adyb76
Trainer
Trainer
Re: v6.19 released
Wed Sep 10, 2014 9:43 am
Installed on our CCR1036 which is our QoS, with many mangle rules and a comprehensive queue tree, passing over 800mbit/s at peak times. All went ok, not sure about performance improvements yet - tonight will be the best time to check this out.
Adyb
PastuhMedvedey
Re: v6.19 released
Wed Sep 10, 2014 1:46 pm
What's new in 6.19 (2014-Aug-26 14:05):
*) bridge - added "Auto Isolate" stp enhancement (802.1q-2011, 13.25.6)
Please tell me where you can find a description of this function in the documentation. Follow the link below, found nothing. http://wiki.mikrotik.com/wiki/Manual:Interface/Bridge
andriys
Re: v6.19 released
Wed Sep 10, 2014 2:56 pm
In the aforementioned 802.1q-2011 standard, obviously. You can get yourself a copy of the standard document here.
Paragraph 13.25.6 says:
13.25.6 AutoIsolate
A Boolean. Set by management if isolate (13.25.20) is to be set, causing a Designated Port to transition to
Discarding if both AdminEdge (13.25.1) and AutoEdge (13.25.5) are FALSE and the other bridge presumed
to be attached to the same point-to-point LAN does not transmit periodic BPDUs—either as a Designated
Port or in response to BPDUs with the Proposal flag set (see 13.21). The recommended default of this
parameter is FALSE. AdminEdge and AutoEdge are both reset only on ports that are known to connect to
other bridges.
isai
Re: v6.19 released
Wed Sep 10, 2014 10:19 pm
Motherboards and firmware ect compatible with v6.xx?
many new boards out there...and your wiki only shows v3 and v4
Clauu
Re: v6.19 released
Thu Sep 11, 2014 11:38 am
I was modifing some dhcp settings/networks and after that bum all settings/networks from dhcp server section disappeared.. same for ip pools, all my 10pools had gone away.. i'm kind a tired of this very unpredictable behaviour every time i'm having emotions that something will go bad and i must reboot or it will crash etc
pchott
Re: v6.19 released
Thu Sep 11, 2014 1:35 pm
We are using Tftp over MikroTik and after upgrade to 6.19 we experience that we cannot transfer filenames with filename lenght 6? Does anyone alse uses TFTP over Mikrotik?
EDIT:
6x8bit = 32bit filename length and with uboot there is no way to transfer such filename. Looks like i have to go back to 6.15
zervan
Re: v6.19 released
Thu Sep 11, 2014 7:45 pm
It seems like there is something wrong with dhcp-server lease address-list parameter. Here is a line of my last backup - as an example:
/ip dhcp-server lease
  add address=192.168.1.91 address-list=klient mac-address=00:1E:74:DD:A3:9F server=dhcp-local
Everything was working for years. Today one of local admins contacted me about a new PC problem - he added new address, but something was not working. I found out that he didn't add address-list parameter as he should - well, but he just made copy of other leases and there is no address-list parameters at all and they were there till now. Did he delete them? I don't think so, I have also checked other of my routers where I use address-list (RB1200, RB751, RB2011) - none of them has address-list parameters set - they were lost probably after 6.19 update!
Here is the same line when I made backup now:
  add address=192.168.1.91 mac-address=00:1E:74:DD:A3:9F server=dhcp-local
The strange thing is that the old leases do add addresses to the list despite the fact that they are not listed in configuration.
Does somebody have this problem or I am the first one? This is the second serious bug in 6.19 that affected me :(
zervan
Re: v6.19 released
Thu Sep 11, 2014 8:24 pm
Another question about dhcp lease address-list problem is - how to fix that? I tried command
/ip dhcp-server lease set address-list=klient numbers=[find server=dhcp-lan2]
- but it is not displaying it neither and there are messages in the log like
dhcp,error dhcp-lan2: failed to add address-list klient for IP 192.168.3.62: already have such entry (6)
lambert
Long time Member
Long time Member
Re: v6.19 released
Thu Sep 11, 2014 9:45 pm
I believe the format of the set command is :
set {entry number(s)} things to set
Your command should have been in the format of:
/ip dhcp-server lease set [find server=dhcp-lan2] address-list=klient
But the error you are getting says that the address-list entry already existed in /ip firewall address-list
You can probably ignore that since some of your entries probably already had address-list settings.
zervan
Re: v6.19 released
Thu Sep 11, 2014 10:59 pm
The format is correct, the same error appears if I set address-list to particular lease number.
The first problem is that since manual setting of Address List in WinBox will remain and seems to work correctly (despite the same error in log), setting using command in Terminal is not working correctly. Maybe better said: it may work somehow "hidden", but the value is not displayed in Winbox, nor export. The second problem is that even working values (which are displayed in Winbox) are lost after reboot.
Is there anybody who can confirm this problem? I am the only one which is using dynamic address list from DHCP clients? I found a very simple way to reproduce the problem: add an Address List to some DHCP lease, reboot, check the DHCP lease - there is no Address List mentioned in 6.19.
tkgit
Re: v6.19 released
Fri Sep 12, 2014 6:37 am
i use rb751u2hnd, if i enable ppp-out 3g use usb 3g modem, cpu process suddenly rise to 100%
if i disable ppp-out, cpu process back to normal again, why? this problem began after RoS 6.xx
gvitalik
Re: v6.19 released
Fri Sep 12, 2014 8:50 am
I am not using 3g modem, and my router is RB951G-2HnD, but on each 7 day after reboot cpu process rise to 100%.
