Hi to all,
what does item Bridge Mode: in wireless interface means?
I'm using AP bridge and I'm wondering does this have to be enabled or disabled?
Thx, Petar
is there a speed limitation using WDS?Has the same speed limitations because the 802.11 frame is still built with the 4 mac.
802.11a/b/g/n standard frame is composed by 3 MAC.is there a speed limitation using WDS?Has the same speed limitations because the 802.11 frame is still built with the 4 mac.
My recomendation would be the two devices on AP-Bridge mode with wds between them, but do not add the wds interface to any bridge.ok,
can this vpls tunnel be set up between two AP bridge wireless interfaces running 802.11b/g?
I actually need two tunnels to transport two different hotspot networks.
Any advice on that?
Petar
[admin@MTK4] /mpls ldp> print
enabled: yes
lsr-id: 10.0.0.4
transport-address: 10.0.0.4
path-vector-limit: 255
hop-limit: 255
loop-detect: no
use-explicit-null: no
distribute-for-default-route: no
[admin@MTK4] /interface vpls> print
Flags: X - disabled, R - running, D - d
B - bgp-signaled, C - cisco-bgp-signale
0 R name="VPLS -> MTK5" mtu=1500 l2m
arp=enabled disable-running-chec
cisco-style=no cisco-style-id=0
pw-type=raw-ethernet
1 R name="VPLS -> MTK3" mtu=1500 l2m
[admin@MTK4] /interface bridge port> print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether1 MTK4 -> BDHM 0x80 10 none
2 VPLS -> MTK5 MTK4 -> BDHM 0x80 10 none
3 VPLS -> MTK3 MTK4 -> BDHM 0x80 10 none
