Re: 802.11n
Thu Apr 01, 2010 1:48 pm
routros v5.0beta1
rb600a and rb433
tcp traffic already accelerated . :shock:
normis
Re: 802.11n
Thu Apr 01, 2010 1:51 pm
Is it good or bad? hard to say out of context.
mishaM
Re: 802.11n
Thu Apr 01, 2010 2:02 pm
evident is good , rb433 (300mhz) it correspondingly good . :)
InoX
Re: 802.11n
Thu Apr 01, 2010 2:11 pm
RB433 can push easy over 150mbps on 3xwlan, so from some point of view your result isn't good. You must provide some setup data. 80mbps can be achieve with 5Ghz turbo easy.
WirelessRudy
Re: 802.11n
Thu Apr 01, 2010 5:57 pm
I have to agree with Skaught and expunge.
I hope v5 will bring better times.
And if you guys manage to have the hardware side covered and we can see real life improvements it is time some real expert goes through the Wiki with a comb.
Lots of stuff presented there is incomplete, conflicting with other info or just not the right way to do things.
the ROS ref. manual or online docs are written for the reader that obviously already has experience and advanced skills in MT-ROS.
And put more real life representing examples online.
Some users do run good running networks. Use them as ´working model´ examples and sponsor them! But only after their setup is checked and approved by you experts.
New users need to be able to fall back on examples they can explore and edit to their wish.
The forum is now so big that indeed, usable info is hidden but to find it you need hours of reading.
Searches won't always work since their is a lot of bad grammar around and subjets or even topics are not covered by the subject titles.
Support and forum could definitely have a more helpful and friendly approach too.
It causes repeatedly irritations from users if answers are not given or it is only pointed towards were the requester should start reading or watch (incomplete and slow) tiktube video's.
Hardware price levels are of lesser importance if documentations and post sale support would be excellent.
Many of potential MT hard or software users are now becoming so frustrated they change platforms.
We read this in the forums, I read it in other forums of the competition, I hear it direct from colleagues and think about it myself.
So take the advice and improve the hardware drivers and management in v5 and make 802.11n work with explanation of the environment it need
Set-up a complete new after sales and support dept. with focus to the client.
If one or both fail I see no long term future for MT and its products. Competition coming up everywhere!
All good advice! :)
mihookoz
Re: 802.11n
Fri Apr 02, 2010 11:16 am
Hi! Unsubscribe from MT to another manufacturer. N is the standard long ago. Many of the settings a lot of problems when trying to introduce N Mikrotiku. After an exchange for another manufacturer's working. Approach manufacturer Mikrotik lack of words. How do I continue to be no change provides a fast end of MT.
rpingar
Long time Member
Long time Member
Re: 802.11n
Fri Apr 02, 2010 12:47 pm
it is not useful to show the bandwidth test in this psot.
Because the problem of N links are not evident using bandwidth test.
They arise when using real traffic with small packets.
Actually 5.0beta1 didn't fix our isse with this kind of traffic. Still see a very huge jitter with latency of 20-40ms on 20mbps of traffic and 4.5K packets.
They are not good numbers for a backbone link.
regards
Ros
0ldman
Re: 802.11n
Sun Apr 04, 2010 7:18 am
If bandwidth tests don't show the limitation of N for you, you are several steps ahead of me.
I've been reading on 802.11n, been reading the posts, forum, wiki, etc. I can't even get a 411 to work with a bandwidth test, not even 2 433's with R52nH, two 5GHz antenna per system, single chain, dual chain, extension channel, no extension channel, v4.3 through v5B1, reset to defaults, WPA, no encryption, just about every variable I can think of.
I am about two steps from calling MT 802.11n complete BS. I have tested single antenna, dual, single chain, dual, single channel, dual, encrypted vs not, different channels, different bands, etc... reset after every firmware update, manually configured rather than use my CPE config, tried actually using the link rather than running btest.
Every single time I use N, it fails. The only thing more reliable than N's failure is A or G working. The most I've gotten out of it was 23mbps.
My entire network is based on MT hardware and software. I am beginning to wonder if my business plan may not have a huge hole in it limiting myself to a single supplier. The only things I don't buy from MT is cases, antennas and 900MHz radios. Every piece of hardware with any intelligence is MT, right down to the wireless cards, aside from the 900MHz band.
I have posted many questions about 4.x and N networking in general and gotten some info that I already knew from some forum users and no answers from MT themselves. I have been completely thrilled with MT until this point. Now I am beginning to wonder.
If MT is having trouble with 802.11n, keep us in the loop. Denying there is a problem when many of us are actually having problems is causing loyal customers to doubt your integrity and/or capability. What you are capable of can change drastically and quickly, I've been there myself. What you are honest about is something different entirely.
angboontiong
Re: 802.11n
Sun Apr 04, 2010 9:24 am
May you can consider to attend china MUM and talk face to face with the Mikrotik management people.
aaa
Re: 802.11n
Tue Apr 06, 2010 9:52 am
It's mixed customer internet traffic. Some of this is HTTP,FTP but most is P2P taffic.
aaa
Re: 802.11n
Tue Apr 06, 2010 9:58 am
Two chains, ping not exceed 20-30ms. I can try make sreen shot but I am not always on internet connection.
dieterk
Re: 802.11n
Wed Apr 07, 2010 1:52 pm
Hi !
I can completly support this mind ! fact is, that 11n (i have tested at 5GHz with R52n) doesn't work correctly. I think it is simply the delay time, so we cannot get more TCP traffic. Maybe driver problem or 4.x problem... Test with RB433AH and RB600 with all possible settings show a higher delay time (40ms+) at real TCP traffic above 25MBit - also with 40MHz and CCQ95%. I have also seen that configured interface-bridges can increase the delay time.. I tried all, did get the link stable (rety time), but no good performance. Best performance i can reach with 5GHz 11a with turbo mode and nstreme at 3.x. Delay time is 1ms and real customer traffic from hundreds of customers up to 50MBit without problems.
Please MT devolopment team: accept this is a fact and no secret switch can turn the link into a turbo-speed 11n link. i have seen that nstreme at 11n has hopefully much better delay time. So i also tried this way. I did get a link into work with nstreme with many tricks (ack-time, noise-immunity, fixed-data-rates, MPLS, ...) and did run this link with high-load-bandwith test on UDP (80MBit) and very low delay time for pings via the same link (1ms). But real traffic did make the link unstable and unuseable, so nstreme really can'not be used ...
A real faithful MT statement should help very much to end this odysseey and save many many hours of hopefully but unsucessfully testing for all of us at looking for own "configuration problems". I don't understand, that MT cannot reproduce this problem and cannot find the solution for this SW delay-time-problem on load...
I don't need new features first on 5.x, i would need an working 11n link on 4.x oder 5.x with low packet delay !! THANKS !
best
Dieter
normis
Re: 802.11n
Wed Apr 07, 2010 1:56 pm
We are testing a lot, we have a multitude of testing links with real traffic, but most of them work perfectly fine. We have found some issues in some cases, and are trying to improve the situation. We are also working on new wireless drivers.
But ...
don't expect the 802.11n to be some magic speed boost switch. You have to learn to understand it, and properly configure it.
angboontiong
Re: 802.11n
Wed Apr 07, 2010 2:14 pm
But ...
Normis...
Just wonder know, is all of you focus on the Router OS only..
or you have enough good people take care on the wireless related implementation?
normis
Re: 802.11n
Wed Apr 07, 2010 2:19 pm
we have separate teams for separate RouterOS features, we focus on all stuff that's important
dieterk
Re: 802.11n
Wed Apr 07, 2010 2:34 pm
Thanks Normis !
But if a link is properly configured, i understand the background, the CCQ is nearly 100%, the link is very stable at 130-270MBit both directions, the bridge goes via MPLS (ap/client), the packet loss on wlan-interface is very very poor, and the delay is 1ms at lower load. It seems good ... But: If the traffic goes up to 25MBit the deley increases and stopps performance ... This on 3 different links i have tested ... no problem with 3.x and 11a on nstreme and alternative turbo mode ...
There is a hidden bottleneck inside the OS ... How can we open the valve ? And i am not alone with this unsuccessfully links ...
Do you really have real traffic via 11n above 50MBit TCP on 20MHz and delay time at 1ms ??? Please push a config online (where everything is configured correctly) and show the speed results with real TCP traffic ??
I really want to help solving the problem and i like MT, because i have very good quality to my customers with the help of MT products. But 11n is really a long-time-problem ... via years of waiting and testing ... And we will need working 11n in near future to be able to push our bits and bytes to our very hungry customers !
Thanks for information
Dieter
normis
Re: 802.11n
Wed Apr 07, 2010 2:36 pm
dieterk
Re: 802.11n
Wed Apr 07, 2010 3:08 pm
Normis,
Its Ok, and would be great ! But because of EOIP tunnel shows no traffic, it seems to be a routed configuration. Maybe the Problem is the bridging in V4.x ?!? which produces delay ?!? no chance with EOIP or MPLS with bridged traffic on my location ....
Dieter
0ldman
Re: 802.11n
Wed Apr 07, 2010 10:10 pm
But ...
I really am beginning to tire of reading this particular line.
How complicated is N? If it is so complicated and we're doing it wrong, why can't you tell us where we screwed up?
Two chains, multiple encoding methods, extension channels. I don't see the complication.
I have read the posts on this thread, read the wiki. I don't have some odd link.
What other magic bullet to make a dual chain, 40MHz N only, MT only link to move traffic?
A/B/G works fine. If I disable A/B/G speeds, N disconnects the instant I go beyond a simple ping.
I just reset the wireless to defaults, turned one on in bridge mode, one station, added extension channel and got a 135mb link that appears stable. I will now start enabling encryption, change SSID, etc, one at the time until I determine what caused it to fail earlier.
Right now the link shows 150, however, it only moves around 28mb, the same it did at 65.
edit: enabled WPA encryption, system now only moves data at 54mb speeds, loses connection at HT speeds.
gringoZ
Re: 802.11n
Thu Apr 08, 2010 12:02 am
this means that your link is WORST then common nstream dual in 802.11a turbo link. i had 7-10 times smaller pings at mt 3.30...
show us pings at 60/60 mbit or higher tcp traffic...
rpingar
Long time Member
Long time Member
Re: 802.11n
Thu Apr 08, 2010 7:25 am
My experience is the same.....
In all my links in N the problems is not stability, but latency and jitter when the real traffic goes above 25 mbps in one direction and 5 on the other.
ros
aaa
Re: 802.11n
Thu Apr 08, 2010 10:11 am
I don't have any dual nstream wireless link but I have many single nstream link and 802.11n latency is better at full load. I don't offer voceip service over wireless therefore 802.11n is very acceptable for me.In the immediate future I plan one 10km wireless link with 5GHz N and I can post results.
uldis
Re: 802.11n
Thu Apr 08, 2010 10:28 am
when enabling the encryption use only AES. Do not use the TKIP as it will be slow on the N.
angboontiong
Re: 802.11n
Thu Apr 08, 2010 10:37 am
Uldis..
we running on the MPLS, when the traffic up to the 23Mbps it getting 20ms ~40ms.
The link can up to 50Mbps, when and how we can have the improved RouterOS to implement the latency?
dieterk
Re: 802.11n
Thu Apr 08, 2010 5:48 pm
Hi Normis !
I have tested now with ordinary routed config...
2 x RB600 on my Desktop, copying files from LAN via WLAN 11n stable 20MHz:130/130 MBit btw. 40MHz:300/300.
No real change on throughput...
20MHz: 26MBit (a second File: 28MBit)
40MHz: 28MBit (a second File: 31MBit)
change to nstreme with special tricks ...
20MHz: 30MBit (a second File: 34MBit)
40MHz: 36MBit (a second File: 42MBit)
i think the bridge is not the problem. its maybe a SW design problem ... ??? The boards are unable to push the packets as fast as needed ... ???
