Would this include access to /tool sms and /tool e-mail for example ??@dimsoft
That is not possible at the moment. However we do intend to add some access to server host ROS side for better notification options.
Pretty much that. However email tool is already accessible for use with notifications.Would this include access to /tool sms and /tool e-mail for example ??
There are still features that are broken in v6.37rc builds due to all of the changes that are ongoing in background. However rc21 client no longer crashes when connecting to server. So it is definitely better than what was going on with rc16-rc19 builds.Do you consider it safe to upgrade from rc15 to rc21 for our test setups yet? (You still have the warning on the inital post)
Now that the dude uses radius from the host Mikrotik to authenticate, would it be possible to add two new Tool variables which are the current dude client username and password. Maybe [Client.Username] and [Client.Password].
We've made tools to launch Winbox 3 like "c:\winbox.exe [Device.FirstAddress] [Device.UserName] [Device.Password]" and it would be very useful to be able to just use the current users credentials and not the credentials from the settings in the device on dude.
Haha - of course e-mail is there - sorry.Pretty much that. However email tool is already accessible for use with notifications.Would this include access to /tool sms and /tool e-mail for example ??
At the moment this can only be done by disabling the server and deleting old db file.Two questions
2. I need command to clean all Dude database - return Dude to default like "system reset no-default=yes"
Sounds over all handy. Will check if we can create this login option for devices.Now that the dude uses radius from the host Mikrotik to authenticate, would it be possible to add two new Tool variables which are the current dude client username and password. Maybe [Client.Username] and [Client.Password].
I'll check if we can make it so that main map shows problems in sub maps if they are stacked like that.Would it be possible to enable/disable a submap state propagation to all (or defined number) upper levels? In The Dude 4b3 with this configuration Map -> Submap1 -> Submap2, if Submap2 has outages it is red in Submap1, but Submap1 is not red in Map. If there are a lot of devices in one area (Submap1) it is better to divide them into a several subareas (Submpa2) and without this option it is not possible to visually check the state of the whole network (Map).
This specific change should be in all builds starting with 6.36 and newer.I noticed in the change log, that diff64 was fixed in 6.36. Was that change introduced into 6.37rc, and if so, in which release? And what was fixed?
1. It is still there, just in different form. Check wiki manual for more details. Note that new implementation will be improved to have better default settings and no manual interaction on ROS host side would be needed.1. What happened to the Logging Section to which Syslog messages were being sent? Is this being deprecated ?
2. I cannot login to the dude - we are using Radius Authentication for Winbox Login, and with The Dude using local RouterOS users for Authentication, there is something broken here. I can login with local use, but I am getting the following for Radius Users: "Login failed: radius authentication is not supported for old challenges (6)"
It's already there for a few rc builds. Check my post on "execute on server" notification....
How long until we may see access to the SMS do you think ? We currently do this via a \Windows executable which is holding up trying the new Dude in production
I can reproduce the problem. Thank you for bug report.In the v6.37rc24-27 there is a problem with server crash after displaying any device popup window. I.e. you hold cursor for a moment on any device on any map, after taking it away from that device, server crash and then recovers itself after few seconds.
You mean that you restart the dude server or monitored host?We've just started playing around with 6.37 RC27 after giving this a bit of a wide berth for a while and the first issue we're seeing (after we import our dude database from 4.0beta3) is when the new instance first fires up it very slowly connects to all our AP's (routerOS connection type); it takes about 30 minutes to cycle through them all and connect. Once connected initially they reconnect just fine until we restart the service.
Is this a change made for a reason and can we turn it off; or is it a known bug?
Thanks!
adding google maps (or google earth) would be very usefull for WISP (like our team).Hi
As it is not listed in the features/bugs list, I would like to add a feature request.
Implementation of Google Maps API, so that we can position the devices on a dynamic, real world, map.
Thank you for updating us on the progress of The Dude. This kind of community connection is wonderful!
Regards
Karl
it is not fixed yet....There is a bug in 4b3 when you delete somehow a combination of device and link. I don't know how to reproduce it exactly. But the result is a deleted link in upper left corner of each map. It appears there after several seconds after switching to a map. It can't be moved, but you can double click it and use Remove button. There can be more of such links over each other. Is this fixed in a new version?
I have a small wish, add to discover, the ability to put a username and password.
+1 i'd love thisI have a small wish, add to discover, the ability to put a username and password.
rc36
Interface throughput bug
Also some graphical problem with mini map
[/quote]RC38
Note: For example, if I change the interface to "wlan1", Dude will display the result for wlan1, but the entry continues to display the first entry, in my case, "bridge1".
Reproduced and reported for fixing.yes in RC38 something is fixed, but yes what ever u select entry still stays "bridge1"RC38
everything else still dont work
We added a bit different approach for now. You can create custom tool with winbox for example: "D:/winbox.exe [Device.FirstAddress] [Admin.Name] [Admin.Password]" it will allow you+1+1 i'd love thisI have a small wish, add to discover, the ability to put a username and password.
in r34
also transferring files is like forever
am I missing something
We will include fix for this in next releases.by fposavec » Service ping on XXXXXX is now [Service.Status] ([Service.ProblemDescription])
[Service.TimeLastUp]
I am able to upload files to Dude via Winbox. I am unable to use Dude's upgrade feature on my ROS devices to a newer or older ROS version. When I try, nothing happens.Changes in 6.37rc42
- Disabled upload and drag&drop feature in Dude, for file management use Winbox, Webfig or ftp.
- Dude client will be instantly disconnected when the Dude server has stopped.
How! I can't put files in dude dir via winbox or ftpI am able to upload files to Dude via Winbox. I am unable to use Dude's upgrade feature on my ROS devices to a newer or older ROS version. When I try, nothing happens.Changes in 6.37rc42
