I have RB433AH and CM9 card in AP mode (RouterOS 6.6). On AP there are 25 clients. First, card was in g-only mode, most of clients have 100% ccq, 54/54Mbps rate, but some of clients has same rate and ccq but distance show 30-40km???.(farthest client is 2km from antenna with clear sight). From time to time i got complains from clients that they cant ping anything. I checked ping from AP to client and the result was 2000-3000ms??? Then i changed freq and ping is now 1-2ms. After day or two same thing, i returned freq that was before i changed first time and again ping is 1-2ms. Now card is in b mode, rate is 11/11, ccq 100%, distance 1-3km, this setting worked 3 days after i need to change freq again...This AP is only in area.
So, ccq and signal are ok but ping goes to 2-3000ms. Antenna is http://www.rfhamdesign.com/images/slott ... 13cm02.jpg. I spoke with some people and they said that problem is maybe in antenna??? I dont think so i ask you guys! Can you help me?