So please can you give information whats the plan from MT ? I think this problem is well known, because it can be reproduced on a desktop. I have to change to other hardware platform, if there is no plan to solve throughput. And i don't want change ...
Dieter
JorgeAmaral
Trainer
Trainer
Re: 802.11n
Fri Apr 09, 2010 6:30 am
I have seen so many people complaining about N, but only a couple of them have achieved to get it working.
From my point of view, N is a completely new stuff, that we cannot just simply press buttons and hope it works.
It is completely different from a/b/g networks.
If someone really wants to build stable N links, first they should spend 90% of their time reading, and trying to understand what are those new options.
There is no magic configuration that can fit all needs.
My first recommendation is to search goggle for A-MSDU.
Then search for 802.11e.
Then, for those that complain about why normal wireless WDS has very low throughput, search again and see how the WDS frame is built, and if it is possible to build an A-MSDU with the wds 4 mac frames. "Probably there is a turn around".
Some things I have learned is that each time the link changes the tx/rx rate, you will notice jitter on the link.
Now its time to search for mcs table, and understand what all those codes stand for.
Because each mcs has 4 possible data rates when you enable ht-extension-channel, and for 2x2 antenna we can have 16 mcs, routerOS will have to chose between 64 possible data rates. a/g networks only have 8 data rates, there needs to be a very power full ap to calc all these on the fly. Most of us are working the RB4xx, so my recommendation is to first find what modulation works better for that link. When found, apply the mcs 1x1 for your modulation has ht-basic-rate, and apply the mcs 1x1 and mcs 2x2 for supported rates only. Then carefully adjust your hw-retries for the tx/rx rate to stable on max throughput.
How big is the MPDU on a wireless N link running full speed?
If you have 90% ccq with a link running 50Mbits/s full duplex, how much traffic in bits needs to be transmitted again each second?
Nice questions that all of us should goggle and understand it.
I hope I can point some of you to read, understand and help, instead of just simple copy paste and complain.
Kindly regards to everyone.
Jorge Amaral
0ldman
Re: 802.11n
Fri Apr 09, 2010 8:14 am
That was the source of my troubles.
The odd thing is after going to no encryption, the link still failed. Only after I reset the interface would it connect at HT speeds. I changed my encryption to AES and she's running quite well, though not significantly faster than my A/G networks.
Putting up new equipment and I'll be running MT N hardware, time will tell whether I'll run A/G or N, but as of today, the install is moving forward.
HaQs
Re: 802.11n
Fri Apr 09, 2010 10:28 am
OK :) But why ubiquiti "N" working fine with simple configuration ?
Maybe MT add wizard to simple configure 802.11n ?
ste
Re: 802.11n
Fri Apr 09, 2010 11:00 am
We are watching this "working fine" product and testing it.
It is simple unusable for an ETSI-Wisp at the moment.
But you make the point that they seem to do 11n much smoother
and that's what I am missing from MT too. They could start
with an exact documentation which tells what's all about 11n
and with a best practice guide with working examples which makes
us believe they have a successful Wisp-Like test setup.
Hey MT. Take a Wisp in your neighborhood, hire some students
and make a test-village-setup with 11n. So we all might learn
something.
dieterk
Re: 802.11n
Fri Apr 09, 2010 3:28 pm
Next Test:
Notebook -- RB600 --11n-- RB600 -- LAN (with servers and MTS)
2 x RB600 on Desktop like told above, 270/270MBit stable n11 link. Ping delay through the routing RB600 1ms to the LAN behind. very good :) - BUT !
Starting Bandwidht Test TCP "both directions", random data from Notebook to another (!) MT on LAN.
Throughput on the RB600: 23MBit/17MBit, app. 6Kpps, delay: 8-20ms (ping through link to other side)
Starting a second, prarallel Bandwith Text TCP "both directions", random data from Notebook to another (!) MT on LAN.
Throughput on the RB600: 24MBit/24MBit, app. 7Kpps, delay: 15-30ms
Starting Bandwidht Test TCP "receive only", random data from Notebook to another (!) MT on LAN.
Throughput on the RB600: 1MBit/32MBit, app. 4Kpps, delay: 7-11ms
Starting a second, prarallel Bandwith Text TCP "receive only", random data from Notebook to another (!) MT on LAN.
Throughput on the RB600: 1MBit/40MBit, app. 5Kpps, delay: 9-19ms
Load on both RB600 app. 45%
The UDP Test (RB600_to_RB600) brings unidirect 180MBit, 15Kpps, at delay time of 82ms (limit reached = OK)
The UDP Test (RB600_to_RB600) limited at 100MBit, 8-9Kpps, at delay time of 1-9ms (middle 5ms)
... it seems there is a bottleneck inside OS, which lets the RB600 to queue packets ??? and if the deley increases, TCP throughput limit is reached quickly ...
... because the packet transport within the WLAN seems to have more capacity than the boards/SW is able to push via the WLAN ...
so i dont understand that anyone is able to transport TCP traffic of above 50MBit via the 11n link... This seems not to be possible... The above limit at my test is 50MBit... And i can see that the problem is _not_ the WLAN setting. I think the speed of something inside the box ?!?
Am i wrong ??? please give input if i have an error in my conclusion .... there is no 11n understanding problem, i think...
Please an statement from MT. Thanks !
Dieter
gringoZ
Re: 802.11n
Fri Apr 09, 2010 4:23 pm
Next Test:
Dieter
yeap its impossible with latency like nstreme dual turbo link. i try everythink (1/2 chain, mpls/bridge/wds, 802.11/nstreme and other...) at rb433/600 and p3 1.2GHz tualatin. and... 15/15 mbit both tcp with ACCEPTED latency at level of nstreme dual or 25 mbit receive/send tcp. that is all that mikrotik can achieve with "n" card sending real traffic.... with low latency.
I do not need the bridge with latency/delay of 80ms, that bridge is unusable for voip/video transmission, online gaming.
I can ONLY ACCEPTED latency at level of nstreme dual (i mean ONE DIGIT LATENCY without non stop jumping to 30ms or worst times).
uldis/normis, i can send you my configs... mayby this help you resolve the problem...
OpiumDream
Re: 802.11n
Fri Apr 09, 2010 5:23 pm
Next Test:
Dieter
could you make a bandwidth test tcp and smal udp packets 100b parallel ?
post results
lawhitecross
Re: 802.11n
Fri Apr 09, 2010 5:37 pm
I cant seem to get my link working on N, cant seem to push more than 20mb/s send or receive, on both maybe 4mb/s
I am using 29dbi Poynting dual feed dishs, 433AH with 1 x R52hN on each board.
My conf is as below on my AP.
set 1 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
basic-rates-b="" comment="" compression=no country=no_country_set \
no disconnect-timeout=3s frame-lifetime=0 frequency=5390 frequency-mode=\
superchannel hide-ssid=no ht-ampdu-priorities="" ht-amsdu-limit=8192 \
ht-guard-interval=long ht-rxchains=0,1 ht-supported-mcs=\
hw-protection-threshold=0 hw-retries=4 l2mtu=2290 mac-address=\
00:0C:42:62:DB:6B max-station-count=2007 mode=ap-bridge mtu=1500 name=\
"Uplink" on-fail-retry-time=100ms periodic-calibration=disabled \
proprietary-extensions=post-2.9.25 radio-name=000C4262DB6B rate-set=\
default scan-list=5300-5600 security-profile=profile1 ssid=test \
set "uplink" comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17\
,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbp\
s:17,54Mbps:17,HT20-0:0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-\
6:0,HT20-7:0,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:\
0,HT40-7:0"
dieterk
Re: 802.11n
Fri Apr 09, 2010 7:11 pm
Hi OpiumDream !
UDP packets with 700bytes = 18Kpps, ping delay = 6-17ms (sometimes 2-3ms ?!?), cpu load 15%
UDP packets with 400bytes = 32Kpps, ping delay = 11-22ms (sometimes 2-3ms ?!?), cpu load 19%
UDP packets with 200bytes = 44Kpps, but "only" 60MBit throughput (air-limit reached), ping delay = 11-22ms
(some packet loss), cpu load 57%
the RB600 boards can do the UDP speed-test, push 44Kpps packets with 200bytes over the air at load 57% and route with a delay of 11ms all together .....
so the WLAN works very fine :-) and the OS works very hard but is able to process the requested stress ...
the only question is: where is the valve to get the speed which the 11n can do easily ;-)
it should be in packet processing to the wlan card and produces a delay which levels tcp communication to a slow speed. the boards and wlan cards have the ressources to do a good work, but something inside the OS stopps speed with queueing.
This is my mind for this problem ?!? i cannot see another explanation ..
Dieter
OpiumDream
Re: 802.11n
Fri Apr 09, 2010 7:43 pm
Hi OpiumDream !
Dieter
try mixed tcp and udp 100b packets
60mb is not a limit
i have 80mb full duplex turbo g link
rpingar
Long time Member
Long time Member
Re: 802.11n
Sat Apr 10, 2010 9:42 am
Next Test:
Dieter
I have to say that your experience pushed me to play with queue and changin the interface-queue of the wireless N, but i don't see any particular benefit shorting the queue on the wireless interface, I noted a little lower jitter but with some more packet loss on have charged N link. As i was expecting but this change.
Hope MT can improve the packet processing over N link soon. In fact I am pretty frustated by this situation.
regards
Ros
jrecabeitia
Re: 802.11n
Sun Apr 11, 2010 2:18 am
I accidentally commented a problem that I was presented with a link PTP r52N plates.
My setup was based on the selection of waveband N.
Change in the 5GHz and lost remote connection. So far so good. But I accidentally set the side stay bridge 5Ghz N only am station-side and 5 GHz and the connection works normally. This is what is very bad and may be a clue to why it does not work correctly in N.
exe
Re: 802.11n
Sun Apr 11, 2010 12:23 pm
I see that many of you complain on 802.11n latency and bandwidth.
When you say that latency is not better in 802.11n then 802.11a, you are very very wrong. Our experience is different. 802.11n link can handle more than dual nstreme at 802.11a with better latency: 1-3ms max.
In order to make ease for you, here is what we test successfully for live links with real internet traffic, without issues:
Let's imagine we have points A and B... A >10km> B
You need to configure like this (we are using ROS 4.5, Sparklan Wmia 198N MinIPCI and RB800):
Point A: Enable nstreme, put 5G only N, mode: ap bridge, remove all data rates, HW Retries 15, HT Chains: 0,1 both, HT Guard: any, HT Ext. channel: for example above control, HT Ampdu 0, HT Supported MCS: 0,1,2,3,4 .. HT Basic MCS: 0 .. WDS mode static, Nstreme: Enable Nstreme>Enable Pooling>Disable CSMA, Framer policy: Dynamic, framer limit: any from 2400-3000 ...
Create WDS interface for point B
Point B: All the same, just put mode: station WDS, enable nstreme and you are ready to go!!!
Try this, if you have good results it is okay, if you have poor result, choose better frequency.
If you have good signal you can enable mcs 5,6,7 .. try it...
This link can give 50M/50M without no problems with latency like in 802.11a dual nstreme .. If you have enough signal margin you can achieve more bandwidth. Latency will be very low: 1-3ms with real internet traffic of 30-35M ...
Signal must not be higher than -65 ...
Note: If you disable nstreme, link will not work.. If your distance between A and B is under 10km, then you can use MCS 5,6,7,8,9,10 and more but you need to determine this on both parts of the link. Just see what works stable with more bandwidth.
