pyrzy
Re: How to make the connection to the second HotSpot
Tue Feb 03, 2015 3:40 am
Hello everyone,
I would like to use existing equipment BT-router and panels antennas (set as point to point) and install 2 omni directional antennas with the free Hotspot. The Hotspot with the customised website is set up on the Routerboard (192.168.0.2) and the local Omni directional antenna A is connected to that router to Port 5 which was set for the Hotspot and works fine. The both omni-antennas have metal routerboard connected and Ethernet Port is set for DHCP client which should be taken from the main routerboard. The only problem is that I don't know what is the best way to connect Omni Directional Antenna B to the routerboard's Hotspot which is connected to another network?
I 've already tried change the static IP of the Omni Directional Antenna B to the same network as hotspot, tried to add static route on the BT router for the hotspot network (192.168.5.0/24), also I tried to use bridge ports/interfaces on the routerboad. Unfortunately, so far I cannot resolve the problem. Should I use the EoIP tunnel between the routerboard and omni directional antenna B?
I look forward for your comments.
Kind regards,
Peter
czolo
Sun Feb 08, 2015 11:44 am
Hotspot works on interface. I see that you haven't configured hotspot on port-1 on main router. You can use gre/eoip tunnel and bridge it with port-5, and it should work.
Alternative is a modification of firewall rules on main router. You have to change the rules that describes the traffic that is redirect to hotspot page. Normally this rules are added automaticly.
Users browsing this forum: Bing [Bot], Tegarrti and 79 guests