I don't know how to back it to normal, except rebooting.
zervan
Re: v6.19 released
Fri Sep 12, 2014 10:07 am
There is no need to reboot - closing Winbox and opening again is enough. I have reported to support.
zervan
Re: v6.19 released
Fri Sep 12, 2014 10:12 am
No problem with that using RB951Ui-2HnD + ZTE modem, nor RB2011UiAS-2HnD + Huawei modem, both with RouterOS 6.19 and previous. Check Tools -> Profile, which process is using CPU, maybe it is related to firewall rules or something like that.
gvitalik
Re: v6.19 released
Fri Sep 12, 2014 11:37 am
Hi zervan!
May be you know what is better to do in case ipsec show 96% of cpu in profile, but at this moment I have no any ipsec connection? I don't know why, but I have configured l2tp/ipsec vpn server before, but now there no any ipsec proposal and peers. If i open PPP->l2tp configuration and save it again, then the system re-create ipsec proposal, but after some period of time, this proposal will be "deleted" again.
zervan
Re: v6.19 released
Fri Sep 12, 2014 1:06 pm
Sorry, but I don't know the reason. Try to export configuration and check if there is really no forgotten ipsec / l2tp mentioned. Is this problem related to RouterOS 6.19? Was it working in previous versions? If not, you should create new post / topic in appropriate section of this forum and somebody will know to help, I think.
I have problems with high CPU load only when I am connected to Winbox and Profile show non-senses like "flash". When I disconnect, CPU load is low again (I can see it on graph). This problem I have for about 10 versions back. But it is probably not the problem you have.
zervan
Re: v6.19 released
Fri Sep 12, 2014 1:09 pm
I've got answer from Mikrotik support - this problem should be fixed in 6.20rc6. I will try in the evening, but I worry - what if there are some new bugs? Early implementation of 6.19 brought serious troubles to me.
rextended
Re: v6.19 released
Fri Sep 12, 2014 6:20 pm
What's new in 6.20rc6 (2014-Sep-08 10:16):
*) pppoe client - increase connection timeout to make connection establishment
possible on busy pppoe server;
*) dhcp server - change default lease time from 3 days to 10 minutes
to avoid running out of IPs;
*) ipsec - allow binding modeconf address to username;
Winbox v3 is required for router’s configuration.
SERIOUSLY? IS STILL FULL OF BUG AND IS NEEDED FOR 6.20!!!???
zervan
Re: v6.19 released
Fri Sep 12, 2014 6:37 pm
Unfortunately, yes. I have upgraded one of my routers to 6.20rc6 to test if Address List of DHCP Lease is fixed (it is not) and it is not possible to connect with the old good Winbox :(
CyberTod
Long time Member
Long time Member
Re: v6.19 released
Fri Sep 12, 2014 6:41 pm
I am connecting through Dude, because it is more convenient to work with a lot of devices. If I will not be able to that anymore because it is using old winbox version that is a major problem for me.
P.S. I just found a workaround for that by making a custom tool in Dude and if indeed winbox 3 is required for administering v6.20+ I will post a short guide with some pictures.
noyo
Re: v6.19 released
Fri Sep 12, 2014 7:10 pm
solution is:
1. Create a directory "Dude" in the C:\
2. Copy the new winbox3 to C:\Dude\
3. Go to Dude > Tools > + end
3.1. name: Winbox3
3.2. command: "C:\Dude\winbox3.exe" [Device.FirstAddress] [Device.UserName] [Device.Password]
Connect to new winbox:
Right click on the device > tools > winbox3
Works on windows, how and on Linux under Wine.
good luck :)
CyberTod
Long time Member
Long time Member
Re: v6.19 released
Fri Sep 12, 2014 7:14 pm
I just did that :)
With the exception that my path points to where my winbox3 is currently saved.
The downside is that the integrated in Dude winbox connects a lot faster. And the known bug of not remembering session with the new one.
noyo
Re: v6.19 released
Fri Sep 12, 2014 7:19 pm
t's terribly sad that we have to pay for underdeveloped software.
Also a shame that mkrotik tests its software on the clients :(
mperdue
Re: v6.19 released
Fri Sep 12, 2014 11:26 pm
I decided to be carefull before deploying 6.19. I have some spare's here at the office so I've upgraded 12 units and bricked 4. Two Rb133c's, one RB SXT 2nd (new out of the box), and one RB912UAG-2HPnd (new).
They will light up quickly one beep and then nothing.
How can I unbrick these units?
-Michael
athlonxp78
Re: v6.19 released
Fri Sep 12, 2014 11:30 pm
WTF!!!??? The Beta3 of Winbox v3 is buggy and you "lock us" to work with this version?
Are you crazy?
It´s a JOKE?
steen
Re: v6.19 released
Sat Sep 13, 2014 10:40 am
Hello Folks!
