I've followed the WISP guide to link two SXT 5HnD up with great results (just on a tested link on the floor for the moment).
The SXT our end is on the 192.168.100.x range.
During the test's ive bridged it according to WISP article and setup default route on the remote SXT and can traceroute etc. However where the remote SXT is going it's on 192.168.2.x range, how can i best configure this so it has its own network internally still but can still have it's default gateway pointing to an address out on the internal 192.168.100.x range. (I was hoping to set client pc's to use the remote SXT address as the default gateway given out by dhcp).
So to clarify the config:
SXT our end - 192.168.100.253
SXT remote end - 192.168.2.253
Default gateway for internet 192.168.100.254
I need the SXT remote end to also be able to connect to any machine on 192.168.100.x segment should it need to.
Thanks,
Chris
