gnuttisch
suddenly unstable nv2 link?
Wed Nov 20, 2013 9:51 am
we have ptp nv2 link on about 2km distance. we are running rb711HA boards whit r5Hn cards on 5.21 firmware.
signal is about 62/62 and ccq is about 92/98, 270/300.
today it have disconnected several times whit error codes like,
lost connection, synq timeout
anyone who have any idea what the error might be? should i lock the link at 270/270 instead to get a more stable link?
the ptp link have worked flawless since the installation, about 1,5 years.
regard..
ShayanFiroozi
Re: suddenly unstable nv2 link?
Wed Nov 20, 2013 12:25 pm
Hi
Please Set the "HW Retries" to 15
it may help you
ShayanFiroozi
Wed Nov 20, 2013 12:29 pm
gnuttisch
Wed Nov 20, 2013 4:56 pm
Hi, already set to 15 in hw retries
regards..
honzam
Wed Nov 20, 2013 5:32 pm
NV2 protocol don´t using "HW retries"
gnuttisch
Thu Nov 21, 2013 11:57 pm
okey, any other idees?
the freq is still clear and the antennas looks fine, have checked them on site.
sonny
Fri Nov 22, 2013 11:15 am
update your Router to 5.24 update firmware and try
after that
update youer router to 6.3 update firmware and try again.
You will see significant improvement of that Link
sonny
Fri Nov 22, 2013 11:22 am
I forgot update both sides!
please post signal RX/TX strength on both chains
/interface wireless registration-table print stats
ShayanFiroozi
Sat Nov 23, 2013 9:31 am
Try Nstreme , see what happens
gnuttisch
Mon Nov 25, 2013 11:34 pm
Hi, and thanks all for your replies,
currently we are running 5.26 on both ends,
now one end is constantly showing;
router was rebooted without proper shutdown,
and their is no problem whit the ups/psu because there is several devices connected to it.
We will try to change the board and hopefully we will get a stable link.
n21roadie
Tue Nov 26, 2013 1:37 am
What type of antennas are being used?
gnuttisch
Tue Nov 26, 2013 12:25 pm
jirous jrc-29 duplex, 38cm.
distance about, 2-3km.
n21roadie
Tue Nov 26, 2013 9:16 pm
JRC-29 DuplEX is listed as 65cm and not 38cm?
Lupin
Tue Nov 26, 2013 10:04 pm
2-3km with a 29dB antenna? and you have only -62/-62 ?
Is too low. there are bad pointings or obstacles
I expect at least -45dB
n21roadie
Tue Nov 26, 2013 10:33 pm
I was about the ask the same until i read "...38cm." as jirous jrc-29 duplex are 65cm
uldis
Wed Nov 27, 2013 10:30 am
Please upgrade the ptp link routers to RouterOS v6.6 and then do a wireless reset configuration on wireless interface. After that specify the settings you need to establish the ptp link - mode,ssid,country,frequency,antenna-gain,wireless-protocol,ht-chains. Then check how it is working.
It is also possible that maybe some other wireless link started to operate near your ptp link.
ste
Wed Nov 27, 2013 10:36 am
after that
5.24 is the nv2 release where improvements took place.
Upgrading further will show now further improvements (but may show up some new bugs).
We stay at 5.24 where possible for the moment until betaphase of 6.x ends.
gnuttisch
Wed Nov 27, 2013 9:31 pm
Then its not a JRC-29 but anouther jirous antenna that is 38cm. I dont have the exact produkt name in the head =)
Yes, that could be, but to achieve a stable link you have to lower the signal to about -60.
No, we would not upgrade past 5.26, as. ste said, you fellows aren't done playing whit ros6 yet and are using us as test pilots, where do I send the bill??
We will try changing the board to a new one. Probably the problem will go away.
n21roadie
Sat Nov 30, 2013 12:53 am
If the antenna is not as stated then what is the gain of this 38cm?
I have very stable links at -50, but signal is only part of having a good stable link?
gnuttisch
Mon Dec 02, 2013 2:38 pm
well we dont care so much about the signal level, it is the ccq level that matters.
regards
gnuttisch
Fri Dec 13, 2013 4:13 pm
Closure,
We replaced the board and the capacitors where bad, our first board whit this, RB411AH.
Now the link is stable again.
Thank all for your help.
Regards.
Users browsing this forum: bias89, neki, Tegarrti and 55 guests
