Lupin
PTMP Bad Throughput
Wed Dec 10, 2014 1:10 am
I've a Metal with 38 clients connected NV2 with RouterOS 6.22 (Wireless-fp enabled)
All clients are RouterOS>= 6.15 with Wireless-fp
I upgrade a client to (Groove 5Hn) RouterOS 6.22 without success
When I start a BWTest UDP I see 20-22Mbps but REAL TCP (speedtest or TCP BWTest 4 sessions) see 6-7Mbps
I've tried the best frequency on the AP, also tried TDMA=auto and TDMA=2ms
The rate of the station is 65Mbps-20MHz/1S and CCQ is 90%, signal -57/-58 dBm
Current bandwidth on the AP is 4-5Mbps
Why I've this bad real throughput
Lupin
Re: PTMP Bad Throughput
Wed Dec 10, 2014 12:25 pm
Test UDP
Test TCP between two CCR
Signal
sonny
Thu Dec 11, 2014 11:04 pm
set tdma to 2 or 3
reduce TX power until the client get´s rx -68-70 per chain
may be your channel is not interference free.
You should get 38-42 mbit/s
Lupin
Mon Dec 15, 2014 9:26 pm
96% CCQ and bad TCP Throughput... why ?
I can't reduce tx-power because:
1 - longest client has no benefit
2 - with a -70 connection is very bad
But I ask why I see HIGH CCQ and bad performance.
Something wrong in the CCQ ??
uldis
Tue Dec 16, 2014 12:49 pm
If you enable the regular wireless package on the AP do you still see the low throughput?
sonny
Tue Dec 16, 2014 6:40 pm
Here is a screenshot from some of our installations testing 6.23
TDMA 3 Wireless FP
With 6.23 RX/TX was 1db better as in 6.19 maybe TCP throughput is a bit worse. But ping is o.k.
B-test TCP 1 stream to a client 5 km away (CCR -> AP-RB912 -.-.-.-.- STA-RB911 -> CCR)
normal traffic arround 20MBit/s + B-test 64 Mbit/s
the Sektor shows nearly 87 Mbits/s
UDP is between 120-140 MBit/s
Lupin
Tue Dec 16, 2014 11:15 pm
I enable the REGULAR WIRELESS package, but after a restart wireless interface disappear (also after others reboot)
I had to enable the wireless-fp package and restart
Lupin
Tue Dec 16, 2014 11:32 pm
TDMA 3 Wireless FP
You have only four stations
See my situation
The selected is one of the best clients that do the test
This a test with tdm 2ms
This with tdma 3ms
Lupin
Tue Dec 16, 2014 11:34 pm
This with tdma auto
Lupin
Tue Dec 16, 2014 11:55 pm
Now see the test on the D2:F1 station alone on the same AP (I only disconnected all other stations)
With all the other stations (even if the total traffic is less than 2megabit) it seems that the thoughput collapse.
Uldis I need a solution to this behaviuor
Lupin
Wed Dec 17, 2014 12:40 am
I tried again but before restarting I disabled the wireless-fp, enabled wireless (regular) and set the TDMA = 2
But thoughput (Always on same station) is worse with no other traffic (about 300Kbps in that moment)
ahmeto
Wed Dec 17, 2014 2:37 am
sonny hello settings show it you have the same problem in the slave 40 clients connected
sonny
Thu Dec 18, 2014 10:41 pm
@lupin
there are things you have to consider.
never connect more than 30 stations
do not mix N- an A-clients
show my a spectralhistory from AP and client - may be your frequency is not free
Here is a AP RB433AH with 29 clients up to 2km. All N 20Mhz TDMA auto
Backbone1 is 8km ptmP (8STA) then 1km ptp SXT all NV2 TDMA 3
throughput generated from clients. 42 MBit/s
sonny
Thu Dec 18, 2014 10:45 pm
@lupin
try to fix datarate at ht4 or ht5
even try to use TDMA 5-8 in 10MHZ channel or auto
then do a test
Lupin
Fri Dec 19, 2014 8:10 am
Hi sonny, I set all stations and ap with band=5ghz-onlyn
on ap I set tdma-period-size=3
and lower HT (see screenshot)
But result is same 9-10Mbps TCP send to the station
10Mhz is not a solution because I need to deliver to all customers greater bandwidth possible
sonny
Fri Dec 19, 2014 9:34 am
Hi Lupin,
have you done a spectral scan at AP side?
What throughput have you masured to the nearest station?
sonny
Fri Dec 19, 2014 9:37 am
As I saw TCP throughput becomes better with MCS5
go to MCS4 or even MCS3.
If it becomes bettter, you have big interference at your used frequency.
Users browsing this forum: No registered users and 14 guests
