onega
Re: The Dude, v6.38rc test builds.
Fri Nov 18, 2016 4:38 pm
DUDE FEATURE REQUEST:
Ability to specify custom port number for Winbox connections (e.g. to connect to multiple MTiks behind single public IP).
Many thanks for consideration.
...also is there a dedicated thread to post DUDE feature requests?
Ayapov8
Mon Nov 21, 2016 4:59 am
Update my CCR to RouteOS 37.1 and DUDE. Problem: Dude no send syslog to remove server. Pleas help me
strzinek
Mon Nov 21, 2016 11:49 am
Another problems with latest RC versions:
When I schedule dude db backup on RouterOS (with
/dude export-db
command), I always get my custom font removed from disk after the operation and not available in Dude any more.
I also noticed that custom MIB, font and image files are contained in backup file, but do not get restored with
/dude import-db
command. I have to copy these files manually afterwards through WinBox and restart the Dude to be able to use them.
celeritynetworks
Tue Nov 22, 2016 2:16 am
Email seems to be broken in 6.38rc30 and 31.
This is what I see in RouterOS log when I try to test email send from an email notification in Dude.
Here is how the notification is setup:
I've tried removing all the fields so that it just uses RouterOS Email settings, but no change. I looked in email server logs and it's not even trying to send it to the SMTP server.
When I send a test email from RouterOS using Winbox, it works just fine.
Chupaka
Tue Nov 22, 2016 2:05 pm
Shouldn't TLS Mode be not 'no' for that port?..
maxkrok
Tue Nov 22, 2016 6:31 pm
Since 6.38rc30 I cannot add any custom files (images, etc) to the Dude directories.. Even it happens if Dude is stopped and it's directory is changed at another path. I use RB750gr3 - MMIPS. Please help.. the disk1|disk2 switching problem is still annoying on RC34..
maxkrok
Tue Nov 22, 2016 6:45 pm
which hardware do you use?
strzinek
Tue Nov 22, 2016 7:17 pm
I'm using Dude on CHR v6.38rc31 on vSphere server 5.5 right now, because on CCR the stable version 6.37.1 was exhausting memory and CPU.
strzinek
Tue Nov 22, 2016 7:20 pm
Thanks for fixing the smb crash in v6.38rc34, it is working ok now.
Keep up the good work :)
doush
Long time Member
Long time Member
Tue Nov 22, 2016 8:46 pm
Adding a user with only a "dude" permission doesnt work. User cannot login
HiltonT
Wed Nov 23, 2016 12:10 am
This is where RoMON comes in handy. Configure RoMON on the gateway MikroTik device and set a password. Configure RoMON on the internal MikroTik devices and use the same password. Then in WinBox, select the gateway MikroTik device and choose "Connect to RoMON" and WinBox will connect to the gateway MikroTik device, change the bottom tab to "RoMON Neighbors" and you will see all the devices listed by MAC Address, with their Identities shown.
If you choose to Add/Set a RoMON device, it will add it to the main "Managed" tab with the "Address" listed as the MAC Address. I then group these under each client's code and then add a Note so I can tell more easily which internal device this is.
- Hilton
denser
Wed Nov 23, 2016 8:03 am
Guys, if there any ability to do such thing - connect links not in one point but in edge of object? When i want to draw 50 ports it become such a mess.
May be it should be able to make curves or polylines?
jarda
Wed Nov 23, 2016 8:05 am
That is something I was planning to ask for too. I am for it!
Chupaka
Wed Nov 23, 2016 2:03 pm
+1 (for multiple links betwee devices, for example)
also, it would be nice to have a possibility to set Interface for both ends of the link (to see that the link is from port 5 of switch1 to port 7 of switch 2)
sup5
Wed Nov 23, 2016 2:42 pm
Currently I solve this issue by putting a static-item inbetween a link.
This allows for
- links with angles
- setting both ends of a link with interface (and stats)
- drawing more than one link between two devices.
Chupaka
Wed Nov 23, 2016 2:47 pm
I was thinking about this, but...
