Version 6.38rc37 has been released.
*) Fixed - default files will be stored in dude files folder if the file system does not support symlinks (fat32)
*) Fixed - avoid going into loop (Dude client could get stuck in loading phase)
Note !
Since dude has received major changes in recent versions, some fixes will be included only in 6.38+
Some bugs might be reproducable only on specific hardware, server and network configuration, etc..
List of recently reported problems:
strzinek - /dude export-db|import-db, and device -> graph issue.
Problem not reproduced, please give us remote access.
celeritynetworks - dude email notification is configured under notifications -> type email. If there are any problems in Ros/Dude email, enable email debug logs, to see where it stucks.
maxkrok - should be able to add custom files to dude/files dir.
doush - minimum polices for user to use dude is read + dude.
sparrow - monitored service types, like cpu, memory, disk... will take more time to reload, this means you will still see device in outage tab even it is recently came up.
Button "remove resolved" will remove only services without active status.
Also will take a look at denser reported issues.
If you still can reproduce problem using the latest RC, please allow us remote acces to your dude server, with
ability to install special debug package on this device, if it's will be necessary. Send all information to
support@mikrotik.com,
also describe steps how to repeat the problem.
Reproduced issues:
nje431 - Background image load, ° symbol problem.
Recent feature requests for consideration:
*) Ability to specify custom port number
*) Links with edges
*) Multiple links between devices curves or polylines
*) Specify link port on both ends
*) Can't click on a sub-map from the primary map to display it. (webfig)
