Hi netrat,
thanks for your reply.
I believe you brought me closer to where I need to be, but I am not quite there yet.
I added the VLANs as per your suggestions and the configuration is now as per below:
AP:
VLAN Interfaces
[stefan@STA-STW-Master] /interface> vlan print
Flags: X - disabled, R - running, S - slave
# NAME MTU ARP VLAN-ID INTERFACE
0 R vl5wired 1500 enabled 5 ether1
1 R vl3wired 1500 enabled 3 ether1
2 R vl66wired 1500 enabled 66 ether1
3 R vl66wireless 1500 enabled 66 wds-STW
4 R vl5wireless 1500 enabled 5 wds-STW
Bridge ports:
[stefan@STA-STW-Master] /interface> bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 vl3wired brVlan3 0x80 10 none
1 wds-OCB brVlan3 0x80 10 none
2 vl5wireless brVlan5 0x80 10 none
3 vl5wired brVlan5 0x80 10 none
4 X wds-STW brVlan5 0x80 10 none
5 vl66wired brVlan66 0x80 10 none
6 vl66wireless brVlan66 0x80 10 none
IP addresses:
[stefan@STA-STW-Master] /ip> address print
# ADDRESS NETWORK BROADCAST INTERFACE
0 172.31.255.253/28 172.31.255.240 172.31.255.255 vl5wired
1 10.10.1.193/28 10.10.1.192 10.10.1.207 brVlan3
2 192.168.8.99/24 192.168.8.0 192.168.8.255 vl66wired
Station (STW):
VLAN Interfaces:
[stefan@STA-STW-Remote] > /interface vlan print
0 vl66wired 1500 enabled 66 ether1
1 vl5wired 1500 enabled 5 ether1
2 R vl5wireless 1500 enabled 5 FNC-STW
3 R vl66wireless 1500 enabled 66 FNC-STW
Bridge ports:
[stefan@STA-STW-Remote] > /interface bridge port print
0 vl5wireless brVlan5 0x80 10 none
1 I vl5wired brVlan5 0x80 10 none
2 I vl66wired brVlan66 0x80 10 none
3 D FNC-STW brWds 0x80 76 none
4 vl66wireless brVlan66 0x80 10 none
IP addresses:
[stefan@STA-STW-Remote] > ip address print
0 172.31.255.252/28 172.31.255.240 172.31.255.255 vl5wireless
1 192.168.8.54/24 192.168.8.0 192.168.8.255 vl66wireless
Station OCB is working fine as it is with the wds-OCB going straight to the vlan'd bridge on the AP, i.e. no VLAN config on the station side there.
Interestingly enough, the of the STW station from the AP seems to work alright:
[stefan@STA-STW-Master] /ip> neighbor print
# INTERFACE ADDRESS MAC-ADDRESS IDENTITY VERSION
0 wds-STW 00:0C:42:2B:A9:D7 STA-STW... 4.17
1 brVlan66 192.168.8.54 00:0C:42:2B:A9:D7 STA-STW... 4.17
2 brVlan5 172.31.255.252 00:0C:42:2B:A9:D7 STA-STW... 4.17
However, I cannot ping across or get any Layer3 traffic going accross the link.
Any ideas?
Thanks,
Stefan