PaulsMT
Wed Nov 23, 2016 3:11 pm
Version 6.38rc35 has been released.
Changes since v6.38rc32:
*) Fixed - Dude client stuck on "getting stuff state".
*) Fixed - Disk name were changed on RB hEX if the dude was used on USB flash or mSD card.
For security reasons it's suggested to make backups before upgrade.
http://wiki.mikrotik.com/wiki/Manual:Th ... ort_export
If you experience version related issues, give us detailed steps how to reproduce problem.
Also thank you all for suggestions and reports, we will take a look what we can improve in the Dude.
jarda
Re: RE: Re: The Dude, v6.38rc test builds.
Wed Nov 23, 2016 3:26 pm
This allows for
- links with angles
I have been using it for years also. But it is very poor solution.
I need multiple links between the same devices also. The idea to make link independently configurable by the endpoint devices / interfaces is the same I had in mind. It is also necessary to be able to replug the ends of the link from one old device to other new device without loosing the graph data.
leoktv
Trainer
Trainer
Wed Nov 23, 2016 5:39 pm
The problem with Dude client stuck on "getting stuff state" are confirmed solwed thanks MikroTik
nje431
Wed Nov 23, 2016 9:03 pm
Now that the Dude supports maps in Webfig, I updated our test Dude from 6.37rc15 to 6.38rc35. A few things I'm seeing with the Webfig maps:
Can't click on a sub-map from the primary map to display it.
Background images take forever to display.
It's not displaying the temperature symbol correctly. It's adding the additional  in front of the ° character. It displays correctly in both the 6.38rc35 Dude client, and in our 4.3 production Dude and Web clients. Appearance label: [Site_Temperature_Display()] °
maxkrok
Wed Nov 23, 2016 10:52 pm
Yes! Now Dude does not make disk name to be changed, but I cannot add any custom files to its directories even directly to RB/Files.. Please repair it and make available to add custom files over client...
HiltonT
Thu Nov 24, 2016 1:21 am
So, so yes!!!
And also, why is the "Wireless" link so... big?
HiltonT
Thu Nov 24, 2016 1:22 am
+1
denser
Thu Nov 24, 2016 10:48 am
Dude, please make links more cool, i even make White Russian for you :)
sparrow
Thu Nov 24, 2016 3:46 pm
Why on "link full" the colour don't change like in previous version 4.0beta or version 3?
Thanks for support
Attached image of dude 6.37.2
sparrow
Thu Nov 24, 2016 4:43 pm
And also if a service come back up from down, status on service outage does not change, is it normal??And its not possible to remove Resolved outages.........
Attached image below.
sparrow
Fri Nov 25, 2016 11:12 am
I have this message also:
dude,critical queued 33758554 bytes for write to db. Please consider faster storage otherwise out of memory condition or data loss can occur
Im using an ssd and ros is installed on a vmware machine to test the system before to make it in production
strzinek
Sat Nov 26, 2016 10:33 am
Still no graph labels in Device -> history tab in rc37.
denser
Mon Nov 28, 2016 8:06 am
Guys, in 37rc i get dude works! Thx goes to Pauls
- email support. But i have some troubles now.
1. I put font arial.ttf - its gone. Afetr i connect i see rectangles instead of russian letters. I put it again - wow, russian letters there again. Close Dude for a while. Run again - rectangles again, look into files - arial.ttf gone(whata...) Put it again - works for now.
2. Cant see snmp values on links. If i goes to node in snmp tab i can see speed on ports.
3. I have two monitors. If i open dude on 2nd and open preferences it can jump to 1st monitor. RRRRRR make me mad :)
PaulsMT
Mon Nov 28, 2016 9:33 am
Version 6.38rc37 has been released.
*) Fixed - default files will be stored in dude files folder if the file system does not support symlinks (fat32)
*) Fixed - avoid going into loop (Dude client could get stuck in loading phase)
Note !
Since dude has received major changes in recent versions, some fixes will be included only in 6.38+
Some bugs might be reproducable only on specific hardware, server and network configuration, etc..
