Hello!!
I have a strange issue that has never cropped up before while using Capsman. I am running Version 6.31 and have also used 6.29.1 and no difference. I have 2 devices one is the mikrotik Rb2011 main router and the other is mikrotik RB433 access point. I have 2 SSID setup on the main router in Capsman - Guest Wifi and Internal Wifi. They both work great on the RB2011 but when I enable Capsman on the RB433 AP it only pushes over the Internal Wifi and not the Guest Wifi SSID and settings. the Internal Wifi also works great on the AP. Come someone please help with why this would be happening?? I have done many of these with same setup and never had this issue. Thank you in Advance!!