Optimization of 802.11n in ROS is not perfect and need more work, but this setup can work without issues. Just try it.
gringoZ
Re: 802.11n
Sun Apr 11, 2010 7:33 pm
please show screenshot with pings/lattency at 50mbit tcp bOTH
exe
Re: 802.11n
Sun Apr 11, 2010 9:18 pm
We cannot dismantle some live production links to show you bandwidth test like you want. So here is example with other link:
50/30 about 6km:
60/30 about 6km:
2jarek
Re: 802.11n
Sun Apr 11, 2010 10:34 pm
yada yada............. users use torrents, varez & voip no 1500b tcp one stream.
gringoZ
Re: 802.11n
Sun Apr 11, 2010 11:39 pm
50/30 about 6km:
where is wds at screenshot in interface list?
did you try r52n mpci?
dieterk
Re: 802.11n
Mon Apr 12, 2010 12:28 am
Ok, internal traffic (wlan,wlan) with bandwidth test is not really relevant...
real traffic or small packets via the _whole_ devices (lan-wlan-wlan-lan) show the problems.
nstreme has better delay time (better packet handling?) but is very unstable at 11n and not really supported. i can only get "stable" links on nstreme and 11n with fixed ack-times, data-rate-settings and noise-immuity. but on limits the nstreme link drops quickly...
i can get stable 11n links only on standard wlan mode, but delay on pass-through-traffic is too high, so tcp stopps throughput quickly... if the wlan-interface queue is shortened (thanks to Ros), the packet loss increases. so the delay is produced directly from the wlan-queue because it gets to limits... i also think that the problem is even present on 11a (and on other modes??), but the possible traffic wasn't ever high enough to show this problem clearly enough. nstreme performs better, and so _i_ get good performance on 11a (with standard mode i had also performance problems on my links ...!!!).
so i still see the real problem on packet forwarding to wlan driver and processing them. 11n wlan itselve seems to be fast enough (see results) to push the number of packets quickly over the air. so there is no real wlan-driver problem or a wlan-setting problem (at most links) ...
maybe RB800 is fast enough to keep the delay time low if there is the bottleneck on OS ... because of faster cpu and therefore better packet processing... and i only tried RB600 and RB433AH. But even RB433AH or RB600 should be fast enough to forward the packets quickly on low delay, because they can do this job easily on lan-interfaces... why not on wlan interfaces ???
this is my mind... has anyone a better view ?? what says the develpment team of MT ? are we really on the wrong way of understanding this long-time-problems of 11n ...
Dieter
WirelessRudy
Re: 802.11n
Mon Apr 12, 2010 1:55 am
?? Your examples show bandwidth tests from the rb's making the link. Not the optimum but OK, better than I ever reached.
But why not run a bandwidth test over your running ´live´ link? Just run it from routers outside the link (RB-test <->RB-Link>>>><<<<RB-Link<->RB-test). Make these "RB-test" boards fast ones, 433AH or better and run the tcp test, even when other ´normal´ traffic is around. Or transfer some big files up and down. And then show us the throughput over the wireless or ether port. Not the test throughput.
It only takes a minute which is long enough to show us screen shots of your link! If you have QoS properly configured on your network/link users probably won't notice you have don the test.
If we still see the impressive result I am really impressed.
Other remarks:
- According MT WDS doesn't work well on ´n´. It is been repeated several times here. Why should in now do on yours?
(And your examples don't show they are wrong. You made a test without WDS)
- Have you tried difference between ´nstreme´ on your ´live´ link enabled and disabled under idle conditions? I am still worried that under idle conditions ´nstreme´ is degreasing performance of link.
Can you please give us some more info on the wireless part.:
- Which power settings on cards (which cards?)
- receiving signal strengths (and are they fluctuating?)
- Connection rates. Do they stay stable under high and low data load?
- Environment: Free LOS? Fresnel? Other same band, or even same frequency radio's around?
- Only one card in the board or maybe second (or third)?
Before we readers can decide if your experience is real and usable we need lots more info.
I tried your settings, on much shorter distant link, 500mtr. as I did many times before with other settings, but 18/18 is about the limit. But OK, I am in a saturated air spectrum and even at such short distance with R52n card and 25dBi antenna can't get no more then -70 signal at the other ends..... (But ´a´ link running parallel, other channel, 15dBi ant and 433 (no AH) has no problem keeping 100-90% CCQ with 54Mb connection rate and even when I ´pump´ 25Mb over the link ping stays below 5 on average...)
And what did you mean with "Signal must not be higher than -65 ... "?
You mend not "better than" or "not stronger than" -65? So -60 or "lower" (-50, -40 etc) is advised?
Or did you mean "no more signal" than -65? So -70, -75 etc. is preferred??
I presume the first: "Not higher or worse then -65". So "lower or better than -65". (Thus -60.-55 etc)
Reason for my question for clarification is that your post put some things up side down. You make a statement about what is possible and then give an example not underlining this. Confusing as some other already noticed.
Only if we have all facts clear we can declare your statement as a bonus to this topic and us all.
asdewq
Re: 802.11n
Mon Apr 12, 2010 9:23 am
Hello, im new on this forum but using MT for a few years... I have one test N link in production use and there is big problems with jitter but... after post from exe i try his config - with WDS ands if i compare ap-client and wds link wds working much better. 11N on MT must be on totally free channel (nothing else cant be scanned, on freq use must be 0!!) so problem can be on small noise immunity too.. problem with driver desing? i dont know... but... on PtP link with WDS i have now nice latency (0-2ms) on 30-40Mbit with bt, 10-20Mbit of it was live traffic.
Insider
NstremeDual Issue
Mon Apr 12, 2010 11:36 pm
Hi, I have several issues question to MT development lounge.
We are doing quite good about links with N draft stands in 5GHz approx 45mbit both ways simultaneously in HD regime. But this is not our business.
I need help with Nstreme dual business.
I do use 2xRB800 with 4.5ROS
I met real issue about full duplex regime using N cards.
1/ With a simple layer (just one HT chain enabled) and 20MHz channel we do 65mbitHT on HW layer, works good bringing over 50mbit in TCP, which makes me happy. Either other way is linked by 65HTmbit regime..
My first question for MT Staff is: Why it pushes only 10 000 packages per second as max? Should I use some VPN to bundle it? Or just the drivers are not still ready.
My second question, which makes me really ill: If I use 2 cards, should I get twice the thruput on other side same time? NO? Why? Please help, I do understand, that tcp has its internal load, which lower the net thruput, but I estimate, that I should be able to do at least 45 mbits both ways simultaneously, What I am getting is 45/6mbits and that is it.. Or 35/35mbits with average latency of 10ms.. With ICMP flood thruput.
If MT will sort this out, I have ready transvertors for 10 and UP GHz working 8)
exe
Re: 802.11n
Tue Apr 13, 2010 1:39 am
This is screenshot of other part of link with station wds.
No.
There is no problem with any kind of traffic with our setup.
With our stability is very good... No issues. Don't enable anything which is not by default. Just use default settings and our setup.
No problem with 433ah and 411ah, we tried this also.. works perfect... But RB800 is the best.
Because Nstreme only works with WDS in 4.5 ... If you disable nstreme, link is not working. I do not know why, ask mikrotik: )
As I mention, our setup will not work if you disable nstreme. Performance is great. Just try it and test it. Then come here and tell me is it the best setup for now? :)) Also when you test it, make sure to test stability, you will see that it is better then dual nstreme 802.11a...
SparkLAN WMIA-198N and WPEA-110N. Default in mikrotik: 30-63mW.
No.
MCS's are stable, but you need to find the best combination for each link depending on distance.
You have so many other questions... Please try our setup and then report. You will be surprised.
WirelessRudy
Re: 802.11n
Tue Apr 13, 2010 4:01 am
Well, tried exactly your settings on 800mtr link. Signal is only -70 - -75!!! (With 21dB dish! Put normal 802.11 card and signals are around -45!!) and had the link running.
Started bandwidth test with 1/1Mb running
Then started to push up.
Reaching 15Mb was maximum while latency stayed < 7ms.
The moment I tried to push a bit more traffic one end router 433 (no AH) collapsed.
Router crashed, takes about 10 mins to recover. During this it is shown in wired connected neighbour with same network IP but not able to reach. Not even with mac. No ping, nothing.
Have to wait 10 mins and then router comes back up.
Look at log, is telling me nothing more that the router shut down due power outage.
But in looking at the other end during the 10 mins out of reach I do see the radio trying to make contact after 5 mins. Only after several attempts and 5 mins later link is established again...
MT reading this will ask supout.rif but it is not generated by watchdog.
WirelessRudy
Re: 802.11n
Tue Apr 13, 2010 4:12 am
Have been doing extensive reading to find out more about 802.11n.
One thing I came across is that on short backhaul links with high converged (high dB gain) antenna's (parabolic) and free LOS probably the protocol is not able to produce any more then normal legacy link would do in same condition.
Reason is that multiplex stream is hard to produce under such circumstances.
Since I am shooting with a 8 meter clearance over hard tiled concrete constructed houses I was thinking of actually pointing both side antenna's down a little so the radio beam is bouncing more (and reflecting) over the adjacent roofs and walls and thus producing more multipath radio streams.
Or maybe it is better to use lesser converged beam antenna's, even just some omni's?
Anyone any experience or say about it?
This is the piece of text I have been reading:
"An NxM MIMO system has N transmitters and M receivers (Figure 1). Signals from each transmitter reach each receiver via a different path in the channel. MIMO works best if these paths are spatially distinct and each is capable of carrying its own data stream. If the radios are within line of sight of each other, MIMO can deteriorate into the traditional single-stream transmission, SISO (single input, single output)."
[http://www.tmworld.com/article/323640-T ... 02_11n.php]
JorgeAmaral
Trainer
Trainer
Re: 802.11n
Tue Apr 13, 2010 4:48 am
I think your wireless card is damaged.
Can you test with another one?
Best regards,
Jorge
dieterk
Re: 802.11n
Tue Apr 13, 2010 11:54 am
ok, exe !
you are right ! this was the valve to speed the link to that what it can do ...
i can do a tcp-test with 65MBit/25MBit via the whole config (lan-wlan-wlan-lan) and have pings with 1-3ms
i can copy files nearly as fast as on LAN !
i can run tcp-BT and file copy parallel and have 82MBit/30MBit with ping delay of 1-5ms !!
this was the only config i did not test, because earlier versions did not work like this and everyone says that WDS is not possible to work :)
-- i use RB600 and R52N now --
in my routed-test-config on desktop, i have switched now simply to nstreme and WDS, did put my ips from wlan interface to bridge interface and had best performance i have ever seen ...
MT, the miracle is solved ! please check packet processing on _not_ WDS and _not_ nstreme ! everything else than WDS with nstreme doesn't work speedy and produces delay - it depends not on wlan drivers and special settings and 11n understanding problems ...
Dieter
exe
Re: 802.11n
Tue Apr 13, 2010 12:31 pm
ok, exe !
Great! You see now how 802.11n works!!!
I hope others can follow your example to test it in this way with our config!
rpingar
Long time Member
Long time Member
Re: 802.11n
Tue Apr 13, 2010 1:09 pm
ok, exe !
Unbelivable!!!!!!
IT WORKS ALSO FOR ME!!! after months of problems seems WDS (that could not work fine with N) fixed the packet problem!!!!!!!!
Many Thanks EXE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Regards
Ros
JrGong
Re: 802.11n
Tue Apr 13, 2010 8:19 pm
Ubiquiti doesn't actually support 802.11n.......
http://www.ubnt.com/forum/showthread.php?t=19949
It's actually the reason I am here. As much as I don't want to have to deal with licenses and such, I want a product that is going to be current for the foreseeable future.
dieterk
Re: 802.11n
yeah!!!
it also works fine on my production link with MPLS if i put the communications IPs for MPLS into the WDS bridge !!! ;-)
real traffic, which comes from hundreds of customers at 50MBit/20MBit with app. 10Kpps on this 5km 11n Link with RB433AH on 40MHz no problem ...
CPU load goes sometimes to 100% (i think because of nstreme eats much cpu) but performance is very good.
Thanks to EXE for this tip !! This work-arround brings the real 11n speed !!
Dieter
WirelessRudy
Re: 802.11n
Wed Apr 14, 2010 12:38 am
yeah!!!
