tarekomari
lost wireless port netmetal 5
Mon Oct 20, 2014 12:34 pm
Netmetal 5,
I lost wireless port and after doing the upgarde to 6.20 /rb firmware 3.18.1 it still no wire less port
CyberTod
Long time Member
Long time Member
Re: lost wireless port netmetal 5
Mon Oct 20, 2014 1:55 pm
Check if for some reason you did not switch to wireless package. The wireless module of Netmetal 5 requires the use of wireless-fp package.
tarekomari
Mon Oct 20, 2014 5:07 pm
No wireless port at all, see photo???
jvkassar
Mon Oct 20, 2014 6:29 pm
I had the same problem. Reset equipment. I went back to 6.19, climbed 6.20. And now wireless appears.
Is there any problem with NETmETAL. I have a link with rb912(NETBOX5) duplicate. With 921 on the same link, does not work well, even by setting N.
IN AC, the behavior is worse.
We are waiting for a stable version for Netmetal. We had several crashes. When you change the power, the radio turns off the ether port. Is working better with 6.19 in the firmware is 3.17.
Lupin
Mon Oct 20, 2014 8:48 pm
Yes, there are many bugs.
For example on my netmetal (6.19) when I start a wireless snooper device crash
They need some fixes
jvkassar
Wed Oct 22, 2014 3:07 pm
Installed RouterOS-mipsbe-6.21rc17.npk. AC remains broken. Lose interface. Reboot ethernet. IN N, does not crash when you change txpower or frequency. But compared the band in 6.19 or 6.20 dropped by half.
tarekomari
Sat Oct 25, 2014 8:44 am
Lupin
Sat Oct 25, 2014 7:19 pm
What's new in 6.21rc22 (2014-Oct-24 10:29):
*) wireless - fixed scanning tool crash for 802.11ac interfaces
*) wireless - fixed Nv2 kernel panic on 802.11ac interfaces
tarekomari
Thu Oct 30, 2014 9:34 am
Thank you all, the problem solved by using wireless-fp pakage
Users browsing this forum: No registered users and 58 guests
