It should be possible to run a dude client on a Windows machine and send SMS notifications from there.Yes best news but its bit difficult for us to use it now without any android client (showing notification is enough)
after all we can't keep a pc on 24/7 and then pay a staff to look at the event if your network is small
so mikrotik please announce a dude android client that can just show notification
All on this list should consider that The Dude is free. Maximizing the Feature wish list might be frustrating for the developer. Developing an maintaining an Android app is a seperate Project which takes a lot of time and effort. I am happy when the Dude itself gets some work done first.Thanks normis for confirmation
but please consider a native android app that can show the host and interface downtime alerts
also please confirm if Mikrotik PHP api will work with dude or not
Browsing does not help. You need a notification on the Smartphone. So a sound and something in the notification bar. SMS is the best for this as it does not need a (permanent) data connection of the receiving Smartphone. My dude sends SMS even if it is not reachable by Network (something I Need to know) as it has a UMTS Dongle.But why develop a separate Android app. I want this functionality too of course. It will be easier if the Dude server package gets a small menu in winbox for showing alert log and currently downed hosts. And this menu can be browsed in Tik-App.
What you are proposing will be good for many people, but it will take more time. And I'm not saying it should not be done, but I don't expect it any time soon. And my network is not so small so I don't want a notification for all devices. For important ones I am using NMA (Notify My Android) - it works very good, i just set an email target for alert, type my nma account there and recieve a push notification on my phone.Browsing does not help. You need a notification on the Smartphone. So a sound and something in the notification bar. SMS is the best for this as it does not need a (permanent) data connection of the receiving Smartphone. My dude sends SMS even if it is not reachable by Network (something I Need to know) as it has a UMTS Dongle.
Android APP is nice to have but not at the first place.
How send SMS by 3G modem with out windows ? Use only CCR + usb 3G modemDude windows client can already exectute local utilities and batch files. It can run a tool that sends an SMS. You don't need an app or RouterOS support for that.
You need Dude Windows client in any case. Server does not do anything without the Windows Client.How send SMS by 3G modem with out windows ? Use only CCR + usb 3G modemDude windows client can already exectute local utilities and batch files. It can run a tool that sends an SMS. You don't need an app or RouterOS support for that.
Да как так ???You need Dude Windows client in any case. Server does not do anything without the Windows Client.How send SMS by 3G modem with out windows ? Use only CCR + usb 3G modemDude windows client can already exectute local utilities and batch files. It can run a tool that sends an SMS. You don't need an app or RouterOS support for that.
The manual you linked, talks about notifications run on the Dude Client!Да как так ???
I need to run the command locally on Mikrotik where you installed dude. In wiki there is an option execute on server. Why not in reality ?
http://wiki.mikrotik.com/wiki/Manual:Th ... ifications
You can also add new Notifications, more types are available in the add dialog.
Execute on server - Run command on the Dude server machine, can pass variables
I've installed the Dude on a CHR v6.34rc after a bit effort to import the VMDK image. I think the Dude needs a mini dashboard in the Webfig/Winbox to see it's running and the current activity. ie devices scanned/min, Dude network traffic, Dude CPU%. The Dude server should send the notifications without an active client.You need Dude Windows client in any case. Server does not do anything without the Windows Client.
why in the wiki, there are two points, and only one in the interfaceThe manual you linked, talks about notifications run on the Dude Client!
You are mixing up Server and Client sides. Please read the manual carefully.
Manual is about Client, a Windows program.
Server on RouterOS is only checking device status. All actions are done in the Dude Client!
both teams dude performs client ?The Notifications pane configures any actions that can be taken when a device status changes. The predefined Notifications are the following:
Beep - Makes a beeping sound from the PC speaker of the server PC
Flash - Flashes the Dude taskbar menu
Log to Events - Saves information to local Event log
Log to Syslog - Saves information to Syslog
Popup - Opens a small notification window
Email - Sends email, need to specify Server address. Authentication not supported.
Execute locally - Run command on the local Windows machine (where Dude viewer runs), can pass variables
Sound - Plays sound. Sound files can be uploaded and chosen here
Group - Executes a group of actions
Speak - Uses Windows speach ability to say the message in a computerised voice
Log - Saves to local Dude Log file
Syslog - Saves to remote Syslog server. Need to specity Syslog address
I did this a bit it differently, I addend another disk to VM and changed dude data path to it.In a VMware install how do you increase the Disk capacity of the CHR device. VMware can be used to increase the allocation but there's no means for the CHR to merge the extra allocation. This would soon need to be done with a large Dude install.
