marcin21
SXTG-5HP ac D - mcs rates under AC ??
Fri Jul 25, 2014 1:42 pm
I've received first SXT AC gear for testing.
As I realised there are some strange modifications done to manual select MCS data rates.
HOW can I set MCS4 (QAM16) to be max modulation ? as i have some MCS 0-7, 0-8 or 0-9 to choose from.
HOW to limit modulation?
uldis
Re: SXTG-5HP ac D - mcs rates under AC ??
Fri Jul 25, 2014 2:03 pm
For the 802.11ac you can't lower the supported data-rates below the MCS7.
So you can choose the max supported data-rate.
Here are the info which 802.11ac MCS represets what:
http://en.wikipedia.org/wiki/IEEE_802.1 ... _and_speed
Also you can specify 2 or 3 fields of supported VHT data-rates. First one is for the 1 Spatial-Stream, Second is for the 2 Spatial-Stream and Third for the 3 Spatial-Streams.
Why would you lower the supported MCS to such low MCS as the RouterOS rate-selection will automatically select the best working data-rate?
marcin21
Fri Jul 25, 2014 2:18 pm
So its a big disadvantage as QAM16 works most stable under Mikrotik.
I have all around 25+25mhz QAM16 nstreme ptp links they have 225mbps rate with 100%CCQ and ping stable as hell, no problem with tcp etc..
migrating thru different modulation results in 50-70%ccq ,much worse ping jitter.
In result AC as I hoped for stable 360/360 80mhz QAM16 wireless datarates is unavailable...
Can You somehow force driver to not to go higher than QAM16 ?
uldis
Fri Jul 25, 2014 2:28 pm
The 802.11ac standard and the card hardware doesn't allow such modifications so we can't do that, sorry.
marcin21
Fri Jul 25, 2014 2:56 pm
ok, as I thought. it was looking nice at first glance, now I see that AC is not going to be replacement for PtP radiolink.
two SXT AC in totally quiet environment on the desk right now stability in nv2 is unacceptable :/
uldis
Fri Jul 25, 2014 3:03 pm
The first problem is that you are generating the traffic on the SXT board and processing it - that causes a lot of CPU usage and that could cause your problems.
What are the signal levels as it could be too strong signal?
Have you tested both 802.11 and Nv2?
And for Nv2 what what tdma-period size?
normis
Fri Jul 25, 2014 3:04 pm
Uldis is right, Test like this:
[poweful router] --> SXT1 ###### SXT2 ---> [powerful router 2]
SXT itself can forward large amount of traffic, but to generate random traffic, you need more powerful machines. or actual data (many torrent users etc)
marcin21
Fri Jul 25, 2014 8:13 pm
doesn't make much difference.
<rb800>----GE <sxt ac ( ~ ~ ~ ~) sxt AC>---GE---<x86 intel c2d>
data rates 650-780 mbps both sides
it's not stable. but ofcourse it may be desk test issues.
Setting nstreme and frame limit to 1580 so lower than l2 MTU of wireless gives
100% CCQ 866,6Mbps wireles data rate and.... max 200mbps HDX of udp btest.
NV2 is behaving as wicked when no upper limit varying 200-450mbps.
but there maybe some interference issues due to desk test.
I'll try to set it in real environment on monday/tue. As for now lack of modulation
manual choice is biggest dissapoitment of AC for me.
sashavl
Mon Jul 28, 2014 7:53 am
Devices are too close. Lower output power.
uldis
Mon Jul 28, 2014 11:12 am
please try to check the throughput speed using the Traffic generator:
http://wiki.mikrotik.com/wiki/Manual:To ... _Generator
normis
Mon Jul 28, 2014 11:13 am
Also please show us your signal and CCQ levels. Just to rule out that devices are too close together or there is some other factor.
sashavl
Mon Jul 28, 2014 6:32 pm
Too close. I tested couple days ago UBNT Nanobeam and had same problem. Lowering output power level fixed problem.
marcin21
Mon Jul 28, 2014 11:00 pm
I lowered txpowerf to 0, 1 and 3 with all rates fixed. so i got about 60db SNR ccq varyies from 50 to 90%. ohhh if I could set QAM16...
