I found:
Code: Select all
d = 3.57sqrt(h)
Code: Select all
d = 3.57sqrt(Kh)
Code: Select all
d = 3.57( sqrt(K[h1]) + sqrt(K[h2]) )
The problem with this equation is it is making the antennas ridiculously high for the distance I am trying to calculate. The question I am trying to answer is: “Two antennae are used for line of sight propagation. The antennae are spaced 150km apart. Determine the required antennae heights.”
My calculations:
Code: Select all
d=3.57sqrt(4/3)(h)
d=3.57(sqrt[4/3])(sqrt[h])
d=3.57(1.1547)(sqrt[h])
150=(4.1223)sqrt(h)
150/4.1223=sqrt(h)
sqr(36.3875)=sqr(sqrt(h))
1324.05=h 1324meters = h1 + h2 -> each antenna needs to be 762meters high
Is this the correct method? Or have I chose the wrong equation totally?