List of recently reported problems:
strzinek - /dude export-db|import-db, and device -> graph issue.
Problem not reproduced, please give us remote access.
celeritynetworks - dude email notification is configured under notifications -> type email. If there are any problems in Ros/Dude email, enable email debug logs, to see where it stucks.
maxkrok - should be able to add custom files to dude/files dir.
doush - minimum polices for user to use dude is read + dude.
sparrow - monitored service types, like cpu, memory, disk... will take more time to reload, this means you will still see device in outage tab even it is recently came up.
Button "remove resolved" will remove only services without active status.
Also will take a look at denser reported issues.
If you still can reproduce problem using the latest RC, please allow us remote acces to your dude server, with
ability to install special debug package on this device, if it's will be necessary. Send all information to support@mikrotik.com,
also describe steps how to repeat the problem.
Reproduced issues:
nje431 - Background image load, ° symbol problem.
Recent feature requests for consideration:
*) Ability to specify custom port number
*) Links with edges
*) Multiple links between devices curves or polylines
*) Specify link port on both ends
*) Can't click on a sub-map from the primary map to display it. (webfig)
asik
Mon Nov 28, 2016 12:12 pm
6.38rc14 (Release candidate)
my requests
1. all alerts that have occurred in non-active time for such notifications for example between 00:00-08:00, should be added to the queue and be send at the beginning of an active time. If by that time the service started to function, the notification shall be removed from the queue.
2. If the main map contains several submaps, and added there devices are set depending on (parents), and when the device is not working in the tree above, I should get one notification about device failure which is highest on the tree even if it is on a different submap. Now i have many alerts. Maybe I have problem configuration of the DUDE?
no solution for these problems?
dcolli
Tue Nov 29, 2016 1:26 am
The execute on Server dont run script.
denser
Tue Nov 29, 2016 6:17 am
Some worksaround. Arial.ttf vanishes when old dude client connects and update itself.... Strange behavior.
Have another request (not onlu dude. capsman too) - autoload fresh versions of packages: analyse devices (caps in capsman) and download in prorep folder all needed files - files/packages on dude and folder pointed in properties in capsman.
chimaster
Wed Nov 30, 2016 1:29 am
Hey Dudes,
What happened to Address Lists?
Ok, that was brief, I'll Edit this up. Struggling with stability on 6.37.1,2,3 on x86, have tried to put our Dude onto CCR but that is also perfing out. x86 is based around SSL / CPU load, CCR is I don't know why. No idea why it's suddenly so unstable.
So trying to move to 6.38.something in the hope stability is there but it appears address lists have dissapeared. :( Can't find any mention of this in changelogs so assuming it's a bug, address list still turns up in /ip firewall address-list but they're pretty useless hanging over there as its our documentation when setting up routers / links in the dude.
Rock and a hard place over here with limited stability on "stable" releases and limited information / changes to core function (bugs) on unstable test builds.
We've got 2900 Access points and routers lulling around waiting for their admins to give them love, but right now.. the love.. it's .. .gone.
Can someone please think of the routers!?
Percanta
Thu Dec 01, 2016 6:09 pm
address list are on routeros now, /ip firewall address , so its working blacklist again (y)
maxkrok
Thu Dec 01, 2016 9:32 pm
6.38rc38 again adding custom files is not possible AT ALL.... Please repair...
maxkrok
Sat Dec 03, 2016 12:43 pm
6.38rc40 again adding custom files on MMIPS 750gr3 is not possible AT ALL.... Please repair...
PaulsMT
Tue Dec 06, 2016 3:08 pm
Changes since 6.38rc37
*) Fixed - File upload to dude/file directory caused client crash
*) Fixed - Background images could disappear on version change
*) Fixed - Snmpwalk was not working properly in recent versions
asik
At the moment it's not in schedule, but the request is stored, thanks.
dcolli
Few quick tests didn't show problem here. Make sure your dude user has the same policies as your script.
Test it with some simple script, to see if problem is not in the script itself.