Arnold2222
Sun Aug 03, 2014 11:10 pm
i have similar problem to this one with ccq and stability in this thread http://forum.mikrotik.com/viewtopic.php ... 98#p440398
cannot anyhow make it works stable :/
marcin21
Tue Aug 05, 2014 7:03 pm
ok I got some results. distance 11km, rocketdish and jirous well shielded, clean channel for testing test done over sxt (RB493G-CCR1016)
signal -61/-62 SNR 51 dB
802.11 :
CCq 50-70 / 50-60 %
wireless rate tx/rx 526/351mbps
btest (over sxt) one direction varying 150-250mbps lots of stall
ping avg 12ms max 63ms
nv2:
2 ms frame
ccq 50-70%
wireless rate 270/351
btest 50-150 mbps even more breaks
ping avg 14 max 82 10% loss...
link is UNUSABLE
nstreme:
best fit 3200:
ccq 70-80%
wireles rate 351/520mbps
btest quite stable 160mbps
ping avg 16ms max 27ms 0% loss
So :
1/nv2 is no usable protocol
2/nstreme is no faster than 802.11n 40mhz and nowhere near stability
3/802.11 is nothing we couldn't achieve on plain ac router.
this was my backup link build on AR9220 with 150mbps troughput with ping stable as hell.
either there is something really wrong with ac under mikrotik yet or there is something wrong with my setup.
Anybody got different / better results?
Arnold2222
Tue Aug 05, 2014 7:51 pm
I think they released it too early and soft is not good yet....
Of my research you can try settings like this, for me allowed to get a bit more stability and speed:
Protocol set on 802.11
Mode: 5GHz-only-AC
Data rates uncheck all under A/G supported and basic, then I put MSC 0-8 two rows under supported VHT and the same under Basic.
I set also distance manually to 1km as it is less than 500m and sometimes it connect with 2km or more in status.
Long preamble.
Thats all so far... maybe ll help you a bit ?
InoX
Tue Aug 05, 2014 10:42 pm
I don't get it, how do you connect an SXT to rocketdish and jirous?
marcin21
Wed Aug 06, 2014 12:34 am
using soldering iron. it's quite easy :)
InoX
Wed Aug 06, 2014 1:31 am
to many pigtails
marcin21
Wed Aug 06, 2014 10:30 am
There are Two pigtails to be precise. Each for one chain as usual. :)
uldis
Wed Aug 06, 2014 12:35 pm
there is no need to solder the SXT device as soon you will be able to get the Netbox5 which has SMA connectors like the BaseBox.
http://routerboard.com/RB911G-5HPacD-NB
marcin21
Wed Aug 06, 2014 12:46 pm
yes ofcourse. I'd choose netbox if it would be available.
But when rb 11e AC be available?
InoX
Wed Aug 06, 2014 12:47 pm
not soon enough...
marcin21
Wed Aug 06, 2014 3:00 pm
small update:
the same pair of sxt ac switched to 802.11 a/n only, can go with 99%CCQ link mcs12 180/180 mbps nstreme
stable 120mbps under btest with ping stable as rock :)
definetely it's about AC implementation and Mikrotik stuff please work on how to force MCS rates, it would give very stable links on 5ghz.
If You could tweak 802.11 standard in very hard ways up to now why couldn't You do so simple thing as selectable/avoidable datarates in 802.11ac :) ?
