Hello Folks,
I have a problem with a PtMP solution.
The distance of Station1 to the AP is 50metres and to Station2 to the AP 700 metres. Station 2 is nearly behind a tree so I have to make 10dbm to get a normal receive level at the AP and vice versa. My station 1 is getting a lot of power RX-31dbm and is almost damaged.
Is there a solution to fix this problem to reduce the RX level on station1?
Re: Problem is solved