If issue remains, send supout file to support@mikrotik.com.
denser
suggestion reported to developers
chimaster
address list is removed from dude v6.38.x
Please use address list from RouterOS
Also it would be great if you could provide us with remote access to device with SSL load problem.
maxkrok
Problem not reproduced. Works with USB/SD card as data storage path, tested with Winbox. FTP.
Make sure you are placing files in dude/file directory.
If you can repeat problem, please write to support@mikrotik.com.
Lakis
Forum Veteran
Forum Veteran
Wed Dec 07, 2016 12:59 am
chimaster
I confirm this, there is some SSL load problem on x86 OS 6.38rc40, reboot fixed for now
Next time I'll give you remote.
aTan
Wed Dec 07, 2016 10:25 am
I've already reported high cpu load by SSL problem (the Dude is unusable) on both CCR and x86 to Mikrotik support three weeks ago. But I can't give a remote access for now. So if anyone has the same issue, please provide a remote access, so it can be investigated and solved.
strzinek
Wed Dec 07, 2016 11:22 am
When I copy built-in tool to new one, I can't get rid of it afterwards. The copy cannot be removed. It says "cannot change built in (x)", although it is a copy and I can give it custom name and command. It shows star in flag column also as if it was really built-in tool.
mylek
Thu Dec 08, 2016 12:56 am
Before migrating from version 3.6 to the latest stop us lack of feature allowing to dump the list of devices in the form of a table: [map name where the device is] [device name] [IP address]. We use similar feature in Dude 3.6 via HTTP to export the device list with IP and location on the map to external databases (eg. smokeping). Any plans to add similar feature?
maxkrok
Thu Dec 08, 2016 12:29 pm
I cannot repeat it... It is permanent.. Please test on MMIPS RB750gr3. On RC44 the same problem... The dude directory is read only or something like that... Other directories - OK... Wrote to support..
UPDATE! All DUDE files are is being rebuit after each dude restart/reboot.. All custom files get vanished after that.. On sd disk - fat32 you can add custom files to the dude directories (images, etc) but after reboot/restart everything is default again.. All logs also get vanished.. Please help!
derr12
Thu Dec 08, 2016 8:38 pm
Im still having background images disappear from the disk at random times on X86 (xenproject hypervisor) on rc30. have to re-upload one or two weekly.
alfonzz
Thu Dec 08, 2016 9:15 pm
i use dude v6.38rc43 on new hex and there is maybe bug with RAM eating.
Hex stay up for 2 and half day and then reboot, for this time hour by hour eating the RAM until device reboot.
On dude i have about 1000 devices, monitoring by ping, some SNMP sonds etc.
It happens on earlier versions too.
alfonzz
Fri Dec 09, 2016 1:09 pm
All i want for Christmas is stable dude 6.38 :-)
FiShYmAn
Sat Dec 10, 2016 1:24 am
I am running dude 6.38 rc46, the last few builds have not been saving any changes for me, i have added new sites and devices in over 3-4 days and then the dude just reverts back to what it was like previous days ago - very frustrating.
Happy to setup remote access for support to look into it, ive lost several days work and would like a solution asap.
I've been using the dude since the beginning, loving the improvements, but this is a major bug.
Cheers,
Matt
2frogs
Forum Veteran
Forum Veteran
Sat Dec 10, 2016 6:57 am
Upgrade from v6.38rc40 to v6.38rc46 on CHR has removed the Dude Package. I had a Dude session open when it upgrade...
Lakis
Forum Veteran
Forum Veteran
Mon Dec 12, 2016 1:09 pm
Still SSL cpu load problem v6.38rc47
deathmagicmedia
Wed Dec 14, 2016 1:21 am
Will the Telegram notification support?
Agreed. It would be great if they added HTTP Notification as a notification type with custom parameters.
