jchmelik
Re: The Dude, v6.36rc test builds.
Mon Jul 11, 2016 2:15 pm
@jchmelik
You get this error on multiple workstations with latest rc client? Is server status on ROS host "running"?
Yes I get this error on multiple workstations and the Dude server status is running.
Dude server operates normally, because I getting a notice about outages. I cannot connect using dude client only.
krisjanis
Mon Jul 11, 2016 3:16 pm
@jchmelik
Can you please try the latest build once more and generate supout file right after connection attempt. Then send that supout to support@mikrotik.com I'll check if something useful is saved in debug logs.
kivimart
Tue Jul 12, 2016 12:35 am
in rc37 snmpwalk dosnt work, no profile, nothing happens.
krisjanis
Tue Jul 12, 2016 9:16 am
@kivimart
That should be fixed in next build.
krisjanis
Tue Jul 12, 2016 2:38 pm
Changes in v6.36rc39:
*) Fixed - diff64 function broken.
*) Fixed - snmpwalk tool broken, status message simply shows "no profile" when starting. (broken in one of previous rc builds)
*) Fixed - Cannot add static element to map shows "no netmap" in status field.
*) Fixed - Server syslog port cannot be changed back to default if it has been changed one to something else.
*) Fixed - Server cannot upgrade device is it is running old ROS version: 5.26, 6.7. Error: "router packages unknown"
*) Fixed - Various problems with snmp probes.
LATNET
Tue Jul 12, 2016 4:29 pm
Settings - > click OK :
6.36rc28 ACCESS VIOLATION at: 45d000
eip=45d000 eflags=210202
edi=2c esi=99e298 ebp=99e26c esp=99e23c
eax=29 ebx=0 ecx=5dcaa74 edx=29
log:
4, 776e5de3, 776e5dae]
sm:backtrace:[4, 419c6f, 4dbe36, 4dc20d, 4dc3a7, 411087, 775684f3, 77546c40, 77546541, 77546300, 40e91a, 4fa287, 4fb6d1, 6487c2, 4010b9, 40129c, 760338f4, 776e5de3, 776e5dae]
unreliable backtrace:
modules:
bclewl1ns
Wed Jul 13, 2016 12:28 am
Looking good so far,  Thanks for bringing it back.
Two feature request:
Upgrade device firmware via Dude
Be able to upload .dpk files to devices via Dude
LATNET
Wed Jul 13, 2016 11:42 am
Change font size/type in static element - crash.
krisjanis
Wed Jul 13, 2016 12:37 pm
Changes in v6.36rc40:
*) Fixed - "..." button function in link configuration menu.
NOTE:  There is a server crash in rc40 which occurs on server disable, that also breaks db export process. We will fix it in next build.
@LATNET
Both issues reproduced in rc40 and reported for fixing.
@bclewl1ns
You mean option to upload the branding package?
jarda
Fri Jul 15, 2016 9:09 am
Having multiple Dude versions installed in different virtual / physical devices for testing purposes (mainly RC builds). For each version I have separate client software installed on my pc (in its own folder). When I move forward with some versions, I do not need the relevant client anymore. So I go to the "add and remove programs" in Windows7 and I see that there is only one "dude" record to be unistalled while 8 different versions are installed now. Why I cannot remove selectively in the standard way the versions of the dude client that I do not need anymore?
Please, make the windows installer to work correctly with versions! Each version should have its record in "add and remove programs" to be managed separately if installed separately.
Please, put the logging to syslog files back.
Please, make again backup/restore function to be working like in old 3.6 or 4.0b3 version.
Please, make the dude commands usable from CLI to be available from Winbox (and webfig) too. Think about to make these functions manageable from the dude client too, if possible.
Those additional parameters for dude vacuum-db are not described in the manual:
[jarda@CHR virt1] /dude> vacuum-db
append  as-value  do  file  interval  once  without-paging
Are they relevant?
Tried vacuum again with rc40.
Running vaccuum-db in "running" state it failed with message:
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
So I have stopped dude and run vacuum-db again. Now the state is "vacuum in progress" but cpu is iddling, doing nothing. How it can vacuum the database when doing nothing?
Thank you.
Edit: I removed the unnecessry clients by running uninstall.exe in their folder. But never mind the records in control panel - add and remove programs should be correct anyway.
krisjanis
Mon Jul 18, 2016 2:21 pm
@Jarda.
 Same as for many other programs The Dude installed treats it similarly as program upgrade which is why there is only one entry in windows installed program list. I could check if we can make a portable archive version this. I guess it would fit this case better than installer?
That will be done at some point. I understand the issue of syslog not being a whole with The Dude server as it was originally.
It's doubtful that Import/Export button will make reappearance in client side.
Before we do this, we will dig around and bit more in CLI side. After that we could possibly start adding support for The Dude in Winbox/Webfig side.
Code: Select all
Are they relevant?
Vacuum command has no arguments, so they are not relevant.
Code: Select all
In v6.36 final build there wont be that problem, rc39/rc40 had some crashes that occurred on server disable this prevented: disable, export, vacuum.
jarda
Mon Jul 18, 2016 2:51 pm
Thanks for the answers and looking forward to 6.36.
krisjanis
Thu Jul 21, 2016 11:38 am
Topic locked. Continuing discussion in http://forum.mikrotik.com/viewtopic.php?f=8&t=110424
Users browsing this forum: Majestic-12 [Bot] and 29 guests