You are using The Dude client on which OS? I haven't noticed it doing so on win7, win10 or linux under wine with win8 set as OS.The minimize control on the top right of the window crashes the Dude client and it quits.
When ?Running Winbox, scripts, exporting maps, executing commands on the server - those things don't work yet, but we will work on those.
We released it one day ago, previous release was five years ago.When ?Running Winbox, scripts, exporting maps, executing commands on the server - those things don't work yet, but we will work on those.
As soon ?
I'm running the client on Win7. It crashes every time when minimized.You are using The Dude client on which OS? I haven't noticed it doing so on win7, win10 or linux under wine with win8 set as OS.
If client when crashing gives out any crash log please send it to us. So far I can't reproduce this behavior tried with multiple client versions. You might also want to try clean the dude install just for experiment.I'm running the client on Win7. It crashes every time when minimized.
Uninstalled, Rebooted, then reinstalled. Same crash when minimized but no errors or crash log in the Dude directory.If client when crashing gives out any crash log please send it to us. So far I can't reproduce this behavior tried with multiple client versions. You might also want to try clean the dude install just for experiment.I'm running the client on Win7. It crashes every time when minimized.
Yes. One of the first crashes I experienced Dude forgot the most recent changes where as a close included the most recent changes.How does it crash then, if there is no error message? Just disappears?
Just a thought, Are you using a CHR with bandwidth limited interface? Looking at the transfer on the client it's getting slowed in it's communication because of the trial setting of CHR.So far I can't reproduce this behavior tried with multiple client versions.
I have some of each type of the dude servers, including limited and no-limit CHR servers. Client does not experience any minimize problems with any of them.Just a thought, Are you using a CHR with bandwidth limited interface? Looking at the transfer on the client it's getting slowed in it's communication because of the trial setting of CHR.
Earlier when I tried to do a channel scan on a Groove the Dude crashed with a report. I emailed the crash dump and the ticket is "[Ticket#2015120666000155] RE: Dude 6.34rc16 crash". Hopefully this will help to id version and linked libraries.I have some of each type of the dude servers, including limited and no-limit CHR servers. Client does not experience any minimize problems with any of them.Just a thought, Are you using a CHR with bandwidth limited interface? Looking at the transfer on the client it's getting slowed in it's communication because of the trial setting of CHR.
what's the reason? it should be in Log after rebootTried few times to re-download file and re-upload it to winbox. It just doesnt want to install.
Any suggestions?
This is a know problem and it is awaiting fix. I had noted it in known issues of this first build in first post.Earlier when I tried to do a channel scan on a Groove the Dude crashed with a report. I emailed the crash dump and the ticket is "[Ticket#2015120666000155] RE: Dude 6.34rc16 crash". Hopefully this will help to id version and linked libraries.
I don't quite get your request. Either way in links menu it is possible to add notes to each link. Can't you add this info there?Hi
i have sugestion for Mikrotik team. Please add the comment box next to the property static. This makes it possible for example. Describe fibers with a fiber distribution frame. It would have been nice if the memo field as the field label was a device which can break down the rows.
Good Job whit dude back:)
This is a know, issue. Thank you for reminding me of it.When I added a few networks in network maps and started to conf it, I saw that in the settings of any map I see all avtoscan. Previously, each map had its avtoscan.
When I try to go inside the map, I see only Loading ...
Reproduced. Yet again thank you for report.then i try to ping some host, windows client disconnected from the server, and reconnected after a few seconds
Reproduced. Thank you for report.When i set dependence i cant copy/delete parent anymore.
Thank you for suggestion. I did that:Maybe you can try to make the users in new dude server first, log by the user existing in the imported file and then try to import. It may help.
dude import-db file=backup-2015.12.08.tgz
It was (sha1 sums):@eine
* That x86 installations is CHR image or standard ROS?
* Generate supout file on that ROS where dude server is working and send it to support. I'll check what I can see in debug log side.
