Tue Sep 23, 2014 11:01 am
1) Wireless client part:
-put the security profile (if any), station mode, right SSID, band, country, and apply. Your wlan interface should be in "R"(unning) state.
-add a DHCP client on the wlan interface. You should get an IP address (if wireless provides DHCP) and be able to ping some hosts on the internet.
2) Ethernet part
- Create a bridge. Assign all ethernet interfaces as bridge ports (eth1 to eth5). You can also use the switch chip but let's make it simple.
- Assign a private IP/network like 192.168.0.254/24 on the bridge interface
- Create a DHCP server on the bridge interface, using the "DHCP setup" button.
- Add a masquerade rule like "/ip firewall nat add action=masquerade chain=srcnat src-address=192.168.0.0/24
Plug something with a DHCP client on the ethernet, it should get a 192.168.0.0/24 address and able to get to the internet.
