hi friends,
i need some valuable suggestions for setting up a p2p link for 6-8 kms with SXT Lite 5 or SXT G-2hnd. i have a pair of both the devices and i have to set up a p2p link. the issue is we couldnt fix the antenna in both the sites.
Signal is not the only variable that you must check. Please post your full config from both sides, and also registration table output from both sides. At this distance, you should be able to get around 100Mbitsxt lite only gave me 12 Mbps throughtput for 1.5 kms under signal -60.
i even tried with recommended config, in bridge & station bridge mode.
compare to airgrid m5 25 dbm gave me 80 Mbps throughput.
Yes, you can. And you don't need any grid antennas, just two SXT units. SXT units can link even up to 10Km if conditions are very good, without any additional equipment.
So, what do you recommend ?sxt lite only gave me 12 Mbps throughtput for 1.5 kms under signal -60.
no way...hi normis
i wana crete a p2p link with sextant 5hpnd over 8.5 Klm
is it posible to get 100m tx rx trafic load ( mean browsing or downloading load a to z)
plz repply me