In the meantime, we created a Google Cloud App, which receives an email from the Dude server, converts the data, and then sends the data to Telegram. Our team will receive the data via our Telegram bot.
aTan
Wed Dec 14, 2016 3:52 pm
I managed to "fix" SSL high cpu problem (Ticket#2016111422000785) by increasing Connection timeout from 10s to 1m in Settings-RouterOS. On CCR it took a couple of minutes to get rid of SSL load after reboot, but it took much more time on x86 (4 cores). The problem was caused by hundreds parallel timed out connections to RouterOS (alive) devices and constantly repeating reconnections. After a successful connection to all RouterOS devices SSL load was gone.
PaulsMT
Tue Dec 20, 2016 2:11 pm
Version 6.38rc51 has been released.
Changes since 6.38rc41
*) Fixed - Changed SSL connection timeouts. SSL connections caused CPU overload
*) Fixed - Minor changes in Dude fonts
*) Added - Dude icon in Winbox/Webfig
The SSL problem should be fixed with this version, please test and report if problem repeats.
Also note that if you have very large network map, with lot of securely connected devices, you will still get relatively high SSL usage by CPU.
maxkrok - we suggest to use only ext3 file system, it's more stable for dude, and more tested. Here only solution seems remote access > support@mikrotik.com
For other reports, please send an email with description to support. Each report is checked individually.
deathmagicmedia -
Please give us more details what would be the best HTTP Notification method
aTan - thanks for detailed SSL report.
Chupaka
Tue Dec 20, 2016 2:29 pm
Is it hard to replace embedded WinBox loader version 2 with current version 3?
just an ability to make GET/POST HTTP requests. I was surprised when did not found that type of notification in Dude v3 :)
francisconeto
Trainer
Trainer
Tue Dec 20, 2016 2:30 pm
What about the commands terminal ?
ticket2016120822001445
/dude device print ==> show only the name of devices
/dude device-type print ==> show only the name
/dude service print ==> shiow nothing
/dude device device-group ==> Not exist
/dude probe print ==> show only the name
/dude notification print ==> show only the name
aTan
Tue Dec 20, 2016 3:05 pm
deathmagicmedia -
Calling https url with custom uri part with replaceable variables would be enough for me. And it should be usable in functions.
e.g. https://example.com/?api_key=my_api_key&ip=[Device.Address]&service=[Probe.Name]&state=[Service.Status]&another_custom_parameter=hello
PS: enabling/disabling ssl certificate verification would be also useful. Something like CURLOPT_SSL_VERIFYPEER and CURLOPT_SSL_VERIFYHOST in Curl.
digicomtech
Tue Dec 20, 2016 4:22 pm
deathmagicmedia -
Currently, we use this probe for HTTP and it works great:
Probe Type: TCP
Port: 80
Send: Authorization: Basic xxxxxxxxxxxxxt\r\n\r\nGET /state.xml HTTP/1.1\r\n\r\n
Receive: <input1state>0</input1state>
You can replace send with whatever HTTP request you want to send, and figure what you should receive.
You can use packet sniffer to help you find what is needed.
Using dude 6.38 rc 48 and it works good.
Don't know if it can suit for https stuff...
Regards,
Michael
RafaelUrsoft
Tue Dec 20, 2016 4:33 pm
In my case it still has not been solved, SSL is very high and the CPU stays at 100% all the time. I have enough devices, but in version 6.36 opened and now I could not open the monitoring once.
aTan
Tue Dec 20, 2016 4:52 pm
deathmagicmedia -
Probe Type: TCP
Port: 80
Regards,
Michael
But I need to send a notification through http request (service is up, service is down). There is no such type of notification as 'TCP Probe'. And it doesn't allow TLS/SSL connection.
PS: option to add custom headers is also a good idea.
OnixJonix
Tue Dec 20, 2016 9:39 pm
Vector graphic for dude - all Mikroti Devices???
maxkrok
Tue Dec 20, 2016 11:57 pm
Thanx for expanations.. You should mention that custom files are available for upload to files directory only.. I tried images directory.. It is readonly..
RedM
Wed Dec 21, 2016 4:23 am
I'm getting connection closed on both Winbox and The Dude with a number of users connected to The Dude server.
My only solution is to either get one of them to log out or reboot the machine and hope I get in to what I want before anyone else does.
