Hi...
I believe most of us there is some WiFi hotpost customer (Laptop) facing the connection issue due to the wireless connection issue...
we able to see the tx/rx signal strength in the AP but customer only see one way information (usually shown rx data rate and signal only)....
is possible we can make this way, when customer connected to the AP, and when it go like www.google.com, it will redirect to the login page...
how can we make the login page to show the signal strength + data rate to the user and the page can help to tell the customer he should connect to the other AP for better connectivity...
I believe this should can be done and in fact this can help to cut down the support call...
or, can be this add in the new feature request to the next version???
thanks...
