I just bought RB951Ui yesterday to replace my Rb433 at home. Configured the device as POE out from ether 5 to roof and all other ethers and wlan is on bridge. The problem is that i can access to internet on my Galaxy S5 with very good rates ( 144Mbps/144Mbps) , but with my 2 laptops i cant even ping them from the routerboard ( i can ping them on ether). Signal to Noise is below 40db CCQ is around %40-50 although signal is around -40-50. Tried every frequency , Channel width ,Band options, HT options but results are all the same. 2 laptops do not have internet.Will be appretiate if you help me with this situation.
Thanks.