We successfully updated about 1/3 of of our MT equipment to RoS6.19 and firmware, we also enabled wireless-fb package on them. RB411, RB433, SXT, SEXTANT and a couple of switches CRS125.
We did it in small steps like, first a baseline reboot then update RoS + reboot, then update firmware + reboot and last enable wireless-fb + reboot.
Still the routing marks for policy based routing is broken so we are stick to RoS 6.7 on those.
kobuki
Re: v6.19 released
Sat Sep 13, 2014 5:01 pm
Are you crazy?
It´s a JOKE?
I must agree. The v3 beta3 cannot reliably re-open the windows and their arrangements when I open an old session auto-imported from winbox2. This effectively makes it completey useless in production. Please save us from testing your half-baked code. There are a lot of small problems and mistakes one can tolerate when forced upon. This is certainly not among them.
bajodel
Long time Member
Long time Member
Re: v6.19 released
Sun Sep 14, 2014 9:54 am
if confirmed I think ros 6 series will stop at 6.19 for me ..
.. pure crazyness
hashbang
Re: v6.19 released
Sun Sep 14, 2014 6:00 pm
+1
winbox 3 is buggy. It doesnt run properly on wine. The cursor will blink on the extreme right of ip address but if u use back space it will delete the 1st octet of ip address. So painful for anyone who uses keyboard and doesnt watch the screen :P. Specially when u have a long list of devices in your winbox list.
xcom
Re: v6.19 released
Mon Sep 15, 2014 2:05 am
If this will be the case for all firmwares going forward, I will take my switch off my network and set it on fire...
I am a linux user and having to install wine to run another buggy ass application... Hell no!... You can keep the spoon.
:evil: :evil: :evil:
lambert
Long time Member
Long time Member
Re: v6.19 released
Mon Sep 15, 2014 2:48 am
We're complaining that pre-release RouterOS requires pre-release Winbox?
Maybe MikroTik just wants to ensure that they get some Winbox 3 feedback from the people who are already demonstrably risk takers. If you are running RCs, you are a risk taker.
Anyone who cares should e-mail support and ask them if they intend for Winbox 3 to be production ready before RouterOS 6.20 is released.
Personally, I think it would be a mistake for MikroTik to require Winbox 3 to manage any RouterOS 6.x release. They can require whatever they want of the RCs. They can require whatever they want for 7.x. But the 6.x releases should not require untested management methods.
And none of that has anything to do with RouterOS v6.19. Start another topic already.
AlexS
Re: v6.19 released
Mon Sep 15, 2014 4:11 am
I'm presuming you can still ssh to the box.
If not then 6.19 will also be my final firmware..
A
kapulan
Re: v6.19 released
Mon Sep 15, 2014 12:17 pm
Remote mac-telnet not work(connection timeout) all v6 version change the wireless mode to station bridge !Change the mode to simple station work again the mac-telnet.I use NV2 .
Mt team please fix this problem.
zyzelis
Re: v6.19 released
Mon Sep 15, 2014 12:45 pm
Just upgraded a whole network to v6.19.
Devices are CCR1036, 1100AHx2, SXT lite5;lite2, SA5r2, G2HnD, G-5HPacD-SA, G-5HPacD, RB433GL, OmniTik-U and UPA,
RB750GL, 750, 750UP, RB2011-LS;RM;UAS, RB951G;U, RB711-5h,RB911-5Hnd and grooves A52HN.
works stable so far, no "kernel failure" crashes, all wireless devices with fp packages
Thanks Mikrotik for stable package.
snoppy
Re: v6.19 released
Mon Sep 15, 2014 12:57 pm
Hi all!
we tested 6..20rc6
4000 simple queue
active users from 900 for 3800
conntrack ON
load 100%,traffic up to 1.7Gb/s
when load to 90-100% (1.7G) router freeze on 5-10 seconds and traffic down to 700Mb/s
connrack OFF
load 10-15% traffic up to 2.3Gb/s
sometimes load 100% and router freeze for 5-10 seconds , but traffic not down.
sometimes load up to 40-50% and then slowly going down to 10-15%
suppout was sent.
Ticket#2014081166000977 with Martins S.
voxframe
Re: v6.19 released
Mon Sep 15, 2014 4:07 pm
normis!
This really bothers me!
Why do you lock us into beta firmware/software before stabilizing the current branch!
Before you did it with the 2011 board and 6.x firmware. Some boards worked with 5.x and some (after a still undocumented hardware change) require 6.x.
Now you are doing it with a buggy version of winbox!
Guys... STOP! STABILIZE THE DAMN THING! Then slowly implement changes. winbox3 should not make ANY appearance in 6.x. It should be reserved for 7.x
Come on! All I want is for things to be stable like 5.26, but I can't run it on half of your hardware, and currently no version of 6.x is trustable.
adyb76
Trainer
Trainer
Re: v6.19 released
Mon Sep 15, 2014 6:54 pm
We have recently upgraded to 6.19 from 6.7 on couldcore router with ubiquiti AF24 and now have FCS errors on interfaces that have an AF24 connected to them.
We have this issue previously and you guys managed to fix it but it's reared its ugly head again....
Thanks,
Adyb
hashbang
Re: v6.19 released
Tue Sep 16, 2014 8:40 am
adyb76 please post the screenshot
vox +1
steen
Re: v6.19 released
Tue Sep 16, 2014 1:37 pm
Hello Folks!