If you want to start with dude it is the safest way to install 4b3 in Windows environment. At least until the new ros dude package will be widely proven to be able to work correctly. Then you can move to it if you see it useful for you somehow.Probably a dumb question - but you are discussing this running on arm - you are talking about the client right?
Not the router, i.e. so the dude package will run on the rb3011 right?
I am, obviously, new to The Dude. Does anyone recommend a "newbie" guide or getting started post? I will begin here and search through the forums. I did find the Mikrotik Wiki on the new Dude. Just wondering if anyone had a great resource they would recommend.
Thanks in advance!
I tried several times, but he always comes back@foxch2
I have seen similar problem that sometimes changes are not being saved. However I haven't found a way to reproduce it. It tends to happen only now and then plus without any logic in actions that you perform in dude. Most probably if you will try it again the deletion of probe will be executed.
We have published the first public test of our restarted project The Dude. At the moment it is just a refreshed version of the same Dude software that we had in v4b3, but is adapted to work correctly with RouterOS v6 with a few minor changes in it. This will be a base on which we will start building The Dude for the future.
* The Dude server is now a RouterOS npk package that must be updated together with RouterOS
* The Dude client is pretty much the same as it was before just with server side removed. If it will detect that servers side is running newer version it will offer to update it self to matching version.
Removed features:
* Windows server
* Language selection for The Dude client
* Web interface
http://wiki.mikrotik.com/wiki/Manual:The_Dude
By what developer thinks on this topic is that 2GB DB limit might have been problem on on some FAT type formatted file systems. If you attach some storage that is formatted with EXT3 fs then it shouldn't be a problem.Is 2GB database size limit fixed?
Why not? Just attach some USB hdd/ssd.It can be used on CCR, that is nice, but what about disk space? CCR has only 1GB (at least 1036 has) and flash is not good for heavy writes. Is it possible to store the Dude data to an external storage?
Thanks....
I already have asked for it: http://forum.mikrotik.com/viewtopic.php ... 89#p510689UPD: Another good feature would be vacuuming of the sqlite3 database.
Well I just confirmed it ... DUDE on the free ROUTER OS is crippled because of the 1mbit traffic cap.
With well over 100 nodes with almost all doing snmp traffic graphs and other custom stuff limits its ability to properly monitor the network as I did with the 4.0beta until I can find a work around I cant use this version.
Do you mean in the new CHR?
Or are you saying there is now a 1Mbps routing limit on x86 Free license?
AFAIR x86 Free License has no routing performance limit, just the limited number of some other features. For CHR Mikrotik clearly announced a 1Mbps limit on that at the moment while they work on it and sort out licensing.
Regards
Alexander
Just to add my penny's worth, Inconvenient is my situation too, Ill have to stick to the old version until a windows version is available again, I'm not about to get a x86 server just to run the Dudeit is still inconvenient. But I can live with the old version, no problem. Since others are happy with the new direction
We are aware of this enhancement request.I have two things,
1 reqeust
1) Is it possible to add authentication to email settngs.
Now it is not possible to configure email notifications when the server requires authentication.
Wiki link:2 question
2) Is it possible to use the Dude as syslog server for all our devices?
Must I send the syslog events to the Dude server?
Please some help.
If you mean DB import/export, then yes. It has been moved to ROS cli side.- Fix the 'export to file' in Windows client. Now the client crashes and fails to make an export on large Dude setups (though I see you added this function via cli, so it's probably going the right way);
Some examples please from recent build. DEV seems to remember such problem only from older v3 dude.- Fix the 32-bit only SNMP counters and do something to make it possible to collect RB260GS bandwidth graphs (again - MT ecosystem!);
We will think about what to do with winbox in the dude client, dev is aware of this request.- Upgrade winbox in The Dude or make it possible to drop in the latest winbox.exe ourselves;
These ones are already for future the dude version, at this point we want to get it back running and deal with current bugs in it.- Make some user roles not only to limit changes to The Dude, but also for non-admin users not to be able to connect via winbox to ROS devices or even better - for different user groups to connect using different users in device's ROS (for example guest);
- Make the Dude server multi-threaded;
I Have a setup working feeding the DB on one of my servers right now. Let's see if I manage to kill it when it grows to large.Congratulations for new version of Dude .
