peterb
RB/2011UAS-2HnD-IN as AP and WLAN-Bridge at the same time?
Sun Mar 23, 2014 12:08 am
Dear all,
I try to configure the following scenario with a RB/2011UAS-2HnD-IN:
Internet <--> FritzBox 3770SL <- WLAN -> Mikrotik RB/2011UAS-2HnD-IN (as AP) <- WLAN and LAN devices
Is this scenario possible with only one RB/2011UAS? If so, can somebody point me to the right direction for configuration?
Peter
plisken
Re: RB/2011UAS-2HnD-IN as AP and WLAN-Bridge at the same tim
Mon Mar 24, 2014 5:19 pm
If you want the routerboard connect with the fritzbox must you set the wireless interface as client.
You can't the radio use as client and accesspoint.
jarda
Mon Mar 24, 2014 6:27 pm
You can use wds in your case. But you need mikrotik device on other side too. So you have four options:
1. Use mikrotik instead fritzbox and wds connection.
2. Use client for connecting to fritzbox and ap for further distribution.
3. Use device with universal repeater capability instead mikrotik- e.g. ovislink 5460.
4. Connect fritzbox and mikrotik by wire. This is the most reliable option.
Sent from Android by Tapatalk.
plisken
Mon Mar 24, 2014 6:33 pm
WDS between fritzbox and routerboard should not work
jarda
Mon Mar 24, 2014 6:36 pm
Of course not. I have written that.
peterb
Mon Mar 31, 2014 12:43 am
thank you all for the fast reply. I connected the Fritz box via wire, which works almost out of the box.
Cheers
Peter
plisken
Mon Mar 31, 2014 9:26 am
That is the only right solution if you want a good performance.
Users browsing this forum: No registered users and 88 guests