We now updated even more RB411 and SXT and SEXTANT:s to RoS6.19 and wireless-fp, no problems so far.
The only observation is that the RB devices takes long time to come back on the network after updating RoS, the same is after the firmware is updated and when switching package from wireless to wireless-fb.
Well, then we have to broken routing marks that prevents us from upgrading several edge routers, business has decided to pick another brand to replace them.... :-( Policy based routing is a must for us.
OlegM
Re: v6.19 released
Tue Sep 16, 2014 1:44 pm
Version 6.19 CCR. Accordingly CCR serves as PPTP server. The role of the client VPN connection that uses torrents. Noted in the PPTP connection, that when working torrents connection is not broken, but the packets lost as long as you do not restart PPTP. And it was seen in the earlier versions.
zyzelis
Re: v6.19 released
Tue Sep 16, 2014 2:16 pm
It was early to be happy with 6.19.
On CCR1036 which is connected via SFP to RB260GSP now i regullary get FSC error on link.
Already tried to turn off autonegotiation and set to FDX 1G, problem still persist
Before CCR was on 6.12 and such problem wasn't......
So be carefull. :?
Robinson
Re: v6.19 released
Wed Sep 17, 2014 12:01 am
After upgrading Ros 5.20 to Ros 6.19 Sextant (RB711-5HnD) lost WLAN port. After disconnecting and connecting the power supply interface has returned, but with defoult settings. 1 hour on a 6 km. remote tower to return the the link. :?
slebrun
Re: v6.19 released
Wed Sep 17, 2014 1:12 am
We upgrade a pair of 493AH routers to 6.19, and saw EoIP start dropping packets > 1422 bytes. Rolled back to 6.17, no problems.
We did not, however, upgrade the far end of the EoIP tunnels, which may or may not have wound up working better.
bajodel
Long time Member
Long time Member
Re: v6.19 released
Wed Sep 17, 2014 8:47 am
6.20rc9 works with winbox2 ..thanx :D
gemwk2
Re: v6.19 released
Wed Sep 17, 2014 11:30 am
There is a problem with RB SXT G-5HPnD r2. This board restarting itself because of kernel failure and log is like this "00:42:21 system,error,critical router was rebooted without proper shutdown by watchdog timer ".
normis
Re: v6.19 released
Wed Sep 17, 2014 11:36 am
how is your watchdog configured? maybe it is pinging some address
hedele
Re: v6.19 released
Wed Sep 17, 2014 12:31 pm
Welp... no more rc testing (or upgrading, for that matter) for me then...
I'll stay on 6.18 on all of my devices, since EoIP (which I use it a lot) is broken on 6.19.
6.18 was a great release (the first really stable and usable one with no major bugs for my use-cases in the whole 6.x branch) and I hold on to it dearly.
normis
Re: v6.19 released
Wed Sep 17, 2014 12:38 pm
why?
hedele
Re: v6.19 released
Wed Sep 17, 2014 12:57 pm
Well as you can read from some of the feedback in this thread, winbox 3 does not seem mature enough for production use yet.
Also, I don't think that there is any technical reason that winbox 3 is required for new rc builds, it's probably just politics to force people into beta-testing winbox 3.
gemwk2
Re: v6.19 released
Wed Sep 17, 2014 4:06 pm
Watchdog is configured by default, no configuration is set.
kliq
Re: v6.19 released
Wed Sep 17, 2014 5:06 pm
Hi all,
We've been working with Mikrotik since v2.9.5 and have followed the progress and changes at Mikrotik for a number of years. We thought we'd throw our 2 cents in on the forums and maybe help pinpoint a few issues. :)
We have been rolling out 6.19 and picked up on similar issues as faced by gemwk2; on about 20 6.19 devices we have deployed, 4 of them are constantly (2-3 times daily) rebooting due to watchdog timeout.
The watchdog is configured in different ways on all 4 devices, all but one are watching a specific IP and the 4th is just enabled as default. We did try disable the watchdog but the board needed a hard reboot as it froze a couple of hours later. If any other information is required please let us know.
noyo
Re: v6.19 released
Wed Sep 17, 2014 5:39 pm
See if your CPU jumps to 100%.
U is not so with Lite5 update 5.26 -> 6.19. Yesterday I turned off the wireless-fp and it did not work. Today, some three hours ago in August alone restarted.
Watchdog also have a default set.
Mikrotik a confused and August restaruje.
visalink
Re: v6.19 released
Wed Sep 17, 2014 5:44 pm
I also have this problem.
I'm moving to VPLS.
nsayer
Re: v6.19 released
Wed Sep 17, 2014 9:58 pm
Sometime between 6.16 and 6.19 L2TP VPN between my mac and iPhone and my routerboard has broken.
I went in and made sure that the configuration was correct (so far as I know), including "enable IPSec" and adding the shared secret on the L2TP server page.
What I get on the mac side is "IPSec connection failed <IKE Error 65535 (0xffff) Unknown error>"
and in the system log,
IKE Packet: receive success. (Initiator, Main-Mode message 4).
try to get pskey by the peer's address.
couldn't find the pskey by address [routerboard].
couldn't find the pskey for [routerboard].