About 2GB limitation of DB , on Dude4.0beta3 i had this problem even in ROS v6.19 so the ext3 was not the solution .
Anything changed in new version ?
The Dude server on ROS already can use at max load up to 3 cores. Provides us with some info on that we need more supouts from bigger setups and we'll check what more can we do.What about CCR performance with the Dude? Is it multi threaded? Will it work well with a network of hundreds or thousands devices?
I'll add this as enhancement request.UPD: Another good feature would be vacuuming of the sqlite3 database.
You can still use standard x86 ROS installation in some VM, just get free level 1 demo license level for the dude server. If should be perfect as there are no traffic limits there.Yes the new CHR limits the traffic that DUDE trys to create doing its tasks with in turn hampers snmp and other monitoring severally.
Regards
Alexander
that part is now done in ROS cli;any idea how to backup/restore? Those icons are gone from the client.
smtp authentication support add please
Wow, thanks! I increased the probe interval and immediately got some nice smooth graphs! Sometimes only a small communication is needed to resolve a problem Regarding 32-bit counters, well yeah, my bad then. I somehow thought it was the cause for bad RB260 probes.Some examples please from recent build. DEV seems to remember such problem only from older v3 dude.
Regarding RB260, it has really week processor so it struggles with the dude probes. The device it self should be monitored with increased probe intervals. Links with SWoS devices should however be monitored from other side linked interface. Same problem applies there, the processor simply chokes on those requests from dude.
Ok there, no rush guys. It's great even as it is and knowing it's going to become better gives even more joyThese ones are already for future the dude version, at this point we want to get it back running and deal with current bugs in it.
any estimate of when it will be deployed to support IPv6?Support IPv6 please!
Create a Mikrotik account - https://www.mikrotik.com/client/"You can still use standard x86 ROS installation in some VM, just get free level 1 demo license level for the dude server. If should be perfect as there are no traffic limits there.
http://wiki.mikrotik.com/wiki/Manual:Li ... nse_Levels"
Clicking that link there;s a link that says registration which brings you to the normal download page and there is nothing there to register anything?
I am obviously missing something, what is it please?
Thanks leon
Oh, I'm so with you here. I run a small IT consulting company where I consult to a number of SMB clients. I am putting MikroTik MIPSBE devices in these client sites (as gateway routers as well as for their internal Wi-Fi access points) as there is no need (and no budget) for the TILE-based units. Most of these clients have the RB2011, CRS or RB950G units in place.Hi Mikrotik Team (and others using the existing version)
At the moment I (and a number of people I work with) use Dude 4.0B3 on RB450G units as dedicated low power local monitoring units in locations. These are running only the Dude and have a MicroSD card inside them for storage. Also as CCR's have begun to replace 1100AHx2 and 1200 devices I would love to be able to move these into service as Dude nodes.
I know this would be more development work for the team however I have found the 450G platform has plenty of power to run a reasonably sized node and I believe the PPC devices could likewise provide a fantastic platform and continue to make use of this hardware going forward.
If other people currently use the 450G and its ilk or have a number of PPC units they want to press into additional service and would see serious use from the Dude then please bring your use cases into a new Dude topic on use cases for other hardware platforms and hopefully we can make a compelling case for inclusion.
I can understand completely why MIPSLE may not be a good candidate for this development effort and the SMIPS platform as well, but to me the new ARM (3011) PPC (1100, 1000, 1200, 850) and MIPSBE (450, 2011) make brilliant monitoring and network administration boxes that work wonderfully for the Dude.
I know myself I use 1100AHx2 units and 450G units as network access gateways coming from the NOC, in datacentres there will be standard routers for user / public traffic and then one of the above units (depending on site size etc) with ports into various switchports / network segments and making use of VLANS and direct connections to provide an inbound direct NOC route into each L2 domain. These boxes are ex network routers which have been replaced or upgraded and have plenty of cycles free to run the dude.
Please consider adding ARM, PPC, and MIPSBE into the supported architectures for Dude ROS Package.
Regards
Alexander
So far mentioned test dude db has grown slightly larger than 3GB. No side effects or crashes so far.I Have a setup working feeding the DB on one of my servers right now. Let's see if I manage to kill it when it grows to large.Congratulations for new version of Dude .
