Hi All,
I'm trying to configure an 751 router with two SSID to provide internet for two separate LANs.
I've configured the default wifi interfase with SSID01.
This interfase belongs to bridge-local and works fine.
For the second SSID, Iv'e done as follows:
1. Created a VirtualAP and gave it a SSID02
2. Created an IP address for wlan2 (SSID02).
3. Created a separate DHCP Server with a new subnet. (176.168.1.0)
4. Configured the Network for the DHCP with the wlan2 IP address as gateway.
5. Created a IP NAT masquerade for all traffic from lan 176.168.1.0 to go through ether1-gateway
I'm able to connect to the SSID02 and get an IP address from the defined pool (176.168.1.200), but I'm unable to connect to the internet through that wifi connection.
The original connection SSID01 works fine.
What am I missing in order to let SSID02 connect to the internet?