I'm really, really, REALLY sure the shared secret is the same on both sides.
WTF?
armandfumal
Re: v6.19 released
Wed Sep 17, 2014 11:21 pm
It is your choice. You can also go to Cisco and pay thousand euro for the device and many more for the service...
MKT do a very good job...
noyo
Re: v6.19 released
Wed Sep 17, 2014 11:26 pm
Man, you pay for it. I really want to buy the product on a half fit?
Think out what you're saying.
I like solutions Mikrotik, I would not trade them for anything at all else, but wants a product who works.
armandfumal
Re: v6.19 released
Wed Sep 17, 2014 11:27 pm
I'm using EoIP on CCR, RB2011, RG951 without any issues with 6.19, work stable...
noyo
Re: v6.19 released
Wed Sep 17, 2014 11:31 pm
And for me as you can see in the graph is not stable. I uwielu people also is not stabile, that in itself is already available 6.20rc shows that there are errors.
Apparently, your network will not fully benefit from the opportunities mikrotik.
I lite5 restart once a day, so do not tell me that it is stable, because it is not.
armandfumal
Re: v6.19 released
Wed Sep 17, 2014 11:46 pm
we have hundred mkt devices under 6.19 without any big issues, may be your problem is coming to specific usage in your config, your case must be analysed by MKT support...
TikUser
Re: v6.19 released
Thu Sep 18, 2014 1:56 am
I'm having a very strange issue. My backup files on the 493g are getting bigger and bigger, but the configuration is the same. Only the textual backups have the same size. Where is the problem? Any suggestions?
The rb493g has 2 wifi cards inserted. One is disabled, and the other serves as AP (2.4GHz).
patrikg
Re: v6.19 released
Thu Sep 18, 2014 10:34 am
The backup files, i assume that it also take backup of the logs and much more.
Not only the config.
snoppy
Re: v6.19 released
Thu Sep 18, 2014 11:40 am
Hello
we have some CCR1036-8G-2S+EM
when traffic grow up to 3Gb/s and more, SNMP does not work correctly.
this ccr connected to other switch
and SNMP statistic from this switch-port has not failures, and traffic 3.5Gb/s
this problem in all versions, whitch we tested and uses
from 6.13 to 6.19, and all 6.20rcX.
vadimbn
Re: v6.19 released
Thu Sep 18, 2014 6:19 pm
I observe a memory leak on this version of RouterOS. Ticket#2014091866000668 has been created.
nsayer
Re: v6.19 released
Thu Sep 18, 2014 7:04 pm
WTF?
Bueller?
maxfava
Re: v6.19 released
Thu Sep 18, 2014 11:16 pm
Normis,
I noted 6.19 has changed mcs ht user interface in winbox on AC devices when I set fixed data rate.
Could you kindly address me how new User Interface works?
Before was with check box and able to set single mcs rate, now is a drop down box showin from 0-9, 0-8, 0-7.
Thanks.
Massimo
nsayer
Re: v6.19 released
Fri Sep 19, 2014 4:52 pm
WTF?
Bueller?
Bueller?
mrz
Re: v6.19 released
Fri Sep 19, 2014 6:45 pm
Enable ipsec debug logs, try to connect and after failure generate supout file. Send this file to support at mikrotik.com
OlegM
Re: v6.19 released
Fri Sep 19, 2014 10:39 pm
Tell me how to write the rules in the firewall to use Layer 7, to block sites by domain, that would not die CCR. I certainly understand that this issue is not the place, but on x86 does not fall even when the error interfaces, and CCR constant problems.
paoloaga
Re: v6.19 released
Sat Sep 20, 2014 3:51 am
do I miss something or the IPv6 iBGP route reflection doesn't work?
joegoldman
Forum Veteran
Forum Veteran
Re: v6.19 released
Sat Sep 20, 2014 7:15 am
Finally upgraded my core CCR's to 6.19 last night - so far no problems but some problems I held off reporting from my old version still exist.
Normally I am sitting 3-10% CPU usage, but it will randomly spike to 50+% CPU usage with no major network events. From some of the profiles I've been able to capture it seems to be the networking process spiking but they are sporadic and only last for ~5 seconds so I can't even capture a supout.
It is still painfully slow to filter and search the route table. I have about 540k IPv4 routes loaded and I can do a x.x.x.x in dst-address filter without it taking MINUTES, or searching where blackhole=yes or comment="blah". I dont mind 20-30 seconds but minutes is too long when investigating issues.
Surely there is a better way like referencing the FIB directly as if it does when actually doing the routing?
I used to have another issue where /system resources CPU % would differ from the reported 'idle' amount (inversed) in the profiler, by up to 5-10%, but this seems better, still closely looking though.
noyo
Re: v6.19 released
Sat Sep 20, 2014 10:08 am
In my case it helped to /system reset-configuration no-defaults=yes and the configuration of RB again.
Uptime 1d and 7h
karina
Re: v6.19 released
Sat Sep 20, 2014 10:38 pm
This is insane! I've updated RouterOS to 6.19 last evening in multiple organizations and today they are calling me that WiFi authentication is not working, since I'm using userman :shock: How can you offer "stable" version with such a huge mistake?