I'm on 6.38rc51.
ste
Wed Dec 21, 2016 9:28 am
As the old dude ran into problems we migrated to the new dude on hex with a 2GB SD Card.
Runs smooth so far.
1166 Devices, 437 Service items, Polling interval 5min cpu 20-40%.
ste
Wed Dec 21, 2016 9:32 am
Device->General Router OS Status: "connect failed ... next attempt at: <time>"
shows a time 1 hour before actual time. The Hex the dude runs on shows correct time.
Version: 6.38.rc51
ste
Wed Dec 21, 2016 9:39 am
Feature request:
We have customers powering their device only at times they want to go online.
I would like:
- to see last time the device was online (to see if it is used at all).
- schedule an update in dude when he is able to connect this devices
ste
Wed Dec 21, 2016 9:50 am
Got a ping outage of a device. Right clicked on the device and selected Ack. The device gets blue on map. But the service is still in state outage (red flag). The dude flag in taskbar is blue.
6.38rc51 on hex.
alfonzz
Wed Dec 21, 2016 12:55 pm
pls update winbox loader to v3 in DUDE!!! Thanks
PaulsMT
Wed Dec 21, 2016 2:11 pm
Version 6.38rc52 has been released.
Changes since last version
*) Removed - Since default Winbox used in the Dude wasn't fully compatible with all RouterOS devices, we removed it completely.
*) Fixed - Increased default ping packet size to 54bytes - there was some devices who wasn't able to respond with 32 byte ICMP packets, this caused ping corruption.
Note that you can still use Winbox in the Dude, by simply adding it as a custom tool:
Here is the quick example:
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Tools
ste - Check if the ping issue remains in recent version, if it does, write to support
aTan
Wed Dec 21, 2016 2:26 pm
Is the Dude client autoupdate functional? I've tried it with several 6.38rc and it downloads something and then just shutdowns.
PaulsMT
Wed Dec 21, 2016 2:29 pm
Should be fine to autoupdate from all recent versions, just make sure that you run the Dude as administrator. Does anybody else have seen similar problems recently ?
aTan
Wed Dec 21, 2016 3:00 pm
%HOMEPATH%\Desktop\winbox.exe doesn't work (Windows 10) in Tools, works in File Explorer. Ordinary users can place files only inside of their windows profile and each profile has its own path based on username.
Didn't work for rc49->rc51 and rc51->rc52 (as Administrator). I had to update it manually. Also would it be possible to allow update without Administrator rights? Many companies doesn't allow to have Administrator rights. And updating it only by company's network admin makes updating to a higher version very problematic.
ste
Wed Dec 21, 2016 3:14 pm
Another option would be to keep Dude client unchanged if only server is updated.
ste
Wed Dec 21, 2016 5:31 pm
Typo: "Authetication Failed" on Server Configuration Tab RouterOS
ste
Wed Dec 21, 2016 5:34 pm
Winbox->Dude->Notification->Command: editable but Apply/Ok does not save changes.
asik
Wed Dec 21, 2016 7:59 pm
its important to find solution for this.
Another bug in tools/bandwith_test/ when - always "auth. fail" when start this tool
asik
Wed Dec 21, 2016 8:02 pm
when i upgrade to rc51 version background image is disapear AGAIN, when i upgrade to rc52 too.
alfonzz
Thu Dec 22, 2016 12:22 am
OMG.. nice solution :-(
Is there any chance to locate winbox.exe on router SDcard and run it from that location? with this "override" solution.
PaulsMT
Thu Dec 22, 2016 10:41 am
Should be fixed in next release:
%HOMEPATH% variable resolve from Dude tool
Reported:
bandwith_test - auth. fail
aTan - Autoupgrade tested with multiple devices, multiple versions, should be something specific.
asik - background image disapear not repeated, remote access will be apriciated !
alfonzz - No the tool should be accessible from your Dude client, this means on OS where the Dude client is installed.
Also note that you can pass arguments to Winbox - IP, usrename, password, so the Winbox tool should work as before.