Dieter, you mean you put the vpls interface in the bridge on the AP-Bridge side?
Do you also have the wlan port in the bridge?
On the station nothing changes apart from "station mode" >>> "station-wds" mode?
Rudy
marek001
Re: 802.11n
Wed Apr 14, 2010 2:02 am
ok, exe !
Dieter
how was the signal on that link?? and have you tried to push to max tcp speed??
we have on our some link's with nstream enabled and in turbo-a tcp speed like 48/30 Mbit..and if this is the max tcp throughput what can be achieved ,then this is disappointed..
as my N cards arrive i will test them..
tnx
for the good configuration...
bye
WirelessRudy
Re: 802.11n
Wed Apr 14, 2010 4:44 am
OK, I tried the "exe" settings as well and it worked for me too!
I still have to fine tune which mcs settings are best but OK, it's almost 4 AM and a new day is approaching....
I have now only 1,2,3,4,5,6 enabled on both ends and can maintain a 80Mb tcp data througput on the link while ping stays below 8ms.
I was not able to run mpls over the wds bridge. Got only one way traffic! So I threw it away!
When I enable all mcs values and no limit in the bandwidth test max. throughput (test between 2 rb1000's connected to the 2 rb433AH maintaining the link) I come close to the wire max. of 100Mb. but any total speeds above 80Mb sees the latency going up.
At 90Mb latency become in 200-350ms range and even saw at times data flow completely drop. But on a 10 mins run got 96Mb total throughput in one direction!
One way direction can have a bit more speed then the other direction. some 10% difference. I have to look into that.
But what an improvement! Before I was happy with 20Mb's total!
I'll play more later with several wireless settings (noise immunity? I have enabled, maybe better without?) and others.
I am also going to run cat6e cables and from the rb433AH's maybe bonding two interfaces to the rb1000's.
One thing I noticed while playing on this live link is in the middle of the night, when only some kbps of traffic around, it looks like traffic needs a bit of a kick start. When browsing it takes a second that nothing happens and suddenly everything goes flashing fast. Even new pages. But then I led the link become quiet and renewing already opened pages (so IP is still in cache) takes again a little time to start. But ok, that can also have many other reasons. Like I said, still some fine tuning to do.... :)
But good work done so far "exe"
MT, this guy should be awarded! (Maybe hire him! He solved a problem you guys obviously were struggling with for months....) ;-)
changeip
Re: 802.11n
Wed Apr 14, 2010 8:39 am
so in plain routed mode the issue persist, but without wds it doesnt? what about CCQ, is this affected by this setting? Seems unrelated, but curious.
rpingar
Long time Member
Long time Member
Re: 802.11n
Wed Apr 14, 2010 8:52 am
in routed mode just use the bridge interface instead the wlan1.
on bridge there is only one port the wla1n putting the ip on the bridge interface.
So you can workaround the packetization issue.
I see the cpu skyrocketing to 100% on high load but it is just a matter of power, we can scale with rb800.....
Then to MT guys..........hope you can fix the issue to have better performace without wds.
regards
Ros
normis
Re: 802.11n
Wed Apr 14, 2010 9:10 am
I read these new posts and though to my self - am I awake or still dreaming :D So, very cool that you found a working scenario. We will continue to work on the rest of the modes. Thanks for sharing, exe!
normis
Re: 802.11n
Wed Apr 14, 2010 9:47 am
We have an idea.
- Again turn off the WDS so that your link is not so good
- Then make a SIMPLE QUEUE with some abnormally high limitation on any interface in the router (ethernet will do, limit it at some 200Mbit so that it doesn't affect you), and
- see if wireless connection improves.
Additionally you have to change under "/queue interface" interface queue to something else and then undo the action, so SFQ really kicks in. It has to be done after each reboot.
We found that there could be an issue with one driver that doesn't load, and making one queue would call it up, increasing wireless performance.
We will include the fix in v4.7 if this helps.
ste
Re: 802.11n
Wed Apr 14, 2010 10:53 am
@Normis
Another Idea: Can the trial and error with data-rates done by ROS?
Especialy for PTMP when another CPE kicks in situation changes.
So some mechanism which watches CCQ and limits used data rates
to get more stability/less retransmit in links.
May be this mechanism is triggered by a client connecting/disconnecting
and then at a configurable time-intervall.
In my 11n tests I see if I allow a data rate which is to high the
link suffers very badly.
dieterk
Re: 802.11n
Wed Apr 14, 2010 11:32 am
yeah!!!
Rudy
Hi Rudy, you have to do this on Both sides !!
1) simply create a bridge on both sides, eg.: bridge-wlan
2) change to WDS on both sides: dynamic with this bridge.
3) move communications IPs which have been on wlan to bridge-wlan - both sides
4) change client side from station to station-wds mode
this works with all configs: routing, mpls, ethernet_over_ip tunnel, .... :-)
nice workarround ! nstreme optimization can be a little bit tricky to get really a stable link ...
rgds
Dieter
dieterk
Re: 802.11n
Wed Apr 14, 2010 1:10 pm
@normis:
i have tried queue, something changes but its not clear how it depends on ...
but there are more things wrong than "only" queue: even WDS with standard 11n brings no benefit.
ONLY nstreme on use with WDS brings the packets to fly over the air ...
and nstreme wlan-setting for 11n is tricky and should be made easier to get good results. we have to disable all the lower speeds, because e.g. nstreme likes to drop down the speed on wlan link and goes up slowly, so you will not get full speed if you don't optimize... only 11n standard mode seems to keep the highest speed on wlan, but packet throughput is very low !
it should be best if someone of MT development team puts 2xRB800 with R52n cards on his desktop, read our forum, makes a link without antennas, produce TCP packet flow via the whole equipment (lan-wlan-wlan-lan) with 2 additionally fast devices from outside. parallel ping through the link shows the delay very clearly.
and the problems will be seen quickly without spending any time on outdoor links !!!
thanks for solving this wlan problems quickly !
Dieter
lekozs
Re: 802.11n
Wed Apr 14, 2010 9:36 pm
Well... the Wiki ( http://wiki.mikrotik.com/wiki/Transpare ... using_MPLS ) clearly states that the WDS approach has some issues with 802.11n links> "802.11n speed is limited over WDS bridges" furthermore --> "this [MPLS/VPLS] method doesn't have such limitations"
This is the ONLY reason I did not even THINK about trying WDS with a 802.11n link! :(
So... I learned my lesson... Do not believe everything that is written in the Wiki...
This WDS method is working for me too... I don't know what are those limitations the Wiki is mentioning. I was reaching 122Mbps (heavy torrent downloads) yet the ping was somewhere around 2-3ms!
OTOH I decided to test this MPLS/VPLS transparent bridging on the ethernet ports of two RB600s (laptop-ether1-ether3-lan(MPLS/VPLS)lan-ether3-ether1-laptop) In other words I simply replaced the wireless cards and the 802.11n link with a LAN cable connected to ether3 ports.
It works flawlessly!
So - I assume - the problem is with the MPLS/VPLS implementation(?) over 802.11n links...
KillerOPS
Re: 802.11n
Wed Apr 14, 2010 9:52 pm
i'm just wondering why the last page of info didn't come from normis or some other mikrotik insider. Hey, mikrotik ppl, you should know what your code does.
WirelessRudy
Re: 802.11n
Thu Apr 15, 2010 1:07 am
That lesson is learned long ago.
Some MT guru should go with a comb through the wiki and filter out all the rubble that is put there and only creates more confusion.They should enforce a policy that any Wiki can only be published when confirmed and tested by tech. dept. And they have to be simple and explanatory for the unknown.
Example:
MT should make Wiki on how to a step by step set up a ´n´ link and mention and explain all variables in the wireless section that have influence.
The examples present are at least "incomplete" and outdated.
Is somebody checking on the value and/or validity of these Wiki's anyway?
changeip
Re: 802.11n
Thu Apr 15, 2010 1:27 am
im having the issues with N in plain old routed mode, no bridges at all, no wds, no mpls, just ap-bridge to station with IPs on each end...
dieterk
Re: 802.11n
Thu Apr 15, 2010 9:26 am
Hi changeip !
The problem should be the packet transport inside MT-OS to the WLAN drivers or via the drivers on all wlan modes except nstreme+WDS...
The ONLY workarround at this time is to use WDS in combination of nstreme !!!
BUT the good news: You can use this workarround on all other implemenations ....
bridging, routing, MPLS, EOIP, ....
1) switch to nstreme and WDS (bridge+station wds) on both sides and do WLAN optimizations as described by "exe" above. even if you use routed mode or MPLS or anything else ... the key is to put the link into the WDS bridge with nstreme and the communications IPs too !!!... Put only the LAN to the bridge too, if you want to impment a real bridge via the whole device (!!!).
2) put your communications IPs (as you had at wlan before, e.g. IPs for routing) onto that bridge, which is now connected to WDS... you always have to do this on both sides !!
and each config works with the workarround of WDS as requested and (!!) with full 11n speed ;-)
good luck !
Dieter
changeip
Re: 802.11n
Thu Apr 15, 2010 9:57 am
yes, i can confirm it helps in my situation to enable WDS+NStreme. All other settings remain yet the CCQ is much improved. I get a solid connection and pretty stable. I still don't get close to A turbo speeds, but this link also doesnt have the best fresnel. Latency went from 400-800ms to 20-30ms when running bandwidth test and performing a ping thru it.
My problem is that I have a few ubnt units associated that can't use nstreme, so i have to revert back to no nstreme... : (
gringoZ
Re: 802.11n
Thu Apr 15, 2010 11:27 am
50/30 about 6km:
60/30 about 6km:
i tried your config, i can't set signal worst than -56, you suggest not higher than -65:
good results with small latency (btest from mt to mt, ip 10.10.10.x is assigned to mt lan)
but
bad throughput with small latency (btest from laptop-mt to mt-laptop)
btest laptop-laptop i had "full" wire speed
where is bootleneck?
dieterk
Re: 802.11n
Thu Apr 15, 2010 1:10 pm
please take a look to the cpu utilization of notebook...
i think windows BT cannot give more on tcp speed test ...
check speed with an other MT (i have tested e.g. with an 750G) from the LAN side ...
gearth
Re: 802.11n
Fri Apr 16, 2010 2:46 am
We received a pair of 433UAH's and a pair of R52n's a few days ago to test (our first real world run with MT). I'm really quite pleased with the results and have actually routed some of our existing links through this one.
Currently, the ptp link is ~38km apart with 36" 32db dual-pol dishes at each end. Granted, there is still much to learn as I am accustomed to using different gear but I think that results speak the loudest. Using the built-in bandwidth test, I am able to achieve consistently between 160-170mbs with fairly decent latency.. sure, there are the occasional ping timeouts while running the bandwidth test but this type of traffic also does not reflect real world usage, "soaked" links should be expected to cause a ping to fail every now and then.
At the far end of the link there is a linux box running so that I can use wget to download a large and very compressed file through the link to represent something close to real throughput and it sits at a steady 80-90mbps which I find very impressive. Maybe this could be better with GbE but if demand rises past what is available then we have no problem spending the money to deploy additional BH links and have comfort knowing that we're not pushing cpu and individual radio usage to the point where performance and stability starts to go backwards.
As a note to those interested, I like to test throughput with my own test file with one end running linux and apache and the other end running linux and wget. The test file is simply the latest linux bz2 source download compounded as so 'cat linux-xxx.xxx.bz2 >> test.zip' and keep doing so until it is the size you'd like, I normally do this about 20 times to wind up with a file somewhere around 1GB so that it can download for a while and get a fairly clear idea for throughput and any jitter that there may be.
Keep up the good work guys, I'll keep tinkering.
Here's a screen cap of the udp test.
marek001
Re: 802.11n
Sat Apr 17, 2010 11:41 pm
May I ask your antenna configuration? Spacings and such
We got a guy that does our dual polarity feeders. Still testing configs but we are satisfied with a certain design that we are going to run a few batches.
