silk101
3g Transparent Bridge
Wed Jun 25, 2014 10:26 am
Hi is it possible to have a 3g USB dongle providing a transparent bridge to all the ethernet ports on a
RB951ui-2hnd?
The 3g USB dongle works fine when the Mikrotik is in router mode I just need to bridge this usb to the ethernet ports
so the client on the Ethernet gets the WAN address.
many thanks
rextended
Re: 3g Transparent Bridge
Thu Jun 26, 2014 10:17 pm
use on firewall nat the netmask function,
you do it easily....
lemonmagic
Fri Jul 24, 2015 3:08 pm
Hi rextended, would you have a Example Code Snippet for a netmask nat rule?
I am trying to do the same as the OP, but I am not able to get it to work.
Users browsing this forum: No registered users and 74 guests
