Dear All,
I need your advise for the best result and easy way, in Routerboard RB1100AHx2.
I have got connection from Providers, one as Main which always must be active and run, and if incase the Main link is down the traffic must shift to Backup link, What I want at same time both connections should not work.
1- connection one Main ( 5 Mbps ) Public IP 103.xx.xx.xx/30 ( Fiber) RB1100 Port 2
2- Connection two Backup ( 512 Kbps) Public IP 82.xx.xx.xx/30 ( VSAT ) RB1100 Port 5
during the outage in Main link I am authorize to backup connection.
like something Ping system, if the ping went down in the main the system should understand in 2 minutes, not before nor later than 2 min, change the circuit to Backup, and whenever the Main connection backup online automatically the system change to Main connection and backup connection stays as backup.
