I have a RB951G-2HnD,and i setup an ap,the top speed is about 3MB/s when i downloading movies through WIFI from another device,is that normal?The TX/RX rate is about 270Mbps/270Mbps.
The log about wireless showing something,what cause this?
signal to noise 62dBm
TX/RX signal strength -40dBm
TX/RX signal strength ch0 -50dBm
TX/RX signal strength ch1 -47dBm
TX/RX CCQ above 90%
0 name="wlan1" mtu=1500 mac-address=D4:CA:6D:93:D3:40 arp=enabled disable-running-check=no interface-type=Atheros AR9300 radio-name="D4CA6D93D340" mode=ap-bridge ssid="" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2412 band=2ghz-b/g/n channel-width=20/40mhz-ht-above scan-list=default wireless-protocol=any
rate-set=configured supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps max-station-count=2007 distance=dynamic tx-power=17
tx-power-mode=all-rates-fixed noise-floor-threshold=default nv2-noise-floor-offset=default periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none
wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00
ht-ampdu-priorities="" ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2
nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key="" hw-retries=7 frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled
hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced multicast-helper=default multicast-buffering=enabled
1 R name="wlan2" mtu=1500 mac-address=D6:CA:6D:93:D3:40 arp=enabled disable-running-check=no interface-type=virtual-AP master-interface=wlan1 ssid="503-WIFI-1" area=""
max-station-count=2007 wds-mode=disabled wds-default-bridge=none wds-default-cost=0 wds-cost-range=0 wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled
default-authentication=no default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no
security-profile=default multicast-helper=default multicast-buffering=enabled
02:23:25 wireless,info wlan2: data from unknown device 44:2A:60:DB:9F:D6, sent deauth
02:23:30 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
03:07:44 wireless,info F0:27:65:4D:AA:0D@wlan2: connected
03:19:51 wireless,info F0:27:65:4D:AA:0D@wlan2: disconnected, received disassoc: sending station leaving (8)
03:19:51 wireless,info wlan2: data from unknown device F0:27:65:4D:AA:0D, sent deauth
03:26:59 system,info traffic generator config changed by admin
03:39:27 system,info,account user admin logged out from 10.0.0.8 via winbox
03:39:48 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, received disassoc: sending station leaving (8)
12:04:26 wireless,info F0:27:65:4D:AA:0D@wlan2: connected
13:17:57 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
13:55:54 wireless,info F0:27:65:4D:AA:0D@wlan2: disconnected, received disassoc: sending station leaving (8)
13:55:54 wireless,info wlan2: data from unknown device F0:27:65:4D:AA:0D, sent deauth
15:54:44 system,info,account user admin logged in from 10.0.0.8 via winbox
15:56:39 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
15:56:39 system,info device changed by admin
15:56:39 wireless,info wlan2: data from unknown device 44:2A:60:DB:9F:D6, sent deauth
15:56:40 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
16:01:11 system,info,account user admin logged in from 10.0.0.8 via telnet
16:02:21 system,info,account user admin logged out from 10.0.0.8 via telnet
16:08:55 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
16:09:05 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
16:09:06 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
16:09:18 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
16:09:24 system,info,account user admin logged out from 10.0.0.8 via winbox
16:09:34 system,info,account user admin logged in from 10.0.0.8 via winbox
16:09:46 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
16:09:57 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
16:10:04 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
16:10:04 wireless,info wlan2: data from unknown device 44:2A:60:DB:9F:D6, sent deauth
16:10:04 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
16:10:13 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
16:10:24 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
16:10:25 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
16:10:35 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
16:10:40 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
16:10:50 wireless,info wlan2: data from unknown device 44:2A:60:DB:9F:D6, sent deauth
16:10:51 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
16:10:56 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
16:10:56 wireless,info wlan2: data from unknown device 44:2A:60:DB:9F:D6, sent deauth
16:10:56 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
16:10:58 wireless,info 44:2A:60:DB:9F:D6@wlan2: disconnected, disabling
16:11:09 wireless,info 44:2A:60:DB:9F:D6@wlan2: connected