We tested those with 80 and 100cm sat dishes. I guess a dual polarity Pac can do the job as well.
hi
i have try'd your config and when i add the value the card's just don't want to connect...
can you pls give me some screenshot from your winbox?? and sam ss from bandwith test, i just can't belive you got such great bandwith :)
tnx
bye
angboontiong
Re: 802.11n
Sun Apr 18, 2010 12:49 pm
I would say, the bandwidth test with UDP is always not the right way since that just "act like a show".
The best proven for 11N still based on the real time traffic.
-headstrong-
Re: 802.11n
Sun Apr 18, 2010 2:55 pm
Hi exe
Which antennas are you using? Are some vertical and other horizontal? how far apart are they?
Nikkit
Best Parabolic Antennas for 802.11N over 30KM
Sun Apr 18, 2010 7:20 pm
Hi There,
Please excuse me but I am a total newbie here. :lol:
Has anyone used Dual Polarity Pac Wireless 32dB parabolic? Will they work as well as Jirous 29dB Dual Polarity?
I would like to replace an existing 5Ghz link that currently has Pac Wireless 32dB dishes in place, the distance is 30KM and i can achive -55
signal strength using Turbo mode.
I would like to use the Pac Wireless Dishes as they're in place but I've been told the polarity seperation is very bad, :(
any help would be very much appreciated.
Kind regards,
nikki
chvdr
Re: Best Parabolic Antennas for 802.11N over 30KM
Mon Apr 19, 2010 5:41 pm
Hi There,
Kind regards,
nikki
im affraid, the signal level is not the most important thing at all. what about ccq @ existing link
Nikkit
Mon Apr 19, 2010 7:44 pm
im affraid, the signal level is not the most important thing at all. what about ccq @ existing link[/quote]
Thanks for the reply, CCQs look very good, the link distance is 30km I'd like to use rb52hn and rb800 at either end
Thanks again,
Nikki
Axiom
Mon Apr 19, 2010 10:29 pm
We use those dishes on a 19mile link. -55 at either end with 80's-90's CCQ. Noise around -105 on both ends. Throughput is a little less than 80mbit (tested one way, hdx). The collapsed dual-pol design on one dish won't give you the best performance but they're space efficient, cost effective and easy to install. So, how much speed do you need? If ~50meg give or take, will do, the dual-pol radome is convenient. If you need more speed then you'll want to use seperate dishes with spacial separation.
But as was previously stated, the most important element is environment. Do you have low noise and available channels? If yes, you should be fine with whatever antenna system you select. If not, the best antenna won't be much help.
-Nelson-
2jarek
Tue Apr 20, 2010 3:42 pm
Hi There,
Kind regards,
nikki
802.11n no need perfect polarity separation
wehrhard
Re: 802.11n
Tue Apr 20, 2010 8:30 pm
I tested today the "Exe-Config.
2 x RB411AH, 2 x R52hN, 2 x Mars 24,5 db Dual Polarity, Distance 25 km, LoS, very noisy enviroment, bridge mode, Btest over both RB411AH, Antenna on one side "off beam" due to lack of "second" man. I think it will bring 6 db more, if the antennas are correct justated.
Results:
20 Mhz Bandwith, 25-30 MB TCP, MCS4 stable Connection, Signal -69 to 72 db.
40 Mhz Bandwith, 45-55 MB TCP, MCS4 stable Connection -70 to 74 db.
Do not use WEP or WPA/TKIP. It slows downt he speed . WPA/TKIP 50 % slower and WEP 25 % slower. I used WPA/TKIP and there was no speed loss.
It works. Thanks to Exe.
I will go "hot" next week....
Regards
Wolff
ste
Re: 802.11n
Tue Apr 20, 2010 9:56 pm
Results:
Regards
Wolff
http://www.funknetz-hg.de
You should stay anonym with this signal values :D
marek001
Re: 802.11n
Tue Apr 20, 2010 10:49 pm
Results:
Regards
Wolff
is this 45-55Mbps at same time to both sites?? or just 55mbps to one site (half duplex)
tnx
bye
wehrhard
Re: 802.11n
Wed Apr 21, 2010 12:26 am
Everything is half duplex. One direction....
-headstrong-
Re: 802.11n
Wed Apr 21, 2010 9:57 am
does exe's config work on v4.6? I'm using it successfully on v4.5 but cannot bring down the link to test
Nikkit
Wed Apr 21, 2010 10:08 am
-Nelson-
dieterk
Re: 802.11n
Wed Apr 21, 2010 1:13 pm
Hi !
We use 4-6 and it works with workarround ...
I hope 4.7 has included full speed on all modes !
@Normis: has MT seen the problems on delay is is working on it ?
Thanks for information !
Dieter
gringoZ
Re: NstremeDual Issue
Wed Apr 21, 2010 3:16 pm
how much cost that converter? could you show how it looks like?
Insider
Wed Apr 21, 2010 4:09 pm
It has exactly same shape like this one (a bit other guts inside), except that this one is for full duplex radiolink like Ceragon, Dragonwave and Carriercom are with speed up to 350mbits full duplex.
http://www.facebook.com/photo.php?pid=2 ... 0085712801
Price is negotiable, depends on band and output power. But know that this should be like expansion box for ROS, once guys fro MT will improve Nstreme Dual
gringoZ
Wed Apr 21, 2010 4:42 pm
please pm your email. i would like to start negotiations on the price ;)
angboontiong
Wed Apr 21, 2010 5:58 pm
Would you mind to share with us how it's work?
and how is the connection for this?
Insider
Wed Apr 21, 2010 7:39 pm
Simply said, it is top notch technology up converter for transmitter with amplifier and down converter for reception with purity to pass thru cca 512QAM signal if needed. Then there is separator of transmitter from receiver to not jam the receiver (something like diplexer). Than it has detector to transmit exact power out (not estimated) and tuners to make transmitting within bound of cca 1GHz bandwith - lets say 1O -11GHz (the case you can see). Nice thing is that you loose about 1/2dB at all on input, because there is amplifier directly on receiving dipol. This feeder can be part of parabolic antenna which works like amplifier. With approx 60cm antennas you can do 20km link with Pout 2mW.
It is connected by 2 cables thru adapter (which is by the the MT board) to LNC (Low noise converter)
-headstrong-
Wed Apr 21, 2010 11:19 pm
me too please
digicomtech
Re: 802.11n
Thu Apr 22, 2010 5:24 pm
30 km 5 Ghz link over water: lake St-Jean, Qc, Canada
The ice on the lake is melting and vapor in the air make signal instable during sunny day. We test a new setup with:
- SR71-15 on each side;
- 2 antennas 23 dB on each side;
- one horizontaly polarized and the other vertically polarized, space diversity 10 feet vertical;
- freznel zone on one side pass near tree head;
- rate 802.11a desactived;
- supported HT MCS 0-4 Basic MCS 0;
- Channel 5400 Mhz with DFS;
- Hw. Retry: 15;
- On fail retry time: 100ms;
- Extension Channel: above control;
- NStreme;
- RouterOS 4.6.
TCP speed test with BT (CCQ ~100/100%):
- 45 Mbps in send;
- 20 Mbps inreceive;
- 20/20Mbps both.
Signal is weak: -75 but when sun get down it reachs -69
Thanks to MT and exe for the tip (always try at lower rate, and add higher rate progressively watching the CCQ)!
I have try the same setting on a 60 km 5 Ghz link. Historicly this link had always failed to get decent speed in receive. Signal is good -65/-65 but CCQ suffer in RX. Using NStreme have fix the RX problem passing from 250 kbps Rx speed to 14 Mbps, but signal drop often below -80 (often in fall and spring when the lake is melting or frozing during the sunrise or the sunset) and some time signal don't drop but CCQ does so the link disconnect (in summer cause by thermoducting over the lake). Recently we have try SR71-15 card instead of XR5:
- SR71-15;
- 1 antenna 32 dB on each side;
- other settings are the same as above;
- signal is weaker: -75.
TCP speed test with BT (CCQ ~70/70%):
- 31 Mbps in receive;
- 30 Mbps in send;
- 20 Mbps both.
I will give a try on 5beta1 as 4.7 package is broken...
Insider
Re: 802.11n
Thu Apr 22, 2010 5:30 pm
My own experience is that water surfaces are really big big big problem for radiolinks. On all frequencies.. Especially on long links..
digicomtech
Re: 802.11n
Thu Apr 22, 2010 5:52 pm
Canada Mirror package 4.7 is OK !
I will try it as soon as my signal will get back to -69...
Now is -80 :( but i'm still doing 10/10 Mbps TCP in a both BT test...
digicomtech
Re: 802.11n
Thu Apr 22, 2010 5:59 pm
20/20 Mbps TCP in a both BT test when i use supported MCS 0-3 (disable MCS 4) !
Axiom
Re: 802.11n
Thu Apr 22, 2010 6:48 pm
We've had better luck with R52n's than the SR71's. We tried the 71's...excited about the 3-chain ability. But in our testing, while the 71's work "fine", throughput and CCQ is consistantly better on the R52n's. Our testing has not been exhaustive and we don't have enough hours on the 71's to make a conclusive call (and there's a lot of new variables with MIMO testing...in our application we were running 3 chains at the AP, 2 on the clients [happy to accept advice on MIMO configurations btw]) but first impressions...R52n's a better card. If it's easy to do I'd be curious to see your results on that same shot with a card swap.
-Nelson-
exe
Re: 802.11n
Thu Apr 22, 2010 9:39 pm
It works, but we experienced some issues with x86 and RB800 wrong temp value and some kernel problem if minipci-e slot is used, so we use v4.5 for now...
If you have Rb433ah or rb411ah you can use v4.6 without problems by our experience.
hallsys
Re: 802.11n
Fri Apr 23, 2010 12:57 am
i have 802.11n link 22km. signal -55/-57. ccq 90/97. bandwidth 105mbps/50mbps. But, after some time ccq drop to xx/30% and bandwidth is about 30mbps. all is on ROS 4.7.
I disable/enable radio card and ccq is again 90/97%. :(
why ?
marek001
Re: 802.11n
Fri Apr 23, 2010 1:03 am
witch config do you use??
rpingar
Long time Member
Long time Member
Re: 802.11n
Fri Apr 23, 2010 9:11 am
we tested 4.7 on RB800 and it is shoing high latency on high load using plain station mode without bridge;
At the moment the best config for us is 5.0beta1 and EXE's config (station-wds).
regards
Ros
ste
Re: 802.11n
Fri Apr 23, 2010 10:56 am
regards
Ros
Tested it today on RB411AH/R52N/4.7 seems to look much better now.
exes config worked and it looked like wds is no longer needed.
Nstreme+AP/Bridge to plain station mode I see constant bandwith
79/79 UDP and pings constant below 20ms (better when limiting the
bandwith test).
Tests running on the RB411AHs.
I see 48/48 TCP. But CPU is at 100% so this might be faster.
I tested in lab. Disable CSMA does not make a difference.
So the main problem is/was packet handling in the kernel and
the datarate selection mechanism?
wdca
Re: 802.11n
Sat Apr 24, 2010 12:14 pm
Hi all!!!
I have been testing a lot lately the N-Bridge(http://www.cyberteam.pl/produkt/show/944.html) product from cyberteam in production enviroment.
The results are quite interesting.
The results are adequate to the test that is located at the ct page
http://www.cyberteam.pl/artykuly/conten ... 32505.html
The thing is that the nstream and the pooling policy runs much more greater but it is still behind airmax :(
Hope that routeros will squeeze much more (in near future) from the 802.11n standard that in this moment .