I really need to download PPC version of fixed package ASAP, presented links are not working, there is still the old broken one, I tried http://download2.mikrotik.com/routeros/ ... sgdfgwgwer - contains broken package. I don't use any cache.
With due respect zervan, the mistake is upgrading production routers to the latest version quite so quick. I would advise testing before deploying any software or if not possible watch the forum while others test
Begetan
Re: v6.19 released
Sun Sep 21, 2014 3:52 am
I put CCR-12G-4S-EM with ROS 6.19, made configuration of SNTP client. Put DNS name instead of IP.
Then I upload ntp package and restart device, after that I completelly lost connections.
I have to go at morning and immediattely fix the problem. Could anyone tell me which version is good for CCR?
It looks like NTP is broken here and this is the worst release ever! Please provide me link to official package 6.18 for Tile.
honzam
Re: v6.19 released
Sun Sep 21, 2014 9:54 am
http://download2.mikrotik.com/routeros/ ... e-6.18.npk
nz_monkey
Re: v6.19 released
Mon Sep 22, 2014 2:05 am
+1 we are still running 6.5 in prod, and are only now an entire year later evaluating 6.19 for our next upgrade.
Zdenekhb
Re: v6.19 released
Mon Sep 22, 2014 11:42 am
Tested 6.19 on SXT5G-HnD Link... but Throughput is very bad.
Link is Only-N, 20/40 above, nv2 signal -40dB to -45dB on both chains. no wireles-fs enabled
6.19 winbox freeze ... try BTest and Throughput is 1-10mbps (WTF?) in 1TCP connection
Downgrade to 6.18 Try Btest and Throughput si 70-80Mbps in 1TCP connection.
Zdenek
zyzelis
Re: v6.19 released
Mon Sep 22, 2014 11:47 am
Zdenek
What about other end?
Try to enable wireless-fp with 6.19 and i think your wtf will change to wow :).
onnoossendrijver
Re: v6.19 released
Mon Sep 22, 2014 1:37 pm
Zdenek
Well, -40 to -45 is a bit strong. Try adjusting it to -50 to -55.
k0st3k
Re: v6.19 released
Mon Sep 22, 2014 10:52 pm
how to uninstall dude ? :)
jarda
Re: v6.19 released
Tue Sep 23, 2014 12:31 pm
Netinstall? Or maybe from console if possible?
k0st3k
Re: v6.19 released
Tue Sep 23, 2014 1:20 pm
in console not possible.......i think only netinstall can help :shock:
voxframe
Re: v6.19 released
Tue Sep 23, 2014 3:28 pm
Any updates on 6.20 progress?
zervan
Re: v6.19 released
Tue Sep 23, 2014 10:17 pm
I was explaining that: I thought that since there are public RC versions to download, each "stable" version is tested enough. Now I know that I was wrong. Why I upgraded so early? Because today is the last working day of public holiday here and there is only small part of users in those organizations working. Next week it would be worse.
Sorry, but if a software is stated as "stable release", it should work and it is not good to test each version again. Here in 6.19 I found two bugs which are serious for my usage, but only a few users use this specific functions. Which version should I stay in? Almost in each version I've found some bugs, hoping next release will fix them. In some version before there was a bug related to multiple SSTP sessions (disconnecting), it was fixed. Some bugs nobody else reported here, just me - e. g. DHCP Leases Address List problem (it should be fixed in 6.20rc6, but it was just partially, still not fixed in 6.20rc9 which I tested latest). So what should I wait for? This kind of bugs I will not see immediately - it will take a time. Waiting is not a solution.
Many will agree that Mikrotik should really improve development. Why not to have odd (new functions and improvements) and even (just fixes) versions? I am recommending and implementing Mikrotik products - but it is shame when my customers are complaining that something stopped to work after upgrade.
noyo
Re: v6.19 released
Tue Sep 23, 2014 10:36 pm
I would urge you not to upgrade to 6.xx, is broken. MikroTik not fully test their software, only counts on the free beta testers
We pay, require an efficient software
All v6.xx is fucked in full.
I had updated a couple of RB711, Lite5, RB2011, RB912 to v6.19 or 6.7, and each August restarts from time to time due to the watchdog.
Watchdog has never been set - the default configuration.
After the downgrade v6.19 to v6.7 CPU up to 100% (ipsec). IPsec has never been used.
It helps to CPU 100% IPSEC:
/system package disable security
/system reboot
#waiting for restart
/export file=conf
/system package enable security
/system reboot
/system reset-configuration no-defaults=yes keep-users=yes run-after-reset=conf.rsc
#A couple of times I did not work, so I need inputs on the mac and perform again
Ticket#2014091366000293
Looks like some problems with installation. Would it be possible to netisntall
that boards, It will format all partitions and install valid RouterOS version
Downgrade ALL to v5.26 and firmware 3.10.
littlebill
Re: v6.19 released
Wed Sep 24, 2014 3:42 am
6.7 sstp server 2011 --- Map2n 6.19 sstp client. upload will never go above .75 mbit,
i was barely able to get down to 6.7 and i was able to go over 7mbit on tunnel, but i have the same IPsec 100 % cpu usage
i tried netinstall 6.7 but the unit will not boot correctly with default config. it came shipped at 6.15, so not sure it can go that low, really wish it would, unit is kind of useless right now
and no i won't upgrade off 6.7 till we have proven vpn is working reliably
savage
Re: v6.19 released
Wed Sep 24, 2014 12:09 pm
Hopefully this is a cosmetic bug...
