Code: Select all
0 R name="AP" mtu=1500 mac-address=00:15:6D:64:4D:55 arp=enabled interface-type=Atheros AR5413 mode=ap-bridge
ssid="Call.623-640-7883" frequency=2462 band=2ghz-b channel-width=20mhz scan-list=default
wireless-protocol=unspecified antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=RioVistaAP compression=no
/interface wireless security-profiles print
1 name="AP" mode=dynamic-keys authentication-types=wpa-psk,wpa2-psk unicast-ciphers=tkip group-ciphers=tkip
wpa-pre-shared-key="Whatever" wpa2-pre-shared-key="Whatever" supplicant-identity="AP"
tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none static-key-1=""
static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0
static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no
radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
radius-mac-caching=disabled group-key-update=5m management-protection=disabled management-protection-key=""
