I was wondering if it might be possible to do a similar project like the following but with Mikrotik hardware: http://makezine.com/projects/browse-ano ... or-router/
The goal should be to surf securely in foreign/public WiFi networks. So the device should be able to connect to a WiFi network and at the same time it should establish a own, private network which is then tunneled via VPN to a gateway of your choice. Tor is not needed in my setup.
Has anybody an idea if this is feasible? Especially to run two WiFi networks one as a client one as an AP at the same time...
Lukas
