Do the MultiPoints use the same SSID or is there a config like the WDS we use now and does NV2 pass MACs across the bridge?
Just need to know where to look at a sample NV2 config.
Thank you,
Rod
MptP is nothing more then an AP with two (or more) clients. Off course they use the same SSID. If not we talk different wireless networks.Do the MultiPoints use the same SSID or is there a config like the WDS we use now and does NV2 pass MACs across the bridge?
Thank you,
Rod
