diablonet,
please provide us with console output, when your router enters endless loop.
I have used the same configuration for “ntp client” as you specified, my router works without any reboots. Perhaps there is any other configuration that is required.
igb,
I assume you need to check mss (MTU/MRU configuration for PPP profile), and decrease mss to 1300 in /ip firewall mangle rules, by max-mtu max-mru configuration at ppp server.
AlexS,
please provide us (
support@mikrotik.com) with support output file from your router, when traffic-flow does not work for you.
JanezFord,
please provide us (
support@mikrotik.com) with support output file from 6.19 version, when DHCP-leases are erased.
samim,
please post your issues in the appropriate forum section, this thread is about RouterOS 6.19.
Zorro,
what hardware do you use?
roadracer96,
please provide us (
support@mikrotik.com) with support output file from your router.
standart,
please post entire output of command that you use to enable NTP server, and error returned by MikroTik RouterOS.
parinya1957,
please share your configuration with us. We will try to repeat the same problem in our test networks.
pturkey,
please add more details to your problem description. It would be convenient to get console output from your router, when problem is present.
meetriks2,
share you ppp configuration for local and remote addresses, that are assigned to clients.
