It seems that in the 6.21 v(maybe earlier) I found a bug.
I have a routerboard (UAHR) with such config:
1 wireless card working under station mode and connected to the AP. DHclient works on that interface
1 wireless card working as ap bridge. Added to the bridge local. DHCP server started on bridge local.
1 ethernet card connected to the pc. Added to the bridge local
When the first connect apperared using 1 adapter the card obtain the address from DHCP pool of internal DHCP server. Not from the server of external AP. If we disabled the RB DHCP server before the first connection than everything is OK and next time also OK. But if the wireless networks of external AP is not ready than all the next times after the seconds of initial connection wireless card get the incorrect address from internal pool.