Reproduced and reported to DEV for fixing.Minor bug report: Right-clicking on a Network Map and selecting "Open Separately" will open the Map for a split second, but then it is minimized and a small window pops up that just says "Error not implemented".
The Map still opens and is viewable, but that Error windows never appeared before the update.
Reported to DEV for fixing:Fix request: DIsplay and monitoring of 10 GBit interfaces - interface maximum speed is limited at about 4 GBit in Dude at the moment. Please increase this limit. Also a link profile for 10 GBit links added by default.r
We will check what newer images we could add to dude at some point.Feature request: Update icons for devices in Dude. Maybe have the correct icon for the actual MikroTik hardware model displayed by default, as detected by probe(s).
TonyJr
There is no such thing. Dude server only works from RouterOSI'm sorry, but I do not understand
Where can I download the new "Dude server" for Windows? (as "The Dude 4.0Beta3")
Thanks.
I think what UsernameMT is asking is where can he download the old version - 4.0b3. I also would like to know that as well. I need to get a copy just in case our current server chooses to die. I am not able to replace it with the RoS 6.34 version until the web interface it back.There is no such thing. Dude server only works from RouterOSI'm sorry, but I do not understand
Thanks.
I need an official link. I can't just trust that one I find from googling would be clean (may have a virus or have been modified.) I understand that it was not working for a few, but for the ones that it was, we should have the ability to access it. If you can just post a link in the forum with a warning that it may not work for all, I think most will be happy.It was not working for many, we don't have it on the webpage anymore. There are plenty of pages that host it, you can google for it
http://qoo.by/9xsDude server only works from RouterOS
You can make a custom label. Right click on the device and choose Appearance. In the field label, put something like this:Hi All!
tell me plz, how to display device name and IP address on a network map
now i see only name or IP
it would be nice if dude could display both values
You can also view all available display commands by clicking the "Insert Variable" button on the Appearance window.You can make a custom label. Right click on the device and choose Appearance. In the field label, put something like this:Hi All!
[Device.Name]
[Device.FirstAddress]
I'm also confirming that "right click - Tools - Snmpwalk" crashes dude. Nothing in routerOS's log...Bug report.
On fresh install on CCR1036, whit one added device, when make snmp walk TheDude server crash every time.
When import my 420mb *.xml configuration, all custom snmp function not work too.
Yeah, I'm also in no hurry to upgrade everything to new Dude. I've learned to live with the old one I shall watch it mature for a while and decide when I'd like to give it a go.It is currently not as good as Dude v4beta3. Some functionality missing, some broken. It was posted above, there is a list of know issues.
Yes, and it is very well explained in wiki...Is it possible to import a dataset from 4.0beta3 to the new version?
[admin@MikroTik] > /dude import-db file=backup-2015.12.17.tgz
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
I had the same thing. I rebooted the routerpc and now it's running.I'm trying to import from 4.0beta3:
http://wiki.mikrotik.com/wiki/Manual:Th ... nToNewDude
error:Code: Select all[admin@MikroTik] > /dude import-db file=backup-2015.12.17.tgz action timed out - try again, if error continues contact MikroTik support and send a supout file (13) [admin@MikroTik] > /dude import-db file=backup-2015.12.17.tgz action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
Thanks, after rebooting - works.I rebooted the routerpc and now it's running.
hAP lite and such devices are not powerful enough to run a Dude serverWhy the recent dude available only for x86 and CCR ?
previously available for mipsbe, mipsle, ppc and x86
where are the version for mipsbe, mipsle and ppc ?
down here, i have rb433ah with nand 512MB that running routeros 5.26 plus dude v3.6
Paul
Previously the NPK did not work at all, so we actually removed them from the webpage. That was 5 years ago. Now the server is different.previously available for mipsbe, mipsle, ppc and x86
on my case..Previously the NPK did not work at all, so we actually removed them from the webpage. That was 5 years ago. Now the server is different.
Comparing 3.6 and 6.x is not correct. They have different features and requirements.on my case..Previously the NPK did not work at all, so we actually removed them from the webpage. That was 5 years ago. Now the server is different.
i am still using RouterOS v5.26 with dude-3.6-mipsbe.npk on my RB433AH since couple years ago with no problem.
on the other hand, i am still have RB1100AHx2 with 512MB nand storage.
so i do not think there is a problem for mikrotik to release mipsbe and ppc release again.