Greets all!
gringoZ
Re: 802.11n
Sat Apr 24, 2010 5:56 pm
cpu at laptop1 - btest server 60-80% - (ibm thinkpad x40, lan intel 1gbe switched to 100 mbit full duplex, winxp)
cpu at laptop2 - btest client 60-80% - (samsung r522, lan marvel 1gbe switched to 100 mbit full duplex, win7)
when i changed role of laptop1 and laptop2 (client to server) cpu usage were the same
rest of screenshot (packet 64-4000 both/receive/send)
http://www.postimage.org/image.php?v=Tsc_t3S
http://www.postimage.org/image.php?v=Tsc_y39
http://www.postimage.org/image.php?v=Tsc_Ayi
http://www.postimage.org/image.php?v=Tsc_D2r
http://www.postimage.org/image.php?v=Tsc_FxA
http://www.postimage.org/image.php?v=Tsc_KwS
http://www.postimage.org/image.php?v=Tsc_N10
http://www.postimage.org/image.php?v=Tsc_Pw9
http://www.postimage.org/image.php?v=Tsc_S0i
http://www.postimage.org/image.php?v=Tsc_Uvr
http://www.postimage.org/image.php?v=Tsc_W_A
http://www.postimage.org/image.php?v=Tsd00ZS
http://www.postimage.org/image.php?v=Tsd03u0
dieterk
Re: 802.11n
Sat Apr 24, 2010 7:19 pm
Hi GringoZ !
Your notebook works fine :) (i had the problem with slower notebook and 100% load and therefore low tcp speed)
its interesting, that you get slower speed (as you explained on page14) via the whole devices with good ping ... i have no answer because low ping should have good tcp throughput up to the limits when the delay increases... so where is really your bottleneck ?? did you check with MT devices too ? there i had 90MBit tcp via the config MT_TEST -- RB600 -- n11 -- RB600 -- MT_TEST.
Dieter
mars
Re: 802.11n
Sat Apr 24, 2010 10:59 pm
hi
we have a n link and i hope you can help me to set it up
we have a r52hn card at both ends with 2 grids 1 horizontal and 1 vertical at both ends
we used your settings but only get up to 117m on 1 side and the ccq is only about 60/60
the problem is we can not figure out how to line up the grids as when we move them there is no difference in the ccq
is there a special way to line up the grids and check the ccq when doing the alignment for the hn card
any help would be welcome
thanks
-headstrong-
Re: 802.11n
Sun Apr 25, 2010 1:01 am
hi
thanks
enable chain 0 and disable chain 1 then align
disable chain 0 and enable chain 1 then align
Then enable both
mars
Re: 802.11n
Sun Apr 25, 2010 12:36 pm
That is what we did but still no joy. Moving the grid does not change the signal at all.
Do you have to plug the grids in the same connector in both sides?
Ours is horizontal grid to middle connector (chain0) and vertical grid to side connector (chain1).
Edit: I see you are from South Africa as well. Is there any way to get in touch with you, as I'm not having any luck with the alignment.
-headstrong-
Re: 802.11n
Sun Apr 25, 2010 4:06 pm
hmmm then I might be doing things wrong aswell then...lets see what others say
exe
Re: 802.11n
Mon Apr 26, 2010 4:07 am
thanks
Change frequency and try then. Use dual polarization antennas. 117M is very good with current optimization in mikrotik.
npero
Re: 802.11n
Mon Apr 26, 2010 6:48 am
Is someone try to test speed using only one chain, single polarity antenna ? If someone try please post result.
Thanks.
Trisc
Re: 802.11n
Tue Apr 27, 2010 2:17 pm
Thanks.
Yes - 2km link RB411 - RB532A using R52ns in Pacwireless 18dB Rootennas:
Testing by downloading 350Mb file from FTP server on LAN we get steady 50Mbps with pings below 10ms. CCQ is 90-100% signal is -65dBm
Interestingly using Jperf we can run multiple UDP streams across this link giving approx 75Mbps but latency jump to 150-300ms.
Using Exe's configuration but Nstreme set to Exact, 2500.
colebert
Re: 802.11n
Tue Apr 27, 2010 6:52 pm
Greets all!
I am surprised to hear this. In all my testing (long distance PtP links) Airmax is obviously the inferior protocol vs nstreme. No doubt.
cmurrayis
Re: 802.11n
Wed Apr 28, 2010 3:00 pm
Greets all!
Care to Explain how so? In my testing it's been the opposite way around, Aurmax just "works"
colebert
Re: 802.11n
Wed Apr 28, 2010 9:11 pm
Greets all!
Does Airmax just work at 40mhz on a 25 mile link?
Does Airmax just work at 20mhz on a 40 mile link?
Does Airmax have better latency and jitter than nstreme?
No, No, No is the answer at this time. Don't believe me? Stop by the ubnt forum and see the complaints for yourself. The new beta firmware has helped some with jitter but wake me up when Airmax works as well for long distance ptp links as nstreme. Can I get airmax to work? Yes. It's "working" right now in a degraded capacity on about half of my links but it's pretty obvious for my links that airmax is the inferior solution.
I have all kinds of problems with Airmax on the majority of my PtP links with one or two notable exceptions. But when I replace my balky Airmax links with with Mikrotik/nstreme solutions they work just fine. Mikrotik has it's own issues and is not perfect when it comes to their form factor and design of their units, but when it comes to running a smooth PTP link there is no contest in my experience. I am counting down the days, hours, minutes, and seconds until I can get my links all moved over to nstreme.
I will give you just one example. 26 mile PTP link. Put a Bullet M5s on each of my dishes. Airmax on, no ack, 40mhz channel, mcs7, etc. Terrible CCQ (40s, 50s mostly), 17% airmax capacity, 30 something % airmax quality, jitter and packet loss all over the place. Have to bust the link down to 20mhz, turn off no ack, set the ack time out manually, just to get a stable link with jitter on it. Keep in mind this is out in the country, way up in the air, on a professional microwave tower, giant Andrew dishes, clear fresnel, etc. Airmax should "just work" here but doesn't. I can squeeze out about 17mbps of TCP traffic if I'm lucky. Bring in Mikrotik with RB411AH/SR71-15 and nstreme, keep everything else the same. Perfect 40mhz channel, 99%+ CCQ under load, 60 to 70 megs of aggregate TCP traffic. We have a winner.
Obviously this is just one link but I can provide more examples that follow this same sequence. In fairness I do have one Airmax link at is about 36 miles and working solidly with 40mhz and no ack. I get 30 megs EACH WAY (60 megs aggregate). But this is the exception and not the rule for Ubiquiti products on my PTPs which is why they are being retired before I ever really started using them.
wdca
Re: 802.11n
Mon May 03, 2010 11:09 am
1. Bullet M5 is 1x1 not 2x2.
2. I've had tested 433ah <> intel atom with r52n 2x2 vs bullet m5 1x1 @12km NOS.
The mikrotik HT speeds must have minimum -65 rx/tx to work. On the bullet m5 i've have got 84mbit-HT on -76 signal. On this signal i've reach 30/30 fdx tcp. The disadvantage of the airmax devices are weak processors :(
conjurer
Re: 802.11n
Mon May 03, 2010 6:11 pm
They are not weak. Connect to bullet via ssh, and run "top". The are just enaugh for wireless. Mikrotik is suited for more.
Muqatil
Trainer
Trainer
Re: 802.11n
Mon May 03, 2010 9:20 pm
I'm Back on this topic, since long time.
I tried once again a live link (lab links aint interesting :lol: )
It's a short link, 5KMs, exe's configuration (thanks exe) but with dynamic wds and hw-retries=4
Looks good even today, in a rainy day.
It supports max 50mbit FD, then the ping rate raises a little.
Looking forward to make a 100mbit FD
colebert
Re: 802.11n
Mon May 03, 2010 11:54 pm
HW retry=4 ??
angboontiong
Re: 802.11n
Tue May 04, 2010 7:33 pm
There 2 thing to clear...
1) You only can show 25Mbps half duplex but no full duplex man....
2) You test i believe is with UDP instead of TCP, look at you CPU...
Muqatil
Trainer
Trainer
Re: 802.11n
Tue May 04, 2010 11:24 pm
That's not a test, that's live traffic.
Do you really need a screenshot of a btest as proof of my words?
I prefer to avoid to overload that link, since my customers might complain..
And as i wrote, i would like to make it work better, if i could know how..
Before 4.6, the jitter and the disconnections were my problem, now at least is working as a nstreme dual link, but 40mhz smaller :P
I'll make soon another N link, maybe with larger antennas and RB800 to see what happens..
frontiersteve
Re: 802.11n
Thu May 06, 2010 7:47 pm
Maybe you should try it Non Nstream with the new beta 5.02 as there are supposedly some improvements in it for ptp.
thrill123
Re: 802.11n
Fri May 07, 2010 7:54 pm
Hey colebert,
I just received a 5.2BETA-8 firmware from one of their devs. This version fixes all the issues you are talking about.
If you want to try it out just email them.
conjurer
Re: 802.11n
Mon May 10, 2010 5:11 pm
I noticed that PtP link works best without airmax.
exe
Re: 802.11n
Tue May 11, 2010 12:50 am
Here is the homework for wireless. Link is at 2km, using rb800 and sparklan wpea-110n and our config posted on this forum. Link is stable using 2 chains under v4.5 ... UDP test at 200.1M ... Real internet traffic achieved is between 180 and 190M downloading from rapidshare... Check picture:
aaa
Re: 802.11n
Tue May 11, 2010 3:16 pm
Hi, nice results. Can you test this link with 50-100 customers load without taffic restriction ?
marek001
Re: 802.11n
Tue May 11, 2010 9:08 pm
how can i open the attachment??
what kind of antennas do you use??
tnx
bye
dieterk
Re: 802.11n
Wed May 12, 2010 12:49 am
hi all ... back again ...
today i have tested a backup backhaul link (simulated drop out of our fibre link) for our network (1400 wave customers connected via 11a behind). The MTs (2x433AH (!!) with R52n at 40MHz and dual polarity antennas via 3km) worked at 70MBit real traffic (voip, file-sharing, all others) at 10kpps and with delay of 2-4ms without any problems or disconnects. I think more traffic is possible at same delay and faster boards e.g. RB800 are available -- Thanks to exe's config one more time :) with this special optimizations the 11n link works best... the product is very very great ! BUT ...
i don't understand that since 4.5 release (now we have 4.9...) and some weeks of qualified reports in this topic, NO official statement of MT did come about the real problems ... the 11n works great now, but only (!!!) on nstreme with WDS (still the official forbidden config for 11n!) and additionally optimizations (work arounds) for nstreme ... till today ... and the problems with all other non_working_configs are reproducable easily on desktop devices ... why doesn't fix MT the real problems inside OS with packet handling and wlan-speed-sense on all 11n modes and why does noone give a statement about problem fixing procedure inside OS. Is this really sooo hard to do ??? i don't understand the policy because this handling gives frustration and speculations to change to other available products on the market ... and this is really NOT necessary because 11n on MT works - now !
hopefully waiting for a statement of MT ...
rgds
dieterk
normis
Re: 802.11n
Wed May 12, 2010 10:27 am
nstreme with WDS
no, 4.9 fixes the issue and wds should no longer be required. this was true for earlier versions. check the changelog.
rpingar
Long time Member
Long time Member
Re: 802.11n
Wed May 12, 2010 10:42 am
i tested 4.9 and wds is still required to get the best performance in terms of speed and jitter.
regards
Ros
dormador
Re: 802.11n
Wed May 12, 2010 8:41 pm
tnx
bye
same Q !!
thrill123
Re: 802.11n
Thu May 13, 2010 1:23 am
Try out the latest 5.2 beta firmware and check latency when passing traffic. With AIRMAX-on I get under 10ms latency sending 90Mbps TCP traffic on a 6 mile link. With AIRMAX-off its about 35ms but the thoughput is 15 megs lower.
kandidat77
Re: 802.11n
Fri May 14, 2010 11:27 am
Have anyone tested of "N" with Nstream on 2.4 Ghz?
