Product suggestion for Mikrotik after having encountered on many occasions where a PTP link board is being powered but the only access is by Wlan interface and Winbox is indicating no Ether connectivity
Is it possible to test connectivity on the RJ45 (T568B standard)
Pin 1 White/Orange = TX+
Pin 2 Green = TX-
Pin 3 White/Green = RX+
Pin 6 Green Rx- = RX-
If a test could be done to check pins 1,2,3,6 and if say for example all 4 pins did not respond it could indicate either cable is broken (pins1,2,3,6) but POE leads OK or device at other end is powered down or blown,
If there was a response from one or more pins then this would indicate break in Cat5
