Wed May 07, 2014 11:12 pm
The Metal is a high power device and should not be used without an antenna ever.
If you are using an antenna on 5 meters the signal will be so strong that it will just not work normally.
And for this distance you should set the ack timing to 'indoor'
Having all of this said it's not a surprise it shows incorrect distance.