In a comprataively "radio clean" environment..
hallsys
Re: 802.11n
Fri May 14, 2010 8:34 pm
yes
i test link with airmax and with homework antena and airmax no good !
frontiersteve
Re: 802.11n
Wed May 19, 2010 9:17 pm
Was anyone able to open the attachments on the earlier post? :?
dieterk
Re: 802.11n
Wed May 19, 2010 10:43 pm
yes, but only on: May 11 :-)
aaa
Re: 802.11n
Thu May 20, 2010 8:08 am
Same. Normis can you check what's happen with attachment?
sergejs
Re: 802.11n
Thu May 20, 2010 11:08 am
Normis is on vacation.
I guess the problem is with exe post on 11.05.2010.
It seems the attachment was deleted (it is not possible to find on server), so we should ask exe to upload it one more time.
exe
Re: 802.11n
Fri May 21, 2010 1:33 am
Here it is again:
marek001
Re: 802.11n
Fri May 21, 2010 12:44 pm
but this is utp traffic...
can you send a picture of tcp troughput??
tnx
bye
exe
Re: 802.11n
Fri May 21, 2010 6:11 pm
Yes...
Here is the real traffic, downloading from rapidshare:
marek001
Re: 802.11n
Fri May 21, 2010 6:22 pm
i just don't understand how you do this..i have the exact same config as you describe and i have try'd with alot other antenas and change my rb433ah with c2d PC's and still nothing..
can you post your config again??
tnx
bye
exe
Re: 802.11n
Fri May 21, 2010 10:23 pm
with 433ah you cannot achieve this..
You should not use x86 PC because there is hardware incompatibility with some motherboards .. You should use mbs which is proven to work good with mikrotik and upgrade your bios to the latest version.
Use RB800 on both parts of the link and you should not have any problem.
Configuration is exactly like in this thread.
chronos
Re: 802.11n
Sat May 22, 2010 1:31 pm
I am testing two RB411 now in bridge and can't get 200 Mbit UDP which I achieved about year ago with bridge with RB600A and RB433AH maybe at that time routeros 4.2.
Current setting and condition:
- indoor test
- Two RB411 with R52N, routeros 4.9
- bridge, WDS, 5 GHz-n, hw. retries 3
- signal is good, CCQ is good and stable over 90%
- link speed is i 270 Mbit HT and estimated P throughput is 150 Mbit
- 300 MHz CPU is not overloaded, usage about 30 % caused partly by test itself
- routeros UDP test goes up to 47 Mbit, speedtest.net mini measured 37 Mbit TCP
Why max. real UDP throughput is only 50 Mbit then it should be 200 Mbit?
Is this some limit of RB411 even CPU is not loaded too much?
Weird thing is that link speed can't get to 300 Mbit HT, only 270 HT even with good signal.
5GHz a mode real UDP throughput is 29 Mbit with good CCQ and 54/54 Mbit link speed, real TCP test using speedtest.net mini measure about 23 Mbit TCP
There should be some magic setting somewhere.
I have to buy another RB600A or other more powerfull board to repeat earlier tests and compare results.
mishaM
Re: 802.11n
Sat May 22, 2010 3:01 pm
Here is the configuration of maximum stability of Align,
mindaugasr
Re: 802.11n
Sat May 22, 2010 8:14 pm
I have same issue with 270HT mbps. My link also never connect at 300HT/300HT. All time is connected on 270HT/270HT. Can anyone tell me what's wrong in my config?
Very Thanks.
- indoor test
Insider
Re: 802.11n
Mon May 24, 2010 9:02 am
Very Thanks.
- indoor test
Something is not OK.. My own experience is that 65mbit HW makes 60mbit thruput, 121mbit HW makes 95mbit thruput, as count as counting 270mbit has to make at least 210mbit thruput in layer2.. There is inter chain problem.. I will work this out next month
dieterk
Re: 802.11n
Mon May 24, 2010 8:29 pm
Hi !
it seems that 4.9 runs on PTP now without "exe's special nstreme optimizations" for data rates. i have configured 2 PTP links, one with RB433AH and one with RB800, R52n at 5GHz, 20MHz and 40MHz. Both links are stable and best throughput. ATTENTION: it seems that 4.9 also handles the data rate setting other than the versions before ?!? i did't get a link on the manually configured WLANs after updating to 4.9...!!!! with standard speed settings it worked fine ...
So the mayor reqirements are from my view today:
- free channel
- nstreme and WDS as explained on many last posts (everytheng else doesn't perform well)
- set hw-retries at 15 (it helps to get betst stability for PTP)
- additionally i use adaptive noise immunity
nothing else ...
if i put traffic on the link, the wlan speed optimizes itselve now from A-rates to maximum HT rates quickly. Ihe link is very stable, no disconnects. Throughput is best. because of CPU power RB800 performs better and you can see the possible tcp speed with bandwith-test on the same devices. On RB433AH the packet forwarding is fine but don't test with tcp-bandwidth test on same devices... !!! cpu goes to 100% and you will get bad results. but the link itselve can perform good also an 433AH! (i had real traffic with app. 90MBit without problems)
with this configuration you can get very fast throughput you have ever seen at 1-4ms delay. no problem for voip & co...
so it is now much easier to get good results without optimizing. only nstreme and WDS is absolutly necessary !!
rgds
dieterk
npero
Re: 802.11n
Sat May 29, 2010 11:00 am
I also tested 802.11n this mooning.
On production link simple replace UB5 on both side with R5nH and pigtail cable use some setting like before nstreme enabled, WDS static other side station WDS, adaptive noise immunity ap and client mode all like before on 5Ghz turbo link. Both side 4.9
Mode 5Ghz-a/n and change one new thing HT extension channel above control.
Noting special to configure.
And here is results.
Compare to 5GHz turbo link much better speed simple replace only minipci card. Before TCP test one side usually 60-65Mbps now is 80-95Mbps.
I like 802.11n :D is work good with only one chain (antena).
I will try to replace some others link and try 2,4Ghz-n.
mars
Re: 802.11n
Sat May 29, 2010 2:57 pm
hi does anybody know what the distance between 2 grids must be to use 2 chains 0n each side
thanks
couresportivo
Re: 802.11n
Tue Jun 01, 2010 9:55 am
Has anybody had good results with PTMP 11.N.
pleas epost configs and any info
Erastus
Re: 802.11n
Tue Jun 01, 2010 10:35 pm
thanks
A "good" distance ( rule of thumb) is 30 cm for 5G scientific calulation may show different but 30 cm woorsk fine
THat is for different channels not mimo
jbowsher
Re: 802.11n
Fri Jun 11, 2010 5:35 pm
I have tried everything from one card with only one chain to bonding 2 eoip tunnels and i cannot achieve anywhere close to the speeds that you guys are seeing. I have tried the forum configs that everyone has been using. I have even tried using MPLS/VPLS tunnels and i am at wits end. I am using 2 rackmount networking appliances (x86) they have 3.66 Ghz processors so that should be plenty of power i think. I will say that i have tried both the ubiquiti SR 71-15 and the Compex WLM200N5-26 cards and also the R52N's. I do believe that there is a problem with the btest in mikrotik when using it on a pc because the test results between the boxes was horrible but if i put my laptop on one and a RB1100 on the other end the wireless link will give me 80Mbps receive to my laptop before the RB1100 CPU is maxed out 100%, but my laptop single core 1.6Ghz intel would only send about 40Mbps before my CPU was maxed out. So I decided to try file transfers between two laptops accross the ptp link and then i saw something even more odd.....granted my test laptops only have 100Mb NIC's but i figured if i max them out then i would try something with gigabit NIC's, but when transferring files simultaneously being that these are 100Mb full duplex NIC's in the PC's i should see about 90Mbps both ways or so i would think. The traffic would stick at 50-54Mbps(bi-directionally) nothing shows a lot of CPU usage (laptops or network appliances) and both laptops would show 90% utilization of their NIC. I have found that Dual Nstreme is a flop and i have not had any good results with nstreme turned on period. WDS doesnt seem to perform as well as VPLS or EOIP tunnels. Just looking for some insight and guidance to make this work like it is supposed to. Also, all tests have been performed on RouterOS 4.9. Thank you in advance for any help or advice that you can give.
chvdr
Re: 802.11n
Sat Jun 12, 2010 8:37 am
culd you more recently introduce situation - antennas, distance and what system you use (routerboard, pc)...
chvdr
Re: 802.11n
Sat Jun 12, 2010 8:42 am
because our results were terrible in a similar configuration - pcs with 4.9 ar71 cards, 5GHz-a/n, 15km, etc... 80Mbps but if test on single direction (transmit or receive). if direction = both, 12bmps/300Kbps (!!).
Thus discussed many times on forum. They said that this is interferrence and we wait for nstreme improvement.
Erastus
Re: 802.11n
Sat Jun 12, 2010 10:13 am
AM I correct that you work from MS to MS
Or is it that you work from MS to the router board. You will find that certain test will max the cpou out but when you work through the MK then you get better through put.
look at this link http://www.mikrotik.com/download.html down load the windows speed test tool and see what you get from either pc
If dual nstrem gives a problem try by setting the routes to the ip on one cahnnel for up and then on the other channel for down. Use two different freq 1 for up and 1 foe down.
When we use it like this we get good through put.
Alos try and get you signal strength low like below -55 we find that the greater the signal the better the communitcations.
Would be nice if MK will increase the power to +/- 400 mW so that the loss could be compensated for. Call it a R52H+n card.
I am quit sure this was discused previuosly.
chvdr
Re: 802.11n
Sat Jun 12, 2010 11:45 pm
What is MS? And MK.
dantasik
Re: 802.11n
Tue Jun 15, 2010 4:29 pm
Im testing N ptp. I achieve 130Mbit UDP. Signal was -45dBm. data rates 270Mbps-HT.
Now i move that ptp to anothe site. At this moment signal is -61dBm. Rates are from 216Mbps-300Mbps.
I use RB600A and RB433AH.
If im testing bw on localhost i can push 300-400mbit UDP on RB433AH, but on RB600A localy i can push only 90-100Mbit UDP. If im turn off the N interface i push 300-400Mbit also. Maybe litle bit less - doesnt matter.
But in every case the CPU is not loaded to 100%. Is there some other limitations?Bus for example or something else?
herbicidal
N-Mode 83KM Test - Impressive
Wed Jun 16, 2010 2:54 am
My performance results using the following hardware
2 RB433AH
2 RB52Hn
Using Version 4.10
Dual Polarity 4' Dishes (Not sure on the exact db)
Distance 83KM
Frequency 5700
With 2nd Channel (40mhz width)
Using Nstreme and WDS
Signal level is between -59 & -63 both directions.
Resulting link is stable operating at 108.0Mbps-HT in both directions
Have not yet hooked up the second chain so I am operating only with one antenna on each end, not using the dual polarity antenna.
Disabled a few of the lower mcs rates to improve initial connectivity otherwise it seemed to bounce around with funny (lower) signal values for a while.
Results are impressive though
48Mbit throughput TCP on the bandwidth test tool
56Mbit throughput UDP
Currently of a hundred or so links on our network, this is the fastest link with the highest throughput, and also has the longest distance. 8)
Ping times large packets are under 4ms
Tried setting it up in mpls/vpls bridge mode as per the wiki, performance dropped dramatically down to approx 10Mbit.
Have not tried the beta firmware as this is a production link. My older redline radio is sitting idle (radio off) on the second polarity as a backup for now.
0  R name=wlan1 mtu=1500 mac-address=00:0C:42:64:2C:2C arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name=000C42642C2C mode=ap-bridge ssid=NG-HH area="" frequency-mode=superchannel country=canada antenna-gain=0 frequency=5700 band=5ghz-onlyn scan-list=default rate-set=configured supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none wds-mode dynamic wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0 ht-guard-interval=any ht-extension-channel=above-control ht-supported-mcs=mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-basic-mcs=mcs-4,mcs
-5,mcs-6,mcs-7 ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 hw-retries=15 frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
ste
Re: 802.11n
Wed Jun 16, 2010 10:06 am
Yes. Things get more solid now. Running a single-chain 5,5GHz R52n connection 44MBit UDP FDX 8km.