[admin@MikroTik] > /system resource print
uptime: 10m55s
version: 6.19
build-time: Aug/26/2014 14:05:51
free-memory: 1841.2MiB
total-memory: 1893.6MiB
cpu: Intel(R)
cpu-count: 16
cpu-frequency: 2127MHz
cpu-load: 0%
free-hdd-space: 146.5GiB
total-hdd-space: 146.7GiB
write-sect-since-reboot: 14730
write-sect-total: 14730
architecture-name: x86
board-name: x86
platform: MikroTik
[admin@MikroTik] >
The server has 12GB of memory, not 2GB. It looks like the 1 before the 2 has been cut off (both in winbox, as well as console).
Also experiencing RX errors on a Intel 10Gig interface (looks like a constant 1/sec), currently downgrading to 6.18 to see if it's version related or not.
snoppy
Re: v6.19 released
Wed Sep 24, 2014 1:11 pm
memory more then 2G can used onle in CCR
on other platforms ROS only 2G max.
mperdue
Re: v6.19 released
Wed Sep 24, 2014 5:33 pm
Our system is running a mixture of 6.1 on the AP's and 5.6 on the clients.
I pulled copies of 6.9 and decided to first upgrade the miscellaneous units that I had here in the office.
Out of 13 units upgraded to 6.9, 6 units would not restart or respond after reboot.
3 rb133c's (using mipsle code)
1 rb 411 (using mipsbe code)
1 rb 750 (using mipsbe code)
1 rb 911 ((using mipsbe code)
I managed to recover the 411, 750 and 911 units using netinstall and did manage to get 6.9 on it.
The rb133c's won't take any version that I offer them. Though I am going to take them home this weekend and try using a an old win xp machine com ports due to the usb com port option I am trying to use in a Win 7 machine.
I simply can not take the chance of upgrading clients and not having there units upgrade as expected. I can not pay for service calls to go replace units when they fail to upgrade. And I have probibly 20% of my network still on rb133c's which I have had a 100% failure rate on.
Has anyone else's experience been this way?
Regards,
Michael Perdue
SmythNet, CEO
www.smyth.net
276-783-3333
Thalid
Re: v6.19 released
Wed Sep 24, 2014 5:49 pm
These units are probaly to old to run ros v6
in general units support 2v updates and these boards are from around 2006
http://routerboard.com/pdf/rb133ugA.pdf
mperdue
Re: v6.19 released
Wed Sep 24, 2014 6:06 pm
Then why would they release 6.x code for them then?
Ljubo
Re: v6.19 released
Wed Sep 24, 2014 6:18 pm
Regards,
Michael Perdue
SmythNet, CEO
http://www.smyth.net
276-783-3333
Thalid
Re: v6.19 released
Wed Sep 24, 2014 6:22 pm
just refering to what i read in some older posts like this one
http://159.148.147.201/viewtopic.php?f= ... us#p161880
bazzer
Trainer
Trainer
Re: v6.19 released
Wed Sep 24, 2014 7:13 pm
It states "RB111, RB112, RB133C, RB150 devices are not supported in v6, please use v5." on the download web page. http://www.mikrotik.com/download
mperdue
Re: v6.19 released
Wed Sep 24, 2014 7:48 pm
Ok, thanks. At least now I know why 6.x bricks the units and that I'll be unable to upgrade further. - Michael
SiB
Re: v6.19 released
Sun Sep 28, 2014 4:20 am
21:41:30 ipsec,error phase1 negotiation failed due to time up. 01d4db047a60b9bc:0000000000000000
21:42:30 ipsec,error phase1 negotiation failed due to time up. 77ef7ebbe6072755:0000000000000000
21:43:30 ipsec,error phase1 negotiation failed due to time up. 84b2038687046a7f:0000000000000000
21:44:30 ipsec,error phase1 negotiation failed due to time up. 42deffb07e877772:0000000000000000
21:45:30 ipsec,error phase1 negotiation failed due to time up. 51399cc76d9cf438:0000000000000000
21:46:30 ipsec,error phase1 negotiation failed due to time up. 06bded99cac5be7f:0000000000000000
21:47:40 ipsec,error phase1 negotiation failed due to time up. 89a97510102ce77c:0000000000000000
21:48:40 ipsec,error phase1 negotiation failed due to time up. 3f89e001a721cbab:0000000000000000
21:49:50 ipsec,error phase1 negotiation failed due to time up. 218823fc05c11ed0:0000000000000000
21:50:50 ipsec,error phase1 negotiation failed due to time up. b6863d33d03abd58:0000000000000000
21:51:50 ipsec,error phase1 negotiation failed due to time up. 56afaac137289cf2:0000000000000000
21:52:50 ipsec,error phase1 negotiation failed due to time up. 3ba12327f25ba182:0000000000000000
21:53:50 ipsec,error phase1 negotiation failed due to time up. 9772820fef218c03:0000000000000000
21:54:50 ipsec,error phase1 negotiation failed due to time up. e0f9cea084fc72f2:0000000000000000
21:55:50 ipsec,error phase1 negotiation failed due to time up. f699872d6c861076:0000000000000000
21:56:50 ipsec,error phase1 negotiation failed due to time up. d14bf652f5792b1d:0000000000000000
21:57:50 ipsec,error phase1 negotiation failed due to time up. 29f50f1bcfb494ed:0000000000000000
21:58:50 ipsec,error phase1 negotiation failed due to time up. 0d818de75296c237:0000000000000000
+1
now 3th try to upgrade... v6.19 stable for 3h and wait for specific reason to do downgrade into v6.4, I hope this release is truly stable.
