Basdno
Runtime error C++ when I try to start DUDE.
Wed Jun 15, 2016 2:44 pm
I have been using DUDE on this laptop for ages with no problem!
Recently I suddenly get this Runtime error C++ on one of my Laptops when I try to start Dude.  ATM I have Dude 6.35.4 installed, and on all other of my PCs its working like normal.
Only on this PC it simply wont start.
I have tried Uninstalling Dude and reinstalling several times, alos in different locations just to be sure nothing from old install should interefere or something.
I have also reinstalled all Microsoft Visual C++ Runtime redistributables, just in case there was some kind of bug.
Rebooting, and all the usual ways of remedies did not work!
Does any1 have a tip on how to resolve this issue, or do I really hve to reinstall my entire windows just because of this?
(I am not sure if it is related, but I also had a BlueScreenOfDeath because supposedly because of my touchpad shortly before I noticed the problems with the DUDE. However, I do not know, if these 2 incidents are at all connected!)
Any help and tips would be appreaciated!
I attached a Picture of the error message:
Dropbox Link to picture
krisjanis
Re: Runtime error C++ when I try to start DUDE.
Wed Jun 15, 2016 3:07 pm
The problem to which you are referring to is discussed here: http://forum.mikrotik.com/viewtopic.php?f=8&t=105533
At the moment there is no clear answer to what exactly is causing it, as it tends to occur only on some windows machines.
Basdno
Wed Jun 15, 2016 7:33 pm
Thx for the reply!
It is ONLY a problem on my Win10 laptop(and it worked fine before). I have 3-4 other PCs running the Dude client just fine! But so annoying not to be able to quickly check if all is green on my service LapTop when out on asignments! ;D  I now tried running it in Win8 and Win7 Compatibility mode, but to no avail. Same problem! As Mentioned in other thread I guess Microsoft must have bugged it up somehow in a update!
When I run a "Compability check! its only says that the programe DUDE is NOT compatible!
Grrrr, such bugs drive me crazy! :D :p lool  I have waste a lot of time debugging this!   And then the fault is probably neither my PC(or anything that I have done) nor Mikrotik, but probably Windows and Microsoft UPDATE!  (And on top of it all they now more or less FORCES the updates on u!) .
Cheers
Users browsing this forum: No registered users and 52 guests