Arnold2222
Thu Aug 07, 2014 12:35 am
hmm need to test your suggestion :) thanks!
btw what is your setup for nstream ? I am using Disable CSMA, policy= best fit, limit=4000
802.11 A/N MSC12-23:
UDP Tx 240Mb - ccq 95-100% latency up to 17ms
nstreme A/N MSC12-23:
UDP Tx 180Mb - ccq 95-100% latency up to 17ms
802.11 A/N/AC MSC12-23 VHT 0-8,0-8:
UDP Tx 340Mb - ccq 80-100% latency up to 19ms
normis
Thu Aug 07, 2014 11:07 am
So here is our test. Done in a room, 5m distance, Btest running on the SXT itself (usually I recommend running from a different device, through the link, so that the SXT CPU is not overloaded), but as you see the result is still quite good. With a longer distance (1km) the speed could even be better, such short links are not the best example
Bergante
Thu Aug 07, 2014 11:42 am
The signal levels are really high. Should we apply a different doctrine to the new -AC units? I mean, with the "classic" -N ones it's recommended to aim for a signal level between -60 and -70 dBm in order to avoid overload.
Should we keep the signal levels higher with these new -AC units? Won't we have overload problems? In this case, which is the optimum range of signal levels?
ste
Thu Aug 07, 2014 12:28 pm
Sensivity for a 20MHz Channel MCS-9 is -72 (SXT AC). For 40MHz -69. So I guess -60 is the sweet spot. With -70 you will not get 256-QAM 5/6. With 20MHz Channel you get 256QAM-3/4 Max so you want 40MHz Channels.
normis
Thu Aug 07, 2014 12:31 pm
We also made the same test with signal -55, but the speed is the same.
Bergante
Thu Aug 07, 2014 12:32 pm
I was wondering, as the test performed by Mikrotik shows signal levels around -30 dBm :)
Arnold2222
Thu Aug 07, 2014 4:05 pm
very nice normis :)
How to explain then the situation on my sxts ? I can see your speeds are kinda stable while my likes to flap... also your ccq looks poor but probably due to desk test.
I am not able to get stable ccq and speeds but as I made last tests it looks better than my other tests.
I can create supout.rif so you you may take a look maybe there is smth wrong, what do you think ?
normis
Thu Aug 07, 2014 4:10 pm
very nice normis :)
hmm, interference, reflections, noise? did you try complete reset of config, only setting the IP addresses, and trying the link with regular 802.11 without nstreme or nv2? did you try to move to different frequencies, or changing location of the test ?
Arnold2222
Thu Aug 07, 2014 4:40 pm
so far I could achieve this:
hmm bridge is under omni antenas and SXTs are with shield right now (which did not bring anything better)
I tried at night to turn off this 2 omni anteas to see if there ll be better results but also nothing better.
About test it in different place, that could be possible but so far do not have time for that but I am not sure if other bridges has so good clear visibility, anyway I ll take that as an option to check.
About reset I did not make full reset, so far I made radio reset and config using quickset.
amishh900
Re: SXTG-2HND AND SXT LITE5
Thu Feb 26, 2015 8:46 am
we are using sxt 2hnd and sxt lite5 for two different customer and link distance at both the location is 300 meter.however at both location when link is in ideal condition we find a heavy traffic flow and with signal strength of -39 db packet delay is almost 150ms also when we bringing device back to back at a distance of 5 meter inside the room we face a similar type..what could be the reason for packet delay and traffic flow
Arnold2222
Fri Feb 27, 2015 2:36 am
could you specify what do you mean by heavy traffic flow ?
as I got advised before what could eventually help:
1. reset to defoult.
2. upgrade to new stable soft - check forum if there are no issues ;)
3. you need to care signal be not so strong -39 is too strong, lower the power, what MT said around -55 -60 should be perfect
4. check frequency and be sure there is no noise
5. if nothing help then maybe one device is bricked...
Greetings and GL
BTW my sxtgs actually are not able to transfer more than 100Mb/s tcp while competition solution is doing easly 400Mb/s out of box xD waiting for better weather to switch MT.
Users browsing this forum: No registered users and 66 guests
