I have a severe problem with mentioned Groove devices (ROS 6.7).
I installed seven of them in my site to let cusomers access the internet.
After connecting all users are connected in 30 - 90 seconds and the logs show
Code: Select all
disconnected, extensive data loss
Code: Select all
name="AP-1" mtu=1500 mac-address=D4:CA:6D:BF:AD:69 arp=enabled
disable-running-check=no interface-type=Atheros AR9300
radio-name="D4CA6DBFAD69" mode=ap-bridge ssid="AP-1"
area="" frequency-mode=manual-txpower country=germany antenna-gain=16
frequency=2417 band=2ghz-onlyg channel-width=20mhz scan-list=default
wireless-protocol=802.11 rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
distance=1 tx-power=10 tx-power-mode=all-rates-fixed
noise-floor-threshold=default nv2-noise-floor-offset=default
periodic-calibration=default periodic-calibration-interval=60
dfs-mode=none wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=disabled hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-
9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-
18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30
nv2-security=disabled nv2-preshared-key="" hw-retries=7 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled
hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
rate-selection=advanced multicast-helper=default
multicast-buffering=enabled
Tx-Power ist "all rates fixed" at 17 dBm
Distance is set to 1km, customers live in a distance of max. 200m
Noise Floor is -95 dBm on all devices, not changing, don´t know what this means
If a user manages to be listed under "registration", the "P Throughput" starts with a good value,
counts down to 0 and disconnects.
Some users manage to log in an start downloads at ~3 Mbps (limited by profile) which shows, that
a bad signal might not be the cause of the disconnects.
Do you need more information ?
Please help or my customers will kill me.
THX
