49er
Sextant Bridge 2 networks
Mon Mar 04, 2013 1:59 pm
I have 2 Sextants (L3 license).
I need to transparant bridge to buildings.
How can I do this?
It is for temp. use. Our SXT we use are going back for inspection and now I need a connection between these two buildings.
cbrown
Re: Sextant Bridge 2 networks
Mon Mar 04, 2013 3:55 pm
C.Brown
cbrown[at]mpl.com
MTCNA - MTCRE - MTCWE - MTCTCE
http://training.mpl.com
49er
Mon Mar 04, 2013 4:03 pm
cbrown wrote:
Hi, thanks,
I found this document as well an try it but does not work. (sure I have done somthing wrong.
Step 3 and for is not totaly clear for me.
If I do this:
3. Create wds interface on AP and add the interface to the bridge in WinBox
I don's see the wds1 in the wireless tables.
nickshore
Mon Mar 04, 2013 4:28 pm
To make a transparent wireless bridge do the following:
on one sextant set the mode to Bridge
on the other set the mode to station-bridge
on both ends add a bridge and put the eth and the wlan in the bridge
if you want to pick up an IP for management add a dhcp client to the bridge interface
or set a static IP on the bridge
Hope that helps
Nick.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
49er
Mon Mar 04, 2013 10:36 pm
Hope that helps
Nick.
Thanks for your reply.
I have the link up and running now but only the speed is slow.
I have a max troughput from 2 MB/s till 2.5 MB/s
I changed frequence
I alligned the device.
What else can I do?
Users browsing this forum: timking and 4 guests
