Hi I've been using the new dude installed in a CCR and we see that the "ping" in any of the devices entered the program restarts.
truewith the new update, every time you make a change and restarted, the changes made are cleared and return to previous state.
Hello Krisjanis,@abis
Problem with link monitoring in cases where ROS is used as mastering type is know to us. Dev has bug report for it. hopefully it will get fixed soon.
Changes in v6.34rc32 build:
* Fixed bandwidth test tool graphs.
* Ping tool client crash fixed.
* SNMPwalk tool client crash fixed.
* Spectral scan tool client crash fixed.
* In Admins > Group policies *web removed, no longer relevant.
* In Log configuration window sliders fixed.
* Right click "Open separately" fixed.
* Export to CSV client crash fixed.
* Fixed mastering type ROS for link label
* XML backup import fixed.
* Large DB export fixed.
ps, It might take a while to export large DB files. I did test with 4.5GB db and it
did take about 5-10min to create backup file on x86 VM.
Excelent great job!Changes in v6.34rc32 build:
From my opinion is much better in this way, you can manage it more easy, less resources needed and no license for an windows server neededGOod morning...
I'm still struggling why the decision was made to abandon the windows server? RouterOS is a router; a router is not a monitoring system. ANd vice-versa a monitoring system is not a router.
So whats the real reason?
Thanks leon
Email - Sends email, need to specify Server address. Authentication not supported.
smtp authentication support add please
FYI
If any one wants to try a third party android client: https://play.google.com/store/apps/deta ... dude&hl=en
That is a 3rd party app. MikroTik has no control over that app and probably does not support it.Your app has a couple of good reviews and a 2.3 rating, but according to your Google Play information this app was last updated in June, so does it work with this new version of The Dude or are you just plugging your product? Doesn't appear to be a way for us to even find out ourselves without signing up for a subscription with credit card and then cancelling it.
FYI
That is correct. I was also thinking of deleting the post as it has no relevance to new dude builds cause web interface from which it pulled info is no longer there. Although it might still be useful to those that use v3.6 or v4.0b3 servers.That is a 3rd party app. MikroTik has no control over that app and probably does not support it.Your app has a couple of good reviews and a 2.3 rating, but according to your Google Play information this app was last updated in June, so does it work with this new version of The Dude or are you just plugging your product? Doesn't appear to be a way for us to even find out ourselves without signing up for a subscription with credit card and then cancelling it.
FYI
Go to the MikroTik Downloads page, select "Release candidate (6.34rc39)" in the version selection dropbox, then click to expand either "tile" or "x86" section. You will find the links to download both "The Dude server" and "The Dude client" there.i didn't get this application/tool no where on Mikrotik download page. Where is the link to download this tool?
Hello Andriys! Okay thanks a lot. Got it and downloaded.Go to the MikroTik Downloads page, select "Release candidate (6.34rc39)" in the version selection dropbox, then click to expand either "tile" or "x86" section. You will find the links to download both "The Dude server" and "The Dude client" there.i didn't get this application/tool no where on Mikrotik download page. Where is the link to download this tool?
@jstump
On what system do you have that dude server installed?
Also I can confirm problem with dns names in dude loader, it has been reported to dev as bug.
i have that problem too. but i have a crazy solution.@jstump
I tried it using Win10/Virtualbox. I think I had an issue with the Virtualbox as routerOS itself was also losing settings, so I switched and am currently running on a CCR1016. I'm still receiving timeouts trying to import the db. After waiting a while, if I try /dude print I'm also getting a timeout error on that as well.
I am able to access now, but have the problem with all my interfaces showing unknown until I clicked reconnect on the router itself. If I go under devices - routerOS, highlight all and click reconnect, it fails. If I go onto the map, double click the device and hit reconnect, it connects...
System requirements for server package
RouterOS:
v6.34rc13 or newer
Hardware:
MikroTik CCR series hardware
RouterOS x86 installations
RouterOS CHR environment
Note: Use of dude server package is not supported on other hardware.
ok. so that means that i need to buy a x86 licence in order to use the new dude ?ggorbalan
http://wiki.mikrotik.com/wiki/Manual:Th ... stallationSystem requirements for server package
RouterOS:
v6.34rc13 or newer
Hardware:
RouterOS CHR environmentNote: Use of dude server package is not supported on other hardware.
Changes in v6.34rc45 build:
Fixed issues:
* Fixed server crash that some people where experiencing.
* CHR host upgrade fixed.
* DNS name resolving fixed in loader (will however work only after loader is upgraded to rc45)
* Added db vacuuming option
* Added progress indicator to import/export/vacuuming
Known issues:
* Device discovery tool does not work with Agents.
Any update on this? I can force them to reconnect to ROS in Dude, but they disconnect some time after again.@abis
I can confirm that unselecting Secure Mode fixed the ROS connection issues for me for now.I used this link:
http://download2.mikrotik.com/routeros/ ... 34rc45.npk
After install, dude server took about 1/2 hour to start.
From all the 6.34rc releases, I noticed that dude has difficulties connecting to objects that have Secure Mode checked.
How big is that dude db on usb flash? Have to get something similar and recheck.Testing on a CCR1036 it lasts 10 minutes for dude to startup and load it's data from an USB Stick.
ROS link mastering type was fixed some builds ago.
+1 v6.34rc45Now the dude client is unable to connect to the server. I see "Error: Connect failed: 10061: No connection could be made becaus..."
[admin@Dude] > dude print
enabled: no
dude set enabled=yes