RB411AH to RB600 R52n. Nstreme without WDS. 5b3 to 4.10. No data-rate settings.
taduikis
Re: 802.11n
Fri Jun 18, 2010 1:52 am
Did someone resolve the issue of not getting max layer2 throughput?
I've managed to successfully setup 802.11n p2p link with such configuration:
Both ends RB433AH with R52n hooked up to 2 x 23db panel antennas in different polarizations.
One set to bridge, other set to station mode. 5GHz-only-N mode. All ordinary data rates unchecked. NStreme disabled.
Antennas are perfectly aligned with previous dual-nstreme setup and in N mode get signals -50/-51. CCQ of the link is always around 96-100%, and P throughput bounces about 98mbps. Link is extremely stable, counts high uptimes.
Since I'm limited with 100mbps ethernet, I'm totally happy with 100mbps of real wireless throughput. However I cannot achieve speeds higher than about 30mbps through layer2 bridging. Strangely bandwidth test from winbox itself shows 96mbps in UDP and 56mbps in TCP (which I'm sure is limited by routers CPU ability to generate that much of TCP packets, because it hits 100% during the test).
I've tried numerous different configurations, including WDS, Nstreme, tried everything mentioned in this forum, etc.. The results vary from very unstable link with quite good throughput (but still no more than 60mbps) to low data throughput and so on.
Currently I've sticked to MPLS layer2 bridging solution described in this article:
It works really great and looked very promising at first, but unfortunately doesn't give me that much of throughput I previously had with my 5GHz turbo setup..
Maybe someone could give some suggestions or share their experience in setting up a 11n link with demands described above?
I shall soon post some sshots and sketches to get the picture more clear, because I do believe I'm not only one here experiencing such issues. This new N standard has a lot of potential and I'm looking very seriously to it as for replacement of current 11a links :)
dieterk
Re: 802.11n
Sun Jun 20, 2010 1:18 pm
Hi taduikis !
With nstreme and WDS (both are still necessary !!) and 4.10 you should reach best performace, if you have really free channel and good link quality. Sometimes it is necessary to reduce output power and seperate channels very carefully. But the max-throughput shows you the possible throughput which can nearly be reached .... if this value is good and stable, the link is good ...
You can reach the maximum throughput with every configuration scenario (even with MPLS) but ALWAYS put the communications IPs into the WDS bridge !!! or use only the bWDS bridge ... Do NOT (!!!) as shown in this WIKI article !!! - it works NOT as required. Please read the posts (many of them describes the problem and the workarround) carefully - this works really !! The problem is still the packet handling on most modes, which will produce delay. And this delay reduces the tcp speed quickly. You can see this problem if you look at the ping delay times if you reach your limit which can be 30-40MBit at the wrong settings ...
You can see the success if you have delay times of 1-4 ms even above 30-40MBit. Then the speed rises up to the limits of CPU power of the boards and the WLAN-Link restricts. Then you have opened the delay-bug-valve ;-)
I have 100MBit and more. Some others have nearly reached 200MBit at best conditions and fast boards ...
good luck !
DieterK
chvdr
Re: 802.11n
Sun Jun 20, 2010 6:15 pm
wds and nstreme?
it works?
dieterk
Re: 802.11n
Sun Jun 20, 2010 7:47 pm
YES ! try it ... only this mode works great ! because there is still a packet-handling bug inside the current ROS 4.10 which produces delay on WLAN links if you don't use nstreme and WDS bridge together ... this produced delay at 30-40MBit traffic - which is present on other modes - limits tcp speed because of tcp protocol implementation ... and we all would be very very happy if MT would not ignore this problem and fix this bug and/or give a stetement about problem-fixing in near future ... many people would not run into the same problems ... AND this WIKI article referring the "necessary" 11n configuration with MPLS shows the WRONG way (!!), it doesn't help and it doesn't work at required throughput ... you don't need MPLS or anything else, the key which you need this time is: nstreme and WDS ... and if you use tunnels, or routed mode, communications IPs must be inside this WDS brdige ...
: this is the workarround !
chvdr
Re: 802.11n
Sun Jun 20, 2010 8:54 pm
yeah! i'll try it.
i meant that if n mode switched and nstreme enabled there is worst results. if nstreme disabled - interference kills everything...
on the other hand, i don't like wsd links, 'cause wds decreases performance.
because of that your last post is very interesting for me
chronos
Re: 802.11n
Mon Jun 21, 2010 7:51 am
Indoor test with good signal.
Without nstream speed is up to 30-50 Mbit and link is stable. Max. link speed 270/270Mbit-HT.
With nstream speed in UDP can go up to 200 Mbit on 300Mbit-HT link speed and TCP tested with iperf go up to 97 Mbit in one direction limited by 100 Mbit ethernet interface and up to 65 Mbit TCP in both direction but link it is much less stable and sometimes link start droping. hw-retries could influnece stability in matter of retransmits.
It is usable but not stable enough for me.
taduikis
Re: 802.11n
Mon Jun 21, 2010 2:47 pm
Yeah, with so many settings in control, there exist numerous different configurations.. I could say that "kitchen tests" performed indoors hugely differ from real results when trying to set up the link outdoors. With all the equipment laid on the table, even with WDS+Nstreme everything looked very promising. Not so when put in real action.
I've picked the channel very carefully according to the spectrum usage to avoid interference and so on. Antennas are perfectly aligned, so I dare to say they are not the reason of poor link quality, because in plain 802.11a they show signal around -45 dBm bothways.
One end is obviously always set to bridge mode. And here's the interesting part: when another end of the link is set to any kind of station mode - it works great, I've got heavily loaded link running for 4 days without disconnection now. Set the mode to station wds and everything collapses, signals start to be in -70 range, frequent disconnections with "extensive data loss" reason, nstreme enabled or disabled doesn't make any difference. When running in station mode, enabling the nstreme doesn't help either, link becomes unacceptably unstable. Though without nstreme everything runs just fine - tx/rx rate indicates 130/130mbps-HT, P throughput ~98mbps, latency is <= 1ms and slighlty increases while on load, which is understandable.
Actually I don't really care what mode to use as long as I get the desired results. Currently I'm using the MPLS solution only because it allows transparent bridging solution while in station mode. And in station mode only I get that perfect stability..
I am hoping somebody could explain why I can see 95-105mbps UDP and 55mbps TCP throughput while using winbox bandwidth test utility when testing the throughput to the IP of the wlan device on either station or bridge end and cannot get more than 30mbps through transparent layer2 network bridge. Maybe it has something to do with bridge settings?
dieterk
Re: 802.11n
Mon Jun 21, 2010 5:59 pm
hi taduikis !
you cannot get more than 30MBit, because ROS has a problem inside ... it is not to set-up, it's to fix fom MT ;-)
we all have same resultes ... the standard mode and station mode (also on nstreme) cannot push more mbits over the air, because it increases the delay on traffic. you get 20-30ms (the higher delay is NOT OK on traffic !!) at 30MBit and therefore tcp cannot send more traffic, because its communications protocol sends as fast as it gets answers from the other side ... and delay reduces throughput automatically to "not overload" the line and get packet loss ...
only nstreme+WDS handles the packets (this time) as fast as required to communicate at 1ms with the oter side on traffic too ...
i have now 4 outdoor links with 11n running at nstreme+WDS at 5 GHz !!! :
2 x RB433AH (R52, single chain, 23dbi-Antenna, 3km, above control, 135-150MBit-HT) = real tcp traffic 100MBit tested
2 x RB433AH (R52, single chain, 23dbi, 5km, above control, 135-HT) = real tcp traffic 100MBit tested
2 x RB600 (R52, 2 chains, 23dbi dual polarity, 3km, above control, 270-300MBit-HT) = real tcp traffic 130MBit tested
2 x RB800 (R52, 2 chains, 23dbi dual polarity, 1km, above control, 300MBit-HT) = real tcp traffic 150MBit tested
you need:
- 4.10 (update board-firmware too: "/system routerboard upgrade")
- free channel(s)
- maybe reduce tx-power
- 5 GHz-Only-N
- "bridge" or "AP bridge" one side
- "station WDS" other side
- WLAN WDS settings: both sides within the bridge
- nstreme !
- (on use with MPLS both communications IPs for MPLS not on wlan-interface it MUST be in the wds-bridge-interface)
- hw-reties: 15
- (i use) adaptive noise immunity
- maybe above control, if you want to use 40MHz for double-speed ...
the link should be stable on nstreme too, the link wasn't stable on ROS versions before 4.10 !! on 4.10 i had only disconnects on nstreme on too high power settings and/or interference from neighbour channels ....
please check again, it should work !!!
dieter
taduikis
Re: 802.11n
Tue Jun 22, 2010 3:28 pm
I understand what you're trying to say. Believe me, I've tried everything, read lots of forums..
Whatever I do, I'm not able to reach anything over 30mbps. Your described setup with NStreme + WDS doesn't give me that either.. In addition it turns my link quite unstable, lowers CCQ and P throughput. Tx-power tunning is not necessary, because any change gives lower link quality than with leaving everything on default.
And what's more, I am starting to believe it's something in the bridge itself, because with your suggested WDS+NStreme setup I can measure ~80mbps UDP and ~40mbps TCP from winbox bandwidth test tool. Both sides have IP's assigned to corresponding bridges.
To help to understand everything, I've drawn illustration which also shows my intended setup:
The Internet connection does provide 100mbps at any time to my test location. I'm sure of it, because when connected directly to my laptop it always gives what it is supposed to give.
dieterk
Re: 802.11n
Tue Jun 22, 2010 6:22 pm
Hello taduikis !
i understand your problem. the bridge-delay-problems inside ROS stopps your traffic at 30MBit and nstreme is unstable at your configuration. maybe there is another problem at your link... please remember that nstreme sends a lot of polling packets and if there is a problem in the link (reflections etc...) nstreme can tilt over more quickly than standard modes. and 11n is additionally more sensitive than 11a ...
do you really have 4.10 ROS installed and updated firmware ?? if not - it is clear for me, that nstreme doesn't work on your config.... if yes - i think you have to optimize your antennas, frequencies etc ... sorry cannot say anything else ... the config i have posted above (please check each point carefully) works great at my location an some different links. and your 30MBit limit is the known ROS bug which produces delay on traffic from LAN to WLAN through the routerboard, i can only solve this problem with nstreme+WDS this time ...
rgds, dieterk
OpiumDream
Re: 802.11n
Tue Jun 22, 2010 7:12 pm
2km link with rb/600 and r52n.
95m full duplex tcp traffic achieved, test was from notebook to notebook with 100m ethernet.
That’s not a limit I think. Anyway outstanding result !! great work MT!!
one problem is that sometimes link disconnects and log entry appears ‘not polled for to long’
without nstream polling link is not working as good as with polling.
Could someone advice how I can correct this?
taduikis
Re: 802.11n
Wed Jun 23, 2010 12:00 am
OpiumDream: it was explained a few times in this thread.
dieterk: yes, all my RBs are 4.10 with upgraded bootloader.
Well, I guess I'm on my own with this one..
OpiumDream
Re: 802.11n
Wed Jun 23, 2010 6:10 am
i found posts which mentioned that N and nstream is not compatible but i had same 'not polled for to long' on pure A links.
maybe MT ppl can tell us how to solve this ?
on pure data links it's not a big problem if 1 ping will be lost but on links carrying call center voice traffic its catastrophe :(
taduikis
Re: 802.11n
Wed Jun 23, 2010 12:35 pm
Check very first pages of this topic, there was something mentioned about your problem. After upgrade to 4.10 I don't see any of those.
P.S. I'm still hoping to hear out some bright ideas about that bridge throughput :)
Users browsing this forum: No registered users and 48 guests
