• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
Solving 20km wireless link issues  Page 3 of 3
 [ 111 posts ]  Post new topic Reply to topicGo to page Previous  1, 2, 3
  Print view Previous topic | Next topic
Author Message
opalit
 Post subject: Re: Solving 20km wireless link issues
PostPosted: Sun Mar 11, 2012 2:28 am
Offline
This is something I am getting over my 6k and 1k links, it has been happening for about 5 weeks, always between 4:30 and 8:30 PM GMT, the spectrum anylyser shows interference across every single channel of the 5Ghz range, it is across the whole range and lasting about 5 mins max, it knocks out all the bridge links but not the AP's, except I am using Ubiquiti, that is why I have just purchased the Sextant radios to see if they are working any better.
Could it be the solar flares.
Top
 Profile
shadowskippie
PostPosted: Wed Mar 14, 2012 10:18 am
Offline
at a regular time and daily?
I have never known the sun to be that specific with it schedules.
Anyways, it may be something else, but i doubt it is the sun.
One question though, I'd like to know if those sextants work better then the UBNTs, i'm trying to get my boss to use the Mtik equipment over the UBNT equipment for transparent links
Top
 Profile
esfahanweb
PostPosted: Wed Oct 03, 2012 4:48 pm
Offline
it's clear that sextants work better then the UBNT
Top
 Profile
Basiley
PostPosted: Sun Dec 09, 2012 8:17 pm
Offline
maybe something industrial/military ?
or commercial stuff improperly installed ?
If you had spectrum analyzer, GNURadio, WinRadio with this band module and etc - you can actually get some details.
but generally only feds had hardware and experience to locate this both in time, frequency and location.
maybe worth contacting your region communications suprevisors/inspectors.
generally NOBODY should shouting with SUCH transmission power on ISM bands. ever !![in civilian time]
talking about YOU case - such bands and such outputs - usual[similar] to radio-relay stations and [Especially!]for tropo-scatters. some mobile Tropo stations [usually military/gov't]use, despite small size - output measured in KW and even MW !! [but more densely occupied tropo was in K-Band]. Radars can do too, but they working on persistent basis, except some space-sensing and other specific, so wouldn't be related to timed/sheduled issues/troubles.
p..s
remind me one story when overloaded cell station with improperly installed[broken] bandpass filter severely cripple other stations nearby and even wi-fi in proximity.
Top
 Profile
CyB3RMX
PostPosted: Mon Feb 11, 2013 7:31 am
Offline
Im running Ubiquiti 90 degree 5GHz sectors 19dbi with 711GA-5HnD as an AP, and have hooked around 30 sextants and 15 SXT 5HnD and the farest SExtant its at 13.2 km from the ap and have a -72dBm and a 14mbps throghput. They work like charm with nv2 and dual chain enabled.
File comment: This is the actual rate and signal of a sextant at 13.2 from the ap (ap uses a 19dbi sector antenna)
sextant.PNG [ 930 Bytes | Viewed 495 times ]
_________________
Trying to route the world... Hehe
Top
 Profile
CyB3RMX
PostPosted: Mon Feb 11, 2013 7:34 am
Offline
p..s
You are replying to someone?... i get lost with your reply.
regards.
_________________
Top
 Profile
Degun
PostPosted: Fri Mar 08, 2013 7:32 pm
Offline
Hi sir. I don't think i am suppose to say this but i am just sharing my knowledge out. may be it might help. Well i am a guy who is mostly with the surfboard but i have learned that the more distance a connection has from the centre of the company or i guess its called the portal, the less the speed you get. Even i have experienced it out. Just saying. Might something be like that.
_________________
Gold Coast surfboard rental
Top
 Profile
snowwhiteeg
PostPosted: Thu Mar 28, 2013 9:48 pm
Offline
wirelesswaves wrote:
http://www.ips.gov.au/IPSHosted/NCRS/wars/wars2002/proceedings/comm-f/screen/kerans1.pdf
http://sirkova.com/documents /ICEST_2003_Short_Distances.pdf
seo egypt
http://www.its.bldrdoc.gov/pub/ntia-rpt ... hap1-3.pdf
شركات التسويق
http://www.dxinfocentre.com/propagation/tr-modes.htm
شركات التسويق الالكترونى
Some of the above links are tiring reading, especially the third. For 30 years I played around with VHF communications, exploiting the uses of all known التسويق الإلكترونى propagation phenonema, including meteor scatter and moonbounce.
Maybe as I suggested, نشر موقع its not equipment related in any way, just that the freznel zone has given you less than your first expectations, and on the days of 20dB extra, your signal is actually enhanced.
The last link is the simplest explanation from us radio ham chappies
73's EA5/G0MGA
thanks alot for the links , i had a goog info from them :)
Top
 Profile
Cal
PostPosted: Wed Apr 03, 2013 1:17 am
Offline
Top
 Profile
lemontree
PostPosted: Fri Apr 19, 2013 11:20 am
Offline
Given that it suddenly changes and if you see that sudden 20db change on all channels, you should look into the equipment. I'd check the pigtails and coax. Also, I'm not a fan of those antennas for backhaul links (much prefer Radiowaves or Andrews parabolics).
Buy D3 Gold | RS Gold
Top
 Profile
filipearaujo
PostPosted: Sat May 04, 2013 9:02 pm
Offline
never will work u need put more high the antenna is ground on the moutain fresnel
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 3 of 3
 [ 111 posts ]  Go to page Previous  1, 2, 3
Board index » RouterOS » Wireless Networking
Users browsing this forum: No registered users and 10 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