Paul
hAP running smips, not mipsbe or mipsle or ppchAP lite and such devices are not powerful enough to run a Dude server
well.. you said that the dude on 6.34 is the resume job from the last version; it was v4.0beta2, isn't ?Comparing 3.6 and 6.x is not correct. They have different features and requirements.
by jarda » Sat Dec 05, 2015 5:44 amPlease consider adding ARM, PPC, and MIPSBE into the supported architectures for Dude ROS Package.
AFAIR, on almost on every MUM, MikroTik ask us to tell them what we need so they will deploy it. So, is it wrong if I am asking to recreate The Dude for mipsbe and ppc arch ? and as ask my Neilson and jarda, arm arch as well ?I would like to see arm, ppc and mipsbe dude packages also. And windows server back again.
The SHA1 hash for the original dude-install-4.0beta3.exe binary is D936B1D2CA7C537F9F65FEF619CA147B0E3CB525I need an official link. I can't just trust that one I find from googling would be clean (may have a virus or have been modified.) I understand that it was not working for a few, but for the ones that it was, we should have the ability to access it. If you can just post a link in the forum with a warning that it may not work for all, I think most will be happy.
Show some support and offer ideas or just leave a positive comment, because anything else just makes you sound like one of my kids trying to scream their way into a conversation among adults.This will be a base on which we will start building The Dude for the future.
I completely agree. I started 1 topic and replied to that topic 1 time in past 8 years, and it was in Dude forum. This is at the top of best announcements from Mikrotik. I may post again tomorrow just too make sure I'm not dreaming. And many more times to support its growth. Mikrotik probably won't notice, but it's the best thing I could think of to show some appreciation. Other than give them a couple grand for a nice ccrDUDE solution that works right out of the box with a HDMI port for billboard sized LIVE NETWORK MAPS. I will pay in full now if that helps.Thank You MikroTik, I am certainly excited that I don't need to find another product as good as The Dude. I have looked and looked and there are good products out there but nothing as intuitive or as visual as The Dude.
Now that makes sense. (Just a small pillow fight with negative posters)After reading the current status of the new Dude and how it works I am going to keep running my windows 2k3 server and wait for some updates.
Haven't looked for feature post yet but a few of mine are:As for features we all have a bunch of ideas and would love them to be implemented maybe we can get a feature request post started or maybe MikroTik would give us a list of features they plan to implement (after they finish the current list).
I follow your opinion. Just want to say thanks to all people involved in developing this awesome tool. Thank you guys!C'mon guys, stop complaining about not developing Dude for all existing platforms! Be a little more greatfull that this briliant and most of all FREE tool is back. I know that is is not hard to install somekind of free virtualization tool, install mikrotik and use free license, and finally install dude for x86. Maybe one day Mtk guys will eventually develop linux, unix, xenix, whatever variant of server, but for now I suggest to stop bullying developers and let them do their job. I believe that very soon Dude will be back on top of the throne of monitoring tools!
Is this just temporary or is the Windows server absolutely gone for good?Removed features:
* Windows server
Hi I've been using the new dude installed in a CCR and we see that the "ping" in any of the devices entered the program restarts.
truewith the new update, every time you make a change and restarted, the changes made are cleared and return to previous state.
Hello Krisjanis,@abis
Problem with link monitoring in cases where ROS is used as mastering type is know to us. Dev has bug report for it. hopefully it will get fixed soon.
Changes in v6.34rc32 build:
* Fixed bandwidth test tool graphs.
* Ping tool client crash fixed.
* SNMPwalk tool client crash fixed.
* Spectral scan tool client crash fixed.
* In Admins > Group policies *web removed, no longer relevant.
* In Log configuration window sliders fixed.
* Right click "Open separately" fixed.
* Export to CSV client crash fixed.
* Fixed mastering type ROS for link label
* XML backup import fixed.
* Large DB export fixed.
ps, It might take a while to export large DB files. I did test with 4.5GB db and it
did take about 5-10min to create backup file on x86 VM.
Excelent great job!Changes in v6.34rc32 build:
From my opinion is much better in this way, you can manage it more easy, less resources needed and no license for an windows server neededGOod morning...
