David1234
Can't establish connection low Rx\Tx rate low
Sun Jan 18, 2015 5:11 pm
Hello ,
I have an issue and I can't understand the reason
I have a connection , I can see the signal very good (-40dBm) but the rate is low 1.5M/1.5M so I can;t get a connection
this is the registration table :
 interface wireless registration-table print stats
 0 interface=wlan1 radio-name="Main-AP" mac-address=01:21:1E:30:5D:AE ap=yes
   wds=no bridge=no rx-rate="1.5Mbps" tx-rate="1.5Mbps" packets=103,6
   bytes=1510,645 frames=103,6 frame-bytes=1486,609 hw-frames=115,120
   hw-frame-bytes=4588,5169 tx-frames-timed-out=0 uptime=1m25s
   last-activity=750ms signal-strength=-46dBm@6Mbps signal-to-noise=32dB
   signal-strength-ch0=-46dBm tx-signal-strength-ch0=-31dBm
   strength-at-rates=-46dBm@6Mbps 80ms tx-signal-strength=-31dBm tx-ccq=57%
   rx-ccq=52% p-throughput=1296 distance=5 nstreme=no framing-mode=none
   routeros-version="5.26" 802.1x-port-enabled=yes management-protection=no
   compression=no wmm-enabled=no
I have change RB\Cable\antenna\Radio card
with all I get the same result
can it be all the radio card I have are defected ??
(other card can connect to the AP and work just fine 13.5\13.5M - so I know the problem isn't on the AP side)
Thanks ,
Users browsing this forum: Bing [Bot], GoogleOther [Bot], Sddaw and 87 guests
