Port80
Weird bridge behaviour on RB751U-2HnD
Wed May 02, 2012 2:36 pm
U've currently got a couple of RB751U-2HnD running both RouterOS 5.6 and 5.15 which we've been having some serious issues with.
Config in short; wlan1 is a station pseudobridge clone, added to a bridge where all the LAN ports are added as well. IP is set for the bridge.
We've got Computer1 which is connected by a switch to the gateway and a wireless AP, and Computer2 connected into to the RouterBox.
Everything is on the same IP range (10.0.0.0), but sometimes I'm only able to contact some of the equipment connected directly to the RouterBox, and not the RB751 itself. When I log in with Winbox and ping Computer1, I'm suddenly able to ping the RB751.
Anyone got any suggestions to why this keeps happening? Seems to happen with both RouterOS 5.6 and 5.15.
jandafields
Re: Weird bridge behaviour on RB751U-2HnD
Wed May 02, 2012 2:57 pm
How are you logging into the winbox on the rb751 if you can't contact it? Are you using mac-winbox to do so?
Port80
Wed May 02, 2012 3:18 pm
That's the fun part.
I can remotely control Computer2, and access the RB751 through Winbox from that machine. Just a simple ping from terminal in Winbox to the gateway, and I'll be able to connect directly to the RB751 again.
Port80
Mon May 07, 2012 11:44 am
It seems like this might be caused by ARP problems.
The machines in the office are unable to ping any of the equipment connected to the RouterBoard until the equipment connected to the RB pings the office machines.
Ping from the RB-connected machines works just fine, so I assume this has to do with the way the RB redirects the pings sent to its MAC-address.
mistry7
Tue May 08, 2012 8:21 am
These Problemsepends on the Wireless Mode you are Using!
Mistry7
Port80
Tue May 08, 2012 10:44 am
The wlan1 is set to station psudobrige clone, and it's set to clone the WLAN MAC of the RouterBoard.
Port80
Tue May 15, 2012 10:24 am
Attached is a basic layout of our network. What would be the recommended WLAN mode for the RB751 in this case?
Port80
Tue May 15, 2012 10:28 am
The current config on the RouterBoard:
add l2mtu=1598 name=bridge1
set [ find default=yes ] group-ciphers="" unicast-ciphers=""
add authentication-types=wpa-psk eap-methods=passthrough group-ciphers=tkip management-protection=allowed mode=dynamic-keys name=profile1 supplicant-identity="" unicast-ciphers=tkip wpa-pre-shared-key=somekey
/interface wireless
set 0 band=2ghz-b/g country=norway disabled=no l2mtu=2290 mode=station-pseudobridge-clone rate-selection=legacy security-profile=profile1 ssid=SomeSSID station-bridge-clone-mac=00:0C:42:F8:F9:9D
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add bridge=bridge1 interface=wlan1
add address=10.0.0.30/24 interface=bridge1
/ip neighbor discovery
set wlan1 disabled=yes
add distance=1 gateway=10.0.0.1
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
Port80
Tue May 15, 2012 1:36 pm
When I manually add an IP and MAC address to the Computer 1's ARP table it's able to communicate with Computer 2 and Computer 3.
Could this be caused by the ARP setting for wlan1?
nickshore
Long time Member
Long time Member
Wed May 16, 2012 4:46 pm
The mode you are using is only intended to bridge one device
See
http://wiki.mikrotik.com/wiki/Manual:Wi ... tion_Modes
Nick.
Port80
Fri May 18, 2012 10:29 am
Hi, Nick, and thanks for the reply.
I did read the Wiki, and as far as I could tell from this sentence, station pseudobridge and station pseudobridge clone is to be used if the RouterBoard is bridged up against a non-RouterOS AP, or if only one end-user device is connected. As the RB is connecting to a non-RouterOS AP I assumed that this would work just fine.
The usage of this node can only be justified if AP does not support better mode for L2 bridging (e.g. when non-RouterOS AP is used) or if only one end-user device must be connected to network by means of station device.
Which mode is recommended, then?
nickshore
Long time Member
Long time Member
Fri May 18, 2012 1:49 pm
Instead of bridging you could route.
You would use station mode on the RB751 and then either NAT the clients behind it, or route an extra subnet for them.
Nick.
Port80
Tue May 22, 2012 10:27 am
If we were to remove one of the computers from the MikroTik, would pseudobridge clone work as it's supposed to?
Port80
Tue Apr 08, 2014 11:12 pm
Could someone give me any pointers for the best configuration for this settings where only one computer is connected to the RB751U?
Users browsing this forum: PJIUPJIU and 65 guests
