gabby
mikrotik BaseBox as simultaneous dual band AP
Fri Jun 27, 2014 3:32 pm
Hi, Mikrotik Tech and Admins,
Can the mikrotik basebox be as simultaneous dual band AP? eg. 2.4ghz as AP and 5ghz as backhaul simultaneously.
Regards,
Gabby
rextended
Re: mikrotik BaseBox as simultaneous dual band AP
Fri Jun 27, 2014 4:44 pm
yes, if you put one 2,4GHz radio module and the 2 required pigtails inside the basebox5
(or 5GHz radio module and the 2 required pigtails inside basebox2)
gabby
Fri Jun 27, 2014 7:22 pm
Thanks rextended,
Thats gr8 about basebox. I will give it a try
Regards,
Gabby
yottabit
Tue Jul 22, 2014 6:33 pm
I am using a BaseBox 5 and have added in a 2.4 GHz radio interface card. I'm using 5 dBi gain antennas and everything is working great.
1W power for both 5 GHz and 2 GHz in a single enclosure with PoE is attractive.
Jacqueline
Sat Jan 17, 2015 8:27 am
I test repeatly the authentication of my tablet and in my freeradius DB does not appear the MAC addresd of my tablet.
In the previous post, we attach one Accounting packet for the wireless accounting.
I think it is necessary to depuerate the accouting request that MT device sends to RADIUS server. It works fine for the hotspot service.
_________________________________
Unlock the key of your success by 300-115 and testking.By using our latest a+ certification and study material, you can easily pass kumc Your Exams.
Users browsing this forum: No registered users and 87 guests