Code:
%HOMEPATH%\Desktop\winbox.exe [Device.FirstAddress] [Device.UserName] "[Device.Password]"
normis
Thu Dec 22, 2016 12:46 pm
It must be in your Windows PC, not in the router.
celeritynetworks
Tue Dec 27, 2016 6:16 am
Devs: thanks for all the work so far, appreciate it! Sorry I didn't reply with update to email notification issue not working. Original email problem (post #104) was resolved. Was originally on CHR. Loaded new x86 VM and email notifications started working so seemed to be something with that specific load of RouterOS.
I can confirm our map background images randomly disappear from disk, too. We are on 6.38rc40 and have had to replace a background image twice and it ultimately disappears from disk. It is missing again now.
PaulsMT
Tue Dec 27, 2016 8:56 am
1. Please update your Dude server to the latest - 6.38rc version
2. If you can reproduce the problem, send mail with description to support@mikrotik.com
Ciambot
Wed Dec 28, 2016 10:06 am
In my case works only with this command:
C:\...\winbox.exe [Device.FirstAddress] [Device.UserName] [Device.Password]
also, if you wrong something in your path, error message shows clearly your password! :(
macsrwe
Thu Dec 29, 2016 4:22 am
I confirm this behavior as well. Not just the background image, but also some locally-added device images, such as CCR, RB2011, LHG -- only a few of them, not all of them. They disappear from dude/files/images and have to be re-uploaded. Problem seems to be triggered by release updates, and does not reoccur until next update. Reported this back on October 7.
I can also confirm the maddening "auth. failed" problem running bandwidth test in Dude. Reported it November 12, hoped it would be fixed by now. It forces me to turn off authentication on every device before I can run bandwidth test on it.
PaulsMT
Thu Dec 29, 2016 11:57 am
macsrwe - thanks for clarifying.
"auth. failed" problem is fixed, but we haven't released version where the fix is included. (next 6.38rc or stable 6.38)
Also please make sure, that all custom files are stored in dude/files directory only, as it is stated in the manual:
Your custom uploaded mibs/images/etc need to be stored in: "(data-path)/files/" directory.
http://wiki.mikrotik.com/wiki/Manual:Th ... 37_release
Ciambot - also the fix for windows variables is not released yet.
macsrwe
Fri Dec 30, 2016 12:34 am
Thanks, I didn't realize that.
Is it OK if we organize our custom images by creating a new subfolder under dude/files, e.g., dude/files/custom-images/, or will that cause problems as well? I imagine the custom images would no longer automatically "take priority over 'defaults' in case of duplicates," but I haven't been depending on that behavior anyway.
sparrow
Fri Dec 30, 2016 10:43 am
Mastering Type "routerOS" doesn't work, dude map show me all "?" SNMP works good
PaulsMT
Fri Dec 30, 2016 12:56 pm
macsrwe - Yes you can also place your custom folder under dude/files
sparrow - check if you can receive RouterOS data from that device - under RouterOS -> Interface. You should see the same results as in your link label
"?" will be shown if no data has been received.
Filip92
Fri Dec 30, 2016 6:40 pm
Hello everyone,
I want to report a problem with the upload file function in v6.38RC52 on mmips RB750GR3 - in this version and with this device, traditional "drag and drop" does not work, but there is a new button "upload"
because the device has only 15 megabytes of embedded memory, it should be possible to choose the destination disk (SD card or Pendrive)...
PaulsMT
Mon Jan 02, 2017 12:58 pm
Hello everyone,
Test from Windows / Linux didn't show problems with drag&drop
Maybe some OS related problem. Try to open files window, and drop file in some folder
aTan
Mon Jan 02, 2017 4:05 pm
Is there a changelog for the Dude 6.38 final release?
PaulsMT
Mon Jan 02, 2017 4:42 pm
Version 6.38 is released
Full changelog and discussions will be on this topic:
http://forum.mikrotik.com/viewtopic.php?f=21&t=116356
Users browsing this forum: No registered users and 8 guests