I'm still struggling why the decision was made to abandon the windows server? RouterOS is a router; a router is not a monitoring system. ANd vice-versa a monitoring system is not a router.
So whats the real reason?
Thanks leon
FYI
If any one wants to try a third party android client: https://play.google.com/store/apps/deta ... dude&hl=en
That is a 3rd party app. MikroTik has no control over that app and probably does not support it.Your app has a couple of good reviews and a 2.3 rating, but according to your Google Play information this app was last updated in June, so does it work with this new version of The Dude or are you just plugging your product? Doesn't appear to be a way for us to even find out ourselves without signing up for a subscription with credit card and then cancelling it.
FYI
That is correct. I was also thinking of deleting the post as it has no relevance to new dude builds cause web interface from which it pulled info is no longer there. Although it might still be useful to those that use v3.6 or v4.0b3 servers.That is a 3rd party app. MikroTik has no control over that app and probably does not support it.Your app has a couple of good reviews and a 2.3 rating, but according to your Google Play information this app was last updated in June, so does it work with this new version of The Dude or are you just plugging your product? Doesn't appear to be a way for us to even find out ourselves without signing up for a subscription with credit card and then cancelling it.
FYI
Go to the MikroTik Downloads page, select "Release candidate (6.34rc39)" in the version selection dropbox, then click to expand either "tile" or "x86" section. You will find the links to download both "The Dude server" and "The Dude client" there.i didn't get this application/tool no where on Mikrotik download page. Where is the link to download this tool?
Hello Andriys! Okay thanks a lot. Got it and downloaded.Go to the MikroTik Downloads page, select "Release candidate (6.34rc39)" in the version selection dropbox, then click to expand either "tile" or "x86" section. You will find the links to download both "The Dude server" and "The Dude client" there.i didn't get this application/tool no where on Mikrotik download page. Where is the link to download this tool?
@jstump
On what system do you have that dude server installed?
Also I can confirm problem with dns names in dude loader, it has been reported to dev as bug.
i have that problem too. but i have a crazy solution.@jstump
I tried it using Win10/Virtualbox. I think I had an issue with the Virtualbox as routerOS itself was also losing settings, so I switched and am currently running on a CCR1016. I'm still receiving timeouts trying to import the db. After waiting a while, if I try /dude print I'm also getting a timeout error on that as well.
I am able to access now, but have the problem with all my interfaces showing unknown until I clicked reconnect on the router itself. If I go under devices - routerOS, highlight all and click reconnect, it fails. If I go onto the map, double click the device and hit reconnect, it connects...
System requirements for server package
RouterOS:
v6.34rc13 or newer
Hardware:
MikroTik CCR series hardware
RouterOS x86 installations
RouterOS CHR environment
Note: Use of dude server package is not supported on other hardware.
ok. so that means that i need to buy a x86 licence in order to use the new dude ?ggorbalan
http://wiki.mikrotik.com/wiki/Manual:Th ... stallationSystem requirements for server package
RouterOS:
v6.34rc13 or newer
Hardware:
RouterOS CHR environmentNote: Use of dude server package is not supported on other hardware.
Changes in v6.34rc45 build:
Fixed issues:
* Fixed server crash that some people where experiencing.
* CHR host upgrade fixed.
* DNS name resolving fixed in loader (will however work only after loader is upgraded to rc45)
* Added db vacuuming option
* Added progress indicator to import/export/vacuuming
Known issues:
* Device discovery tool does not work with Agents.
Any update on this? I can force them to reconnect to ROS in Dude, but they disconnect some time after again.@abis
I can confirm that unselecting Secure Mode fixed the ROS connection issues for me for now.I used this link:
http://download2.mikrotik.com/routeros/ ... 34rc45.npk
After install, dude server took about 1/2 hour to start.
From all the 6.34rc releases, I noticed that dude has difficulties connecting to objects that have Secure Mode checked.
How big is that dude db on usb flash? Have to get something similar and recheck.Testing on a CCR1036 it lasts 10 minutes for dude to startup and load it's data from an USB Stick.
ROS link mastering type was fixed some builds ago.
+1 v6.34rc45Now the dude client is unable to connect to the server. I see "Error: Connect failed: 10061: No connection could be made becaus..."
[admin@Dude] > dude print
enabled: no
dude set enabled=yes