Support file was send to MikroTik Support Team (I before enable logging ipsec as debug to memory).
Clauu
Re: v6.19 released
Sun Sep 28, 2014 12:05 pm
Ipsec errors here too, rb2011uias+6.19
> ipsec,error failed to get valid proposal.
> ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
> ipsec,error phase1 negotiation failed.
supout sent to mikrotik
miguelgoncalves
Re: v6.19 released
Mon Sep 29, 2014 12:54 am
I was about to deploy an RB450 as a router to an OOB management network where rock solid stability is a must. I will throw this RB450 in the trash and use another thing.
- Beta testing in a production environment is not for me.
- Reading a thread on a forum to determine if a stable version is really stable is not for me. It takes time. Time is money. With this development pattern MK is not that cheap.
Alternatives? I will be using pfSense on an ALIX board for this situation. For everything else: Cisco. It's expensive but it works! They publish firmware updates with small changes and they tell exactly what has been changed. The software version I am using in my ASAs is 8.4.7(22). They will stop providing corrections for the 8.4 line in March, 2016. This is 18 months away. This kind of information is required for a production environment. I don't understand MikroTik. I really don't.
Cheers,
Miguel
jarda
Re: v6.19 released
Mon Sep 29, 2014 10:37 am
I am willing to pay post fee if you would like to send it to me instead throwing it to trash.
vb101
Re: v6.19 released
Tue Sep 30, 2014 10:23 am
One effect that I experienced after upgrading from 5.25 to 6.19 on a RB951G and then restoring a backup file taken from another RB951G running 5.25 - routing & switching through the device was quite slow (5-7Mbit/sec), in the end the issue was resolved after reseting mac-address on master interface of the switch group, it seems that overriding mac address for the switch group interfaces was causing slow switching & routing.
steen
Re: v6.19 released
Tue Sep 30, 2014 6:02 pm
Cheers,
Miguel
Hello Folks!
We had to give up on MT devices in some situations due to two things, policy based routing and l2tp tunnels could not pass more than some megabyte of data till they simply stopped passing traffic. The lt2p MT devices is stuck in RoS6.7, which in our case is very many devices at all customer and company side offices.
The policy based rotuing devices where replaced with ASA5510, which works like a charm since years back. We do not like to be stuck in low versions, neither do we like to use the very big power consuming ASA5510 and catalysts switches, which also is expensive to buy and keep, but they do work.
However we have a success story with all MT wireless devices, they saved our company wireless business. The same goes for CRS 125 switches, they have been successfully implemented on our datacenter and replacing older cisco switches, but they do lack one cruical function and that is spanning tree, which makes them impossible to build redundant layer 2 network. For that we still uses cisco and hp switches.
But who knows, in some future even MT will fix policy based routing and that l2tp tunnel bug and implement spanning tree in CRS 125 swiches.
Overall, without Mikrotik devices, our company had been out of business years ago!
paoloaga
Re: v6.19 released
Wed Oct 01, 2014 3:18 am
One mandatory feature is Per VLAN Spanning Tree, which prevents us from switching old Cisco switches to CRS ones.
ste
Re: v6.19 released
Wed Oct 01, 2014 11:42 am
Now I run into a MPLS Problem with v6.19. After a connected bridge was updated/rebooted the bridged
network (even MPLS routers own address) is no longer reachable from our network. The route distributes
in ospf and LDP but packets do not get through. I cant repair it be disabling enabling the interface. Seems
I have to reboot the router and kick some hundred customers.
I am really pissed to debug all the time. Sent supout ...
aizhihuxiao
Re: v6.19 released
Wed Oct 01, 2014 12:18 pm
I found a bug when using routeros to be pptp client.
some problem cause pptp tunnel disconnected, but pptp client still hang in there. It will not reconnect automatic, I have to disable pptp client and enable again then it works.
zyzelis
Re: v6.19 released
Wed Oct 01, 2014 1:25 pm
Hello ste,
try to disable rstp on affected bridges. :)
ste
Re: v6.19 released
Wed Oct 01, 2014 2:25 pm
Hello ste,
There are bridges (physicaly) connected. The interface to this bridges is not bridged within ros.
So for sure no rstp problem.
ste
Re: v6.19 released
Thu Oct 02, 2014 10:34 am
A nightly reboot solved the problem ... for a while.
So there is a bug in MPLS which might be in a place near you ... soon.
sergejs
Re: v6.19 released
Thu Oct 02, 2014 12:34 pm
Users browsing this forum: bertus, Bing [Bot], dervomsee, infabo, mgual, Mr47, pe1chl, pmcsill, unam83 and 124 guests
