• MikroTik.com
  • RouterBOARD
  • User Meeting
  • Training
  • User Manual
  • Support
  • Downloads
  • Videos
Register |   * Login | HOME
View unanswered posts | View active topics
Different signal strenght rx/tx with dual chain  Page 1 of 1
 [ 8 posts ]  Post new topic Reply to topic
  Print view Previous topic | Next topic
Author Message
brainy
 Post subject: Different signal strenght rx/tx with dual chain
PostPosted: Thu Mar 22, 2012 11:54 am
Offline
Hi there,
someone has an idea what is causing this strange signal strengt?
LOS is ok, distance is ~250m One side is SXT, one side is OmniTIK (screenshot was made on the OmniTIK side) Both sides using "card-rates" with power set to 20 to prevent a too strong signal.
Regards,
Joerg
Top
 Profile
rodolfo
 Post subject: Re: Different signal strenght rx/tx with dual chain
PostPosted: Thu Mar 22, 2012 12:45 pm
Offline
could be:
1. a different propagation from H to V
2. something in radio/pigtail/calbe/antenna
you could discriminate from this two cases, polarizing antennas at 45°. If is the cause 1 the difference must fall near 0.
(remember: some sxt seems to have a problem in chain 1)
Top
 Profile
MrBoni
PostPosted: Thu Mar 22, 2012 7:21 pm
Offline
@brainy I have the same problem. Same setup - OmniTik on one side, SXTs (and 711s) on the other. Also, same as me, you have different CCQ levels on Tx and Rx (97% vs 44%).
Don't know about you, but I'm not getting any more throughput if I enable chain1 on SXTs. It's like 2x2 MIMO isn't doing it for me.
If anybody has an idea, don't be shy to share it with us :)
My thread is here: viewtopic.php?f=7&t=60325
Still no reply.
Top
 Profile
czolo
PostPosted: Thu Mar 22, 2012 10:12 pm
Offline
Still no reply.
Maybe it's stupid - but try to rotate the SXT for 90 deg.
_________________
-= Czo|_o =-
Top
 Profile
rodolfo
PostPosted: Fri Mar 23, 2012 2:42 pm
Offline
@MrBoni
your problem (ccq) is very different from brainy (dbm)
in your case could be an interference problem
Top
 Profile
MrBoni
PostPosted: Fri Mar 23, 2012 9:10 pm
Offline
rodolfo wrote:
@MrBoni
I have both low CCQ and different Tx/Rx signals levels!
Why do I have interference? I tried to change the frequency multiple times with no result.
I'll try that. But, if I may ask, why would that make any difference if both devices (OmniTik and SXT) are dual polarized?
Top
 Profile
DynStatic
PostPosted: Sat Mar 24, 2012 4:07 am
Offline
MrBoni wrote:
rodolfo wrote:
@MrBoni
It won't make a difference if it's dual pol, however if happens after turning it 90 degrees you've ruled out a hardware problem. You can have interference on only one of the poles from a device that's single pole.
Top
 Profile
lazerusrm
PostPosted: Tue Mar 27, 2012 6:08 am
Offline
As Above,
Interference can play a large role when you have significant Signal strength variations chain to chain. Interference / Multipath reflections can also cause problems here.
Run a spectral scan, then try out several different channels, and if you notice that the previously low signal chain gets higher signal levels on a different channel, then you have most likely
some interference.
Top
 Profile
Display posts from previous:  Sort by
Post new topic Reply to topic  Page 1 of 1
 [ 8 posts ]
Board index » RouterOS » Wireless Networking
Users browsing this forum: fleegle and 8 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
Karma functions powered by Karma MOD © 2007, 2009 m157y
